Question about Coleman Powermate Premium Plus 6250W Portable Generator
Coleman 5KW gen motor shuts down when A/C switch turned on
The motor runs fine and was recently serviced. The generator was run about six weeks ago and produced electricity. Now with the generator motor running and warmed up when I turn the A/C switch to "ON" the motor goes under load and shuts down completely. This is without anything plugged into the unit.
  • 169 Answers
Sounds like a problem with the wiring of the outlets after the circuit breaksr. Take apart the outlet box and have a look for burned or broken wires, melted outlets, and/or small critters stuck in the wiring.
I recently had to repair a generator that had its voltage regulator taken out by a frog!
Regards,
Carl
Posted on Mar 01, 2009
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
No AC out put
After working on several of this style coleman generator,i have found that the lead wires in the windings that are soldered to where your brushes would contact tend to break.I don't know if it's a poor design or just a fluke,i would check to see if your getting continuity on the rotor and go from there.They seem to either "burn off" or just break.
Mar 09, 2010 | Coleman Powermate Powermate 5000W...
The coleman voltage generator for 250 kva gen set
Well I assume that this generator is NOT three Phase, and delivering 440 Volts? in that case, that reading is what is called and "Open Circuit" reading, with a full load, that reading will/should come down to the nominal voltage of 250 V (+/- 10%) This generator is a 250 V AC unit? If this is so then it is operating correctly? It is 5kw UNIT. using a digital multimeter due to it's large input impedance it will often give erroneous readings if NOT loaded down with the correct.any. load.?
Mar 02, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate on/off switch broke off. Is a DIY out of the ?
there is a wire in the back of the control pad...right behind the on\off switch...once it touches the naked body of the gen. it will shut off..
Sep 29, 2009 | Coleman Powermate Powermate 5000W...
Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Sep 24, 2009 | Kohler Electrical Supplies
Coleman Powermate generator will not start.
Changed plug since last year?Choke adjustment? try premium gas?
Aug 13, 2009 | Electrical Supplies
Generator plugs doesn't match cord
Hey steve. do you really need 240 volts for 120 v. circuits. the reason you have to have an adaptor plug is because on your 220 volt plug in , 2 of tthose prongs are hot and 1 is ground. for safety you need to get a plug adapter ( a regular 120 volt plug end ) run a ground from adapter to ground on 220 adapter. same with nuetral. you also need to ground your generator. there is usaully a ground lug on the bottom of the gen. Another way. if you dont really need 220 v. is to use both 120v. recepticals on gen. Run 2 chords to tranf. switch. and hard wire it in to switch. another way i did mine . when i lost power in this hurricane. i ran two # 10 chords from my 2 120v. recept on my gen to my breaker panel. when you do this you have to pull the service meter, if you dont when power comes back on it would backfeed through your gen.then i turn all my 220v. breakers i was able to run lights ,ciling fans, freezer, ice box,washing machine and gas dryer , tv's computors etc. . but to do this, you probably need someone that knows what they are doin.
Sep 18, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
322 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
