Question about Tomtom ONE GPS Receiver
Left mine in a drawer for 2 months. Now it won't start. I charged it for an hour in my car (while driving) via the cigarette lighter, but it still didn't turn on. Now I'm using an AC adapter to charge it - still won't turn on. Glad I got the Radio Shack service plan.
  • richardmclea Feb 28, 2009
    my tom tom was left unused nand now it will not turn on
  • 24 Answers
Try to hold the pin for 10 sec. if doesn't help, change a battery.
Posted on Mar 01, 2009
Used cigarette lighter to inflate tire, left inflater on for a long time now cigarette lighter doesn't work and car doesn't always start
It sounds like you might have drained your battery! When the car is running does the Cigarette lighter produce power? It should be working while the car is running. That would also explain why the car starts sporadically. Try leaving the car on for 40 minutes. That might charge the battery enough.
Jan 22, 2014 | 2001 Pontiac Grand Am
I just bought a garim nuvi 1360 and i forgot to ask how to charge the unit . first to plug it in the car lighter, what about the usb, could i tapp it in my laptop thru usb. pls explain better oscar...
There are 3 ways to charge your satnav. You can charge it with the car cigarette lighter socket or an optional mains charger both of which take around 4 hours. You can charge it through the USB port of your computer which takes about 8 hours. If charging with the computer both the satnav and computer should be turned on.
If charging with the car be sure that there's power going to the cigarette lighter socket. Some cars need to be running for power to reach it.
Jul 12, 2011 | GPS
Garmin screen is all i get, then it turns off
try changing the batteries or placing the device on charge and unplugging it, if both those don't work go to the support section on garmin's website www.garmin.com/support/
Aug 04, 2009 | Garmin nuvi 200W GPS Receiver
DOES NOT CHARGE AFTER HOURS OF CHARGING WILL NOT TAKE ANY INFORMATION.
Confirm that it is charging, check the fuse for the cigarette lighter socket in the car you are using, check the fuse in the power cord, the tip of the cigarette lighter adapter should twist off and expose a fuse.
Hope this is of some help.
Ed
Apr 26, 2009 | GPS
Dead
Does the cigarette lighter work in the car when you press it in? Does it get hot? If not has the fuse blown for the cigarette lighter?
If that is supplying power you may have a fault in the cigarette lighter to Tom Tom lead. Carefully check the fuse (one of the six bumps) in the plug and make sure it is still intact (use a meter).
If the fuse is OK then the lead itself may be faulty and probably needs to be replaced.
HTH
Peter
Jan 26, 2009 | Tomtom ONE GPS Receiver
New Garmin 260 W won't do anything when plugged in.
Your PC may not be able to charge it. If it does it's only a trickle charge. May take a day or two
The Garmin cigarette lighter charger take 4 hours.
Dec 26, 2008 | Garmin nuvi 200W GPS Receiver
Fuse for the cigarette lighter - Vauxhall Vectra 03
for a 53 plate right had drive vectra the fuse for the cigarette lighter is in the passangers side fuse box.
open the passanges door, open the glove box, the side of the dashboard revealed by opening the door comes off. on mine it is very tight and has a warning on saying it contains an airbag - it does not.
inside are four columns of fuses, the cigarette lighter is hte bottom fuse of the third column from the left - f22 i think. it is a green 30.
Apr 06, 2008 | Car Audio & Video
How to recharge the unit
you can charge it via the usb or cigarette lighter.  either method will work and i am not aware of any problems created by using the lighter.  that really should be the primary charge method as it is expected to be used in the car.  is it charging on your computer.  if it is, but not on the lighter you may want to ensure that the lighter is itself working correctly and then also check to make sure that the fuse in the car charger is intact.  just a few suggestions
Dec 25, 2007 | Garmin StreetPilot c510 Deluxe GPS...
Garmin street pilot 330
Take the navigator 2 a repair center, because somethin that new, shouldn't happened unless it hasn't been charged for awhle after being in the box on the shelf
Oct 14, 2007 | Garmin StreetPilot i3 GPS Receiver
Tomtom ONE GPS Receiver Logo
26 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
