Question about Eemax Water Heaters
Ihave aEemax (listed)7b95 110volt instant water heater,is their a way to adjust it for more heat?its barely worm.
4 Suggested Answers
  • 659 Answers
SOURCE: once hot water is open the gas is burning and water is not heated
Sounds like the flow is too high and or the temp set too low.
Posted on Apr 02, 2009
Coleman37
  • 337 Answers
SOURCE: waterheater barely heating
If it is old, it may have sediment build up at the bottom. This can be drained. The heater element may have burned out also. We would need more information as to the age, model, etc. in order to provide any more information. Good luck!
Posted on Mar 04, 2010
  • 94 Answers
SOURCE: no hot water from brand new heater
check your thermostat's,be sure they are turned up,tighten all (check),elect' connection's.
Posted on Apr 27, 2010
My water heater is very slow to warm water to take a shower with. I cannot find the manual for it, and have no experience adjusting a heater. Heard am supposed to drain the heater at times need advice
first im going to assume its an electric model , as this is what ill describe on how to adjust and repair .
electric water heaters have two sets of heaters inside them , one that maintains a water heat temp and one that heats the incoming water (sometimes refered to as instant )
looking on sideof heater there should be two covers , one towards top and one kinda at the bottom , the cover at top can be removed to expose the instant water heat temp , now care needs to be taken here as power is exposed and present , looking inside here should reveal a round thing with two screws on it , kinda looks lke a large bolt with two screws on it , this is the heater coil , and just next to it a rectangular thing with six screws on it this is the thermostat , if should have a tiny dial on it and be marked off in degress numbers , this dial should be set 10 to 20 higher than bottom heater (under bottom cover exact same thing there .) if not use plastic knife (table ware ) NOt metal to turn setting till this is achieved , this is how to adjust it , but by your description I suspect one of your heaters has gone open and not heating anymore , they do sell simple kits to repair your own heater and there not expensive less than fifty bucks and most times can be done by owner (follow instructions to letter ) or your in for a mess or worse
and yes once a year you should drain off a few buckets of water from bottom tap to keep sediments from damaging heaters
Jun 03, 2017 | Water Water Heaters
Water heater
Most instant-on tankless water heaters require at least 10 psi of water pressure to start the heating process. The flow of water determines how hot the water will be, within the heating range. An electric 110 volts heater will increase the water temperature about 25 degrees F. A gas water heater will increase the water temperature about 45 degrees F.
Too much flow will not allow the water time to heat. Too little flow will not allow the heating system to work. Each heater must have the outflow water flow adjusted for the best heating outcomes. The best way to find the ideal flow is to turn the hot water facet on and adjust it (open or close) until the water reaches the balance of producing hot water.
Apr 25, 2016 | Water Water Heaters
LB2280 leak
If this is instant heat faucet, then contact manufacturer.
Most these faucets have 1 year limited warranty
Replace faucet?
http://waterheatertimer.org/How-to-install-point-of-use-water-heater.html
Gene
Water Heater Timers Save Money
Dec 02, 2014 | Franke LB2280 Instant Hot and Cold Water...
My Takagi TK3 isn't heating as it should. Had a tech out and he adjusted the dip switches to 140 degrees, which worked for a while but now it barely heats to 100 degrees. Gas flow rate appears to be...
Is tankless computer older than 5 years? Imagine how well a 5-year old laptop computer works.
Setting temperature to 140 degrees might be the basic problem:
Read following resource:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
I doubt this Takagi computer unit was maintained as shown in product manual, and that heat exchanger was not delimed each year as shown in product manual. So the heat exchanger is probably heavily coated with un-removeable scale... since yearly deliming will not fully remove scale on tankless units, the tankless computer is designed to sprial downward in efficiency despite glossy brochures that promise endless and effortless hot water for 20 years ... as if any computer will last 20 years:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#de-lime
Since you are not getting error code, the problem might be crossover, or some other plumbing problem:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#no-error
http://waterheatertimer.org/Crossover.html
I always recommend replacing tankless computer with tank-type water heater for $385 for same-day do-it-yourself solution and to save the endless expenses that arise with computer-driven water heaters.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Aug 30, 2013 | Takagi T K3 OS P OnDemand WaterHeat
Newly installed Hott Rod in 6 gal RV water heater only heats to lukewarm. Has been on for 12 hours. Outside temperature is 60 degrees
Hott rod is 120Volt AC.
Check voltage supply for undervoltage, or reversed polarity, or tripped breaker.
Check that electric thermostat is set to 120 degrees.
Rotate thermostat temperature adjustment back and forth and see if you can hear water heater working.
Thermostats can be bad, or stick.
Check the ECO red reset button is not tripped out.
If tank was not full of water before power was applied, the element will instantly burn out.
Use continuity tester across bare element screws to see if element is good. Or use multimeter and test across bare element screws shows 29 ohm for 6 gallon, 18 ohms for 10 gallon.
More resources at Hott Rod, for troubleshoot and contact.
http://www.hottrod.net/hott_rod_troubleshooting.asp
Oct 31, 2012 | Camco Hott Rod RV/Camper 6 Gallon Water...
Not heating water hot enough or as much water.
You probably have a bad heating element. Probably the upper element.
Feb 03, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
We just bought a new water heater and it's not heating up water.
The heating element was bad. It's hard to believe that a brand new water heater would have a burn element, but that's the problem. I replace the heating element and its started working properly.
Dec 01, 2009 | Whirlpool Water Heaters
Hot water coming out of overflow, valves all been checked. Santon unvented heating system help!!
this wil happend with heating ??
if yes look for thermostat on boiler and turn it a little back then wil heater worming up only not to the max heating so then you do not need overflow outlet never leaking again out of overflow
Nov 08, 2009 | RTO SantonĀ® Tankless Hot Water Heater -...
Water Heaters Logo
69 people viewed this question
Top Eemax Water Heaters Experts
gizmonix
Level 1 Expert
Tim Whalen
Are you an Eemax Water Heater Expert? Answer questions, earn points and help others
