Question about Kenmore 3.5 cu. ft. Front Load Electric Washer
Blockage We have a front loading Kenmore super capacity 3.5 that has some blockage - but we cannot figure out how to take off the front lower panel??? Help
    Scholar:
  • 106 Answers
Your filter on your pump is probably clogged with lint or muck. You have to remove the bottom front panel, 3 screws, torx screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels and unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Try your washer.
Posted on Mar 01, 2009
  • fixer444 Mar 01, 2009
    The 3 screws are at the bottom of the front panel, have to raise the machine a bit to unscrew. How about rating me?
  • nikotug Nov 14, 2010
    Had a scraping sound, but only on discharge...with helpful hint above, was able to take apart filter area and remove a piece of wire that had fallen out of clothing and ended up poking into discharge pump. 15min better than $1000 for a new machine. thanks
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Kenmore washer front load 3.5 super capacity clogged pump.
Remove the lower front panel and unscrew the LARGE 3" round plastic access cover. Have a drain pan handy as it will pour out water! Dump the coins, lint and whatever is collected in there, reinstall, tighten securely and replace the lower panel.
Jan 17, 2015 | Kenmore Washing Machines
KENMORE SUPER CAPACITY 3.5 WASHER WILL NOT DRAIN WATER OUT OF THE WASHER?
drain pump is bad or has a blockage will need to inspect drain pump and clear any blockage if clear replace pump
Jan 16, 2012 | Kenmore 3.5 cu. ft. Front Load Electric...
I need to know how to get a manual for a kenmore ultra bake self cleaning super capacity oven can you help me
Many Kenmore manuals are available from the Manage My Life site: http://www.managemylife.com/mmh/owner_manuals?intcmpMMHxG_HomexServices_Menu .
You will need the model number - there are over 9,000 ovens that come up when you search Kenmore Ultra bake self-cleaning super capacity oven. Most of the Kenmore ovens have the model and serial numbers on the front frame. (Left front of the frame on the lower oven on a dual oven model - just open the door and the panel should be visible.)
I hope this helps.
Jan 04, 2011 | Ovens
Kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
JimmyC
Oct 05, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
Kenmore 3.5 super capacity. will not go to spin
if the drive coupler is broken it won't wash or spin. Does it have a removable lower access panel on the front? if so its an amana. see if u can manually turn the transmission pully both directions. AND make sure there is nothing holding the tub ie nail through tub whole garment between tubs etc.
Jun 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't fill w/ water, Kenmore 3.5 Super Capacity Front Loader
The pressure switch is likely to blame. Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
208 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
