Question about Vivitar ViviCam 7500I Digital Camera
I ordered a 1 GB sd memory card for the Vivitar Vivicam 7500i 7MP
They sent me a 2 GB card. Will I be able to use a 2 GB card or should I return it?
    Sergeant:
  • 319 Answers
YES! it will use it 100%, and congrats on the free upgrade! thats pretty nice.
Posted on Feb 28, 2009
How to delete pictures in camera memorey
Go into the menu options of the camera, select Format memory card, then confirm and press enter.
Jun 14, 2016 | Vivitar ViviCam 7500I Digital Camera
I just bought a Vivitar ViviCam T027 camera. The manual says it will accept sd cards up to 32 gb. My question is, will this camera accept the newer sdhc cards, or only the standard sd cards?
Hi there
Funny, I recently bought the exact same model. The answer to your question is simple (that's the good news!)
A long time ago, when these small SD Cards first appeared, they were limited in capacity from 128 Megabytes (MB) to a maximum capacity of 2 Gigabytes (GB).
To enable the same size card to store a greater capacity, a new specification had to be created. This new spec. was SDHC, and allowed the cards to store from 4 GB up to 32 GB.
The confusion arises because people still refer to all these cards as 'SD cards' when the higher capacity cards should really be called 'SDHC' cards.
Your camera will accept standard SDHC cards. Just make sure you don't order 'mini' cards which are much smaller in dimension.
Hope this clears up the confusion.
Phill R
Oct 04, 2010 | Vivitar ViviCam 3915 Digital Camera
Cant gat my vivitar 5024 to take its card
Your Camera supports a SD Memory Card up to 8 GB. But, its always recommended to use a 1 GB or 2 GB card since higher the capacity, faster will your batteries get drained. And since the 5024 takes in AAA batteries, they will be drained out really quick.
Locate the Memory Card slot. You should find it on the side of the camera just above the Macro/Normal Switch. Now, insert the memory card into the Camera. The Golden lines should be facing downwards and the angled cut part should be the first to enter. Gently push the memory card in and wait for the "Click" sound. An SD symbol should appear on your LCD screen. This shows the Card has been recognized.
Remember to use a memory card with a small capacity as it lets the battery last longer.
Aug 27, 2010 | Vivitar ViviCam 8025 Digital Camera
Every time I go to take a picture it tells me my new memory card is full.
Hi dear, Check your SD card, is it in the LOCK position.Or is your sd card over 8 GB.Because your camera only support up to 8 GB maximum.
Jan 18, 2010 | Vivitar ViviCam 8025 Digital Camera
How do I format an SD card for a Vivicam 3785?
You can format the SD card in your ViviCam 3785.
This utility formats the internal memory (or memory card) and erases all stored images and data. Make sure your SD card is in the unlocked position.
1. Press the button to turn on your ViviCam 3785.
2. Press the MODE button twice to enter Playback mode. Then press
the button to enter the Playback menu.
3. Select [Delete] by using the up/down arrow buttons, and press the OK button.
4. Select [Format ] by using the up/down arrow buttons, and press the OK button.
5. If you want to format your SD memory card or the internal memory choose
[OK] by pressing up/down arrow buttons, then press the OK button to confirm.
 To cancel the action, select [Cancel] instead.
 [No Image] pops up after the SD memory card or internal memory
has been formatted.
If you need a manual for your camera you can download a free PDF at
http://www.retrevo.com/support/Vivitar-3785-Digital-Cameras-manual/id/200ag818/t/2/
Please rate this solution. Thanks.
Jan 15, 2010 | Vivitar ViviCam 3785 Digital Camera
Cant format memory card for vivitar vivicam 5188
I cannot format the sd card. The camera stays in the busy mode.
Dec 09, 2008 | Vivitar VIVICAM 5188 PINK BNIB Digital...
Manual
i need a manual for my vivicam 7500i it was not in the box.
i also need a new charger as my kitten has chewed the wires
i hope you can help
Sep 08, 2008 | Vivitar ViviCam 7500I Digital Camera
Memory card
To my knowledge, the Vivitar ViviCam 3315 has an expandable memory by using a Secure Digital (SD) memory card up to 2 Gb as shown here.
As to your other concern, that of the manual, pls try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 08, 2008 | Vivitar ViviCam 3315 Digital Camera
Vivitar ViviCam 7500I Digital Camera Logo
65 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
