Question about Linksys (NH1005) 5x10/100 Mbps Networking Hub
How do I connect a LInksys NH1005 hub to a wireless router? Do I have to connect directly to the dsl modem first? change the ip address and then connect the router?
  • Tim Crosslin May 11, 2010
    So you are saying you have DSL modem and that is connected to the Wireless router? And you want to add in a Linksys hub?
  • 59 Answers
If you have a port in the back of the wireless router open which you should just run a CAT 5 (network cable) from the back of it to the Linksys hub. That should do it. This way the wireless router won't have to be messed with and you shouldn't have to change a thing.
Posted on Feb 28, 2009
I got 3 PCs in my room & I got an old NH1005 thinking that with it, I would be able to connect the 3 PCs to the internet at the same time. When I connect any of my PCs directly to de MODEM, I get...
It would seem that the modem has only one ip address to offer. The switch won't allocate ip addresses to everything, for that you will need a cheap router. Install, enable DHCP and Away you go!
Good luck. Hope this helped.
Mark Vincent
Jul 05, 2011 | Linksys (NH1005) 5x10/100 Mbps Networking...
Linksys NH1005 V2.2 Ethernet 10/100 5 Port Hub Router. I cant get the other computers connected to the hub to connect to the internet. I've tried everything.
Hello!
I will just illustrate on how to configure or to set the correct IP addressing;
Assuming that we will manually put IP address on each computer:
PC1:
IP Address: 192.168.1.13
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.1
Preffered DNS server: 192.168.1.1
***note that 192.168.1.1 is the IP Address that your ISP gives to you, so on the other computer (see below)
PC2:
IP Address: 192.168.1.18
Hope I was able to help.
Oct 09, 2010 | Linksys (NH1005) 5x10/100 Mbps Networking...
Cannot connect to att DSL through Linksys router.
hi
I've tried:
Having the router get an IP automatically from the modem.
Changing the router's IP address.
Having the modem pass PPPoE authentication to the router.
Bridging the modem.
Power cycling the guts out of everything.
Jul 02, 2010 | Linksys Wireless-G WRT54G Router
Im trying hook up a wireless router and it ask what kind of conection I have static ip ect... How do I know what I have? Im using DSL.
Most residential subscriber services use dynamic IP addressing. Dynamic IP addressing is automatic from your Internet Service Provider (ISP). Linksys home based products such as the one you have should be setup up for this configuration out of the box by default, and require no adjustments to the IP configuration of the wireless router.
You should power down the DSL modem and Linksys, then connect them, then reapply power. This will clear the DSL modem if it was connected to another device such as a PC. This is important as most cable and DSL modems use something called MAC address binding that will only allow one device to connect to it directly at a time.
Feb 06, 2010 | Linksys Wireless-N WRT150N Router
How do you connect a Linksys NH1005 v2 hub and whats the difference between a hub and a router?
A router takes an Internet connection, routes it to several other computers and provides each of these computers with their own IP address.
A Hub, on the other hand, will split the Internet, but the various ports on the hub will all have a single IP address. Makes it hard to use a computer for much of anything, if it is the second computer, you'll have trouble getting access.
Nov 13, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
Only one computer can acces the internet in my hub , I have a Linksys NH1005 hub , I'm using cable dsl , but only one computer can acces the internet , it does not matter wich port
If you want to use more than one computers you will need to replace that hub with router. Best is to get wireless router because in most routers you have places for wired connections and also wireless connection.
Reason why you can't use more than one computer is simple because most ISP are allowing only one computer to be connected from DSL modem.
Oct 24, 2009 | Computers & Internet
Need help!!
Just enable the DHCP capability of your DSL router and then connect the Linksys hub to your DSL router then your PCs to the Linksys hub.
Jul 03, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
Mode, Router, hub problems
Since you cant swap out the hub with a known working one, then the best advice that I can give you is to try to plug in the computer directly into the modem. If the Local Area Connection is able to gain a connection then you know without a doubt it was the hub causing problems. They actually dont sell hub's anymore but switches, here is a link to bestbuy.com that has a listing of switches and their prices that you can check out --> <a href="http://www.bestbuy.com/site/olspage.jsp;jsessionid=LJWOPCFTAK0UDKC4D3EFAHA?_dyncharset=ISO-8859-1&id=pcat17071&type=page&st=Switches&sc=Global&cp=1&nrp=15&sp=&qp=&list=n&iht=y&usc=All+Categories&ks=960">Best Buy Switches</a>
Apr 02, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
NH1005 network hub
I assume that besides the 2 computers you also have a cable or dsl modem connected to the hub in order to provide the actual connection to the internet.
The problem may be the fact that this is a hub and not a router or gateway. The problem is that although it will allow you connect more than 1 computer to the internet, it does not do any good if you Internet Service Provider only supplies you with 1 IP address. You need something that handles Network Address Translation (NAT), like a router or gateway device.
Sep 28, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
Network Hub or Router - World of Warcraft - NH1005 Linksys
I recommend purchasing a small switch because what it sounds like is that the traffic being generated from and to the two computers and then out to the Internet is killing your hub. A switch would help reduce some of the traffic.
Mar 23, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
Linksys (NH1005) 5x10/100 Mbps Networking Hub Logo
754 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
