Question about Microsoft Xbox 360 Console
First the colors messed up then the picture got bad then when i tryed to turn it back on there was no picture or sound then i turned the xbox on and the green lights were on and i could hear the fan but the tv said unsupported mode even though it was the right mode.
    Problem Solver:
  • 6 Answers
Your courd that goes to the tv is probably shot or you have the switch on the courd on the wrong setting
Posted on Feb 28, 2009
I own a 3 year old Panasonic TH-50px77u. The picture has changed and no longer shows and red color in the picture. This seemed to change when I plugged in an XBOX video game 3 night s ago.
If I understand this correctly, since you connected one of the HDMI inputs to an X-box, you do not see any red in any picture from any source, not even the SD Photo display input. White areas in the picture are cyan colored; other areas are various shades of blue-green. Red areas are black. This is the worst case; it is not clear from your description whether this is what you see or if the red areas are just not red enough.
Try going to the Picture menu and changing Picture Mode to "Normal", and Normal to "set". Turn Color mgmt. off. Refer to pages 26-27 of your owner's manual (download here). If this doesn't help, try selecting different Color temp settings. Make a note of which combinations of settings are giving you good results and which are giving you poor results.
If you cannot get close to factory default color, download the service manual and post back so we can take a look at the numbers in the video processor's EEPROM (data memory). We can continue diagnostics from that point if necessary. You may want to compare the EEPROM numbers for the settings that give bad results with the nominal values given in the service manual - if one of the numbers for red is way off, that could be the problem. Please post back before trying to change any numbers in the EEPROM - we don't want to make a bigger mess, and it would be a good idea to figure out what is going on first.
Jan 02, 2011 | Panasonic Televison & Video
Bowed in on both sides. colored lines everywhere
Open fuse/bad connections on HV ckt board and one or two bad capacitors.
Mar 22, 2010 | RCA D52W19 52" Rear Projection Television
My Xbox 360 Keeps Messing Up!
Sounds like a problem with the 360's graphics chip. You might want to phone microsoft support or take it to a 360 repairer.
Aug 12, 2009 | Microsoft Xbox 360 Console
Xbox has no picture but sound works fine.
Hi, this is an internal problem, please send your console to microsoft if under warrenty.
Jun 16, 2009 | Microsoft Xbox 360 Console
My xbox 360 has no sound and now no picture when it is turned on
check the brightness on your tv..or u cud have the wrong PAL settings..i sort of had the same problem but it was the settings on the console..
Feb 16, 2009 | Microsoft Xbox 360 Console
My XBOX 360 has a Sound but no picture issue.
Well the main solution that you're going to get from Microsoft is to unplug everything from your console and your TV and then wait a couple minutes and plug it back in while everything is off. If the problem still persists, instead of buying a new 360, try borrowing a friend's AV cable and see if that works. Try not to unplug or replug anything while the console or TV is still on. Or it could just possibly be all of the jostling around in your suitcase and nothing has come loose enough to stop working until now. Sorry I can't be more helpful, these are just some ideas.
Jan 09, 2009 | Microsoft Xbox 360 Console
Hello my name is steve
Maybe Your A/V cord went bad maybe you should try buying a new one
Dec 13, 2008 | Microsoft Xbox 360 Console
When i turn it on there's no picture
Replace your cables for the xbox im betting one of the contacts i worn, borrow a set from someone if you can and see if it fixes it.
Dec 12, 2008 | Microsoft Xbox 360 Console
Crazy color???
It sounds like you both have problems with the video card. If your 360s are some of the earlier ones then that is more that likely the problem (it happened to a friend of mine). 18004MYXBOX is the Xbox support number and will try to fix it over the phone of have you ship it out to them (they send you a box and its all paid for).
Oct 19, 2008 | Microsoft Xbox 360 Console
No picture or sound
perhaps the xbox is causing the tvs to malfunction. i would get a new one. remember that xbox is giving everyone a 3 year extended warranty on the xbox 360
Jul 31, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
80 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
