Question about ASUS Eee 4G Notebook
Screen blank i have a asus pc 701sd it was working fine turned off then when it was turned back on the lights came on but the screen is still black
  • Anonymous May 06, 2009
    i start up asus 701 lappy find that power and other lights work but screen fails. i tried changing to an external monitor and still received no signal.
  • 3 Answers
Before switching on repeatedly press f9 while doing this switch on and then a boot menu should come up. Choose the 3rd option restore factory settings and go through the steps as guided.
Posted on Jul 13, 2009
My asus eee pc 701sd wireless capability not working?
Try this: http://www.ehow.com/how_6814384_can_t-connect-wifi-eee-pc.html
May 05, 2012 | ASUS Eee PC 701SD Netbook
Hi - I have an Asus Eee PC and when i turn it on, the screen is black, the lights are on and its fully charged but nothing else happens...
The issue might be corrupted display drivers, I recommend you to boot the laptop in safe mode by using F8 key and if you are able to get into safe mode, update your display drivers and update BIOS.
Visit the below link for more information:
http://notebook-solutions.blogspot.com/2009/05/notebook-solutions-notebook-solutions.html
Aug 22, 2010 | Asus Eee 701Sd Notebook
Hi - I have an Asus Eee netbook and when i turn it on the screen is black the lights are on and its fully charged but nothing else happnes
sounds like WIN32 trojan. you can swap out memory card (RAM) and if it boots up then that's your problem. Only solution I found is once your system is up (if the memory swap worked) is to copy any vital files to external HDD/USB then reinstall the Operating System.
Aug 18, 2010 | Asus Eee 701Sd Notebook
Netbook Wont Turn On!!!
Restart your computer and keep pressing F8 and choose safe mode from the menu
once you enter safe mode,click on start->settings->control panel->system and then device manager
and under display adaptors,disable your display card and then restart it again and see if it works
Jul 22, 2010 | Asus Eee 701Sd Notebook
Pc 701sd turns on and works but the screen is black
have you checked the contrast or brightness?
Jan 17, 2010 | Asus Eee 701Sd Notebook
WHEN I TURN ON MY asus pc 701sd IT LIGHTS UP THE SCREEN FLASHES FOR A 1/2 SEC AND DONT TURN ON I TRYED EVERYTHING TURNED IT ON AND OFF TOOK THE BATTERY OFF I WAS JUST USING IT LIKE 1 HOUR AGO AND OPENED IT...
try removing the battery, and holding the power button down for 1 minute( with the computer unplugged of course) - put the battery back in and try to power it on again. this may or may not help
Oct 31, 2009 | ASUS Eee PC 701SD
Eee Pc 701SD/linux. No icons appear at startup, just blue screen
Try opening a terminal (Ctrl+Alt+t) and type the following:
sh startsimple.sh
and press enter. It worked for me, hope it will for you!
Jun 07, 2009 | Asus Eee 701Sd Notebook
Blue screen appears on start up and has no icons on screen cannot do anything does anyone know what this is
try and start it in safe mood and solve the problem from there by doing a system restore to a early date.
May 30, 2009 | Asus Eee Pc 701Sd Notebook
Blue blank screen is my problem
Problem: An update being pushed out to EEE PC 701SD causing machine not to load to full GUI
Symptom: Machine will start to load into GUI but will get stuck after loading taskbar.
To fix:
Open the Terminal window by pressing Ctl-Alt-T.
Enter the command 'sudo apt-get remove asus-p901-system-update azurebt'
Press power button to turn off machine.
Turn machine back on, open the terminal window again with Ctl-Alt-T.
Enter the command 'sudo apt-get install asus-eeepc-core'
Restart the machine.
May 23, 2009 | ASUS Eee PC 701 Notebook
What is your operating system if it is XP then press the F8 key repeatedly when you switch the machine on.
This should put you into safe mode
If you can achieve that then go to Start,Programs, Accessories System Tools, System Restore and try to restore it back a week or so.
Blue Screen is a memory crash so it could also be a problem with the Ram or a conflict
May 21, 2009 | Asus Eee Pc 701Sd Notebook
ASUS Eee 4G Notebook Logo
269 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
