Question about Kenmore Washing Machines
Kenmore 700 series stopped with burning smell leftpile of black mtl under. motor hums now. rw
  • 15,935 Answers
It appears your motor/motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
I have a kenmore 700 series top-loader washing machine. Its about 8 years old but looks pretty new. My knob turns fine but the housing enclosure for the number does not turn with the knob. I have to...
The burnt plastic smell is probably the belt that drives the agitator. There may be something stuck (wrapped) around the shaft under the agitator that tightens the gears so the belt just slips and heats up. Remove the agitator and make sure the shaft is clear. also if it is belt and gear driven, check the gears. This means removing a panel or turning the unit sideways to inspect from below. The hum is the motor either not turning or turning with the belt too tight.
Hope this helps...
Oct 31, 2013 | Kenmore 24032\24036 Top Load Washer
My Kenmore 90 Series electric dryer makes a humming noise when I push the start button. It heats up, run for a short while, then stops. Before it stops there is a clicking noise like a circuit or safety...
There's possibilty that the bearing is going bad. It would cause the belt to slide alittle when the drums starts to turn. The strain on the motor because of the bad bearing can cause the motor overload and shut down until it cools, then it can be restarted.
Apr 08, 2011 | Dryers
I have a Kenmore Dryer, model # 96585210 / 65852. I have it apart and have narrowed my problem to the actual motor. I get a humming noise, but the motor does not spin. After a few seconds, it stops...
You have verfied the motor is shorted out already, when you hear it just hum and smell like burning rubber/electric.
Yes replace the motor.
Oct 02, 2010 | Kenmore Dryers
My Kenmore Series 80 (Model #110.23822100) will do everything except spin. It drains and pumps the water out, and I smell a faint burn-type odor. I looked on the Kenmore parts site but could not find the...
#13 in THIS DIAGRAM
is your coupling insert.
This is the weak point in the transmission - and fails regularly.
You may be able to see black pieces of rubber under your washer.
The coupling is made of plastic - and has teeth that break off too. CLICK HERE to see the full assembly.
The coupling/insert assembly itself is about $20. Look at about 1 hour labor charge if you are having someone else fix it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 06, 2010 | Washing Machines
Kenmore 90 series dryer, motor wont start, loud
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 10, 2010 | Kenmore Dryers
Humming sound and buring electrical smell
yes yes yes .you are absolutely right.its the coils in the motor burning.the motor needs replacement. Often the start relay for the motor sticks and makes the motor get too hot. This can cause the motor to over-heat and shut off on the built in safety sensor inside the motor. You may need to use a amp probe to test the motor properly, check model plate for proper amps.  If this is let go too long the motor windings can also be damaged ( they may look black instead of a nice copper color). The wires on the relay are also bad for burning off the wire terminals.   The wires at the motor should be checked to make sure they have not burned off or you can test the motor continuity with an ohm meter. See two newmotor wiring pictures.....here...and...here. The relay wires often burn off as well.
May 12, 2009 | Kenmore Washing Machines
Intermittent agitation and spin, mostly just hums, burning smell after replacing drive coupling
sound as if the motor or someting else is sticking release the belt on the motor. check belt for damage. check motor by turning it by hand to see if it is free.
May 12, 2009 | Washing Machines
Kenmore washer burning smell after motor coupling replaced
I have the exact same problem, which is why I found this post. Did it stop, or did you find a solution?
Mar 21, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
75 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
