Question about Dell Dimension 2400 PC Desktop
How do i get the side panel off my dell dimension 2400? there is a lever in the back and when i push down on it it still won't budge. i need to clean it and try to figure out how to put more memory in it.
  • hfree2b123 Mar 01, 2009
    totally worked, thank you so much.
  • 59 Answers
Http://support.dell.com/support/edocs/systems/dim2400/en/f75560lrs.pdf
Here is a pdf that will show you how on page 49, I know you may have to put a little elbow grease into on the Dell Dimension 2400. I have had this problem also, sometimes they are just a little stubborn.
Hope this helps.
Posted on Feb 28, 2009
  • Tim Crosslin Feb 28, 2009
    Also in this same PDF on page 64 it will show you how to add memory.
  • Tim Crosslin Mar 01, 2009
    Your welcome and thanks for using FixYa.
    President:
  • 2,692 Answers
Are their any screws on the back on that side? If so remove them first. Press the lever down then pull the sheetmetal toward you,like a hinge door, with the hinge in the front.
The Link is to your manual which should have directions in it.  http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen
Clean a fan on dell 2400 inspiron desktop computer
okk, ann,may 16 2014. face back of ur pc, on the right hand side of pc U will see a knob like 4in up. it looks like a (L) written backward. just move it down (make pressure) at the same time the panel on that side has two indents pull the panel back using them .
don't rush it , take ur time ,piece of cake and happy clanning.
May 16, 2014 | Dell Dimension 2400 PC Desktop
Want to remove cover of the computer to clean inside
Just push down on the lever on the back of the case and it should slide right off.
Dec 07, 2010 | Dell Dimension 2400 PC Desktop
How do I get the cover off of my Dell Dimension 4600 Computer. The position of the lever is not obvious.
press the lever catch on the back of the tower DOWN, and hold it and slide the side panel to the rear
Sep 17, 2010 | Dell Dimension 4600 PC Desktop
I push down the white lever and then I cannot open the back of the terminal
Maybe a powersupply wireing is jammed inside when it was installed
Aug 20, 2010 | Dell Dimension 2400 PC Desktop
On replacing a Dell Dimension 2400 power supply, I can't seem to dislodge the P1 20-pin power cable from the motherboard. I noticed that there is a small plastic "nudge" on the 2 narrow sides of the...
On just one of the "long" sides of the power-connector, there is a small "lever" -- press the hinged lever, at the end the furthest away from the motherboard, to unhook the connector from the socket, and then pull.
Jun 09, 2010 | Dell Dimension 2400 Power supply - FREE...
I need to know how to get into my computer to install a new ethernet port- I can't figure out how to remove the outer shell since all the screws are on the inside.
There are fasteners somewhere ... may be screws, may be latches. Look Closely
Your computer didnt come with a ethernet port? and you are now adding a PCI device?
Sep 29, 2009 | Dell Dimension 2400 PC Desktop
How to remove the case from my Dell Dimension
there is a lever on the back side on the right[if looking from the back]
it is dark gray and looks like a backwards L shaped lever that you need to push down, then pull back on the side case door
Sep 11, 2009 | Dell Dimension 8300 PC Desktop
Dell Dimension 3000
There is an L shaped lever on the back. Press and hold that down and push side panel of case back. It will lift off. When you put it back on just align the slots on the bottom edge and push forward to close it.
Feb 14, 2009 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Problem
Push the black L shaped lever down on the back of the pc and slide the panel back
Sep 07, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 2400 PC Desktop Logo
1,558 people viewed this question
Alun Cox
