There was a very strong burning odor in the laundry room. The washer was completely off. After moving the washer there was a pile of black rubber under the washer. after letting it set, I plugged it back in and there was a humming sound.
  • 70 Answers
The black rubber pile is from the motor coupler, you would need to remove the cabinet and gain access to the motor unit. most of the time you would need a service company.
Good Luck!
Posted on Mar 01, 2009
How do I remove odor from duet front load washer?
Assuming the odor is not a burning rubber smell or some other type of odor caused by a mechanical malfunction:
Remove the bottom of the washer (three screws I believe and above the drawer if you have one) and then open up the drain pump catch and clean it. You may want to put down some towels or even a bowl to catch water that will spill out. There are videos on how to clean this on youtube "Whirlpool Duet Water Pump Drain Catch". I believe this will solve the problem.
Oct 16, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet ghw9250 smells like burning rubber and very loud
Does the drum turn, if not then the drum bearings may have siezed.
Dec 30, 2012 | Whirlpool Washing Machines
Maytag washer MAV6650aww burning smell
OK, this model has a known issue with a bad pump design. The bearing on the pump goes bad and will lock up. The burning smell is the belt trying to turn the pump. Look under the unit and see if you see rubber residue at the pump. Here is the pump to order. To replace the pump, tilt the unit back and remove the belt. Remove the back lower left side access panel. Remove the 2 hoses, then the 3 bolts that hold the pump down. Replace in reverse order. The pump is a new design it looks completely different but will last you the life of the unit.
Dec 09, 2012 | Washing Machines
My machine has such a strong smell when the door is left open that is goes thru my whole house. I have black mold in the rubber ring - my machine is only 2 yrs old. Is LG helping their consumers?
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Nov 09, 2009 | LG WM2688HWM TROMM SteamWasher
I have had for about seven years a Kenmore Elite HE3 washer. It is no longer under warranty. We were going on vacation, so we unplugged it and turned the water off on the wall behind it, and kept the...
If you turned off the shutoff valve then it's defective. Valves in washer also must leak as both sets of valves have to open to let water into machine. Not sure what might be causing odor.
Sep 05, 2009 | Washing Machines
Sewer gas smell
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Apr 29, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
The washer driving belt breaks.
Sounds like a spin bearing might be bad:
Check this link:
http://www.fixya.com/support/t197849-burning_smell_screeching_sound_but
Apr 21, 2009 | Kenmore Washing Machines
Washer doesn't agitate.
Hi Karen,
It is not normal to smell a burning smell after a new coupler install. If the pump is not held on the motor with two clamps then it will raise off of the motor and strip the pump. This would cause the burning smell and also cause you to need a new pump. Before you use it again install the second pump clamp. If you cant find it let me know and we can ship you one over. Contact us anytime m-f 9-5. (865)945-3808
Anderson Appliance Parts and Service
Michael Anderson (Owner)
Sep 24, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
