Question about Fujinon Mariner WPC-XL Binocular
Operating manual for fujinon Poseidon binocular
Poseidon model with rangefinder & compass
3 Suggested Answers
SOURCE:
SOURCE: How to use the reticle in my Fujinon Mariner Binoculars?
How to use the reticle:
The vertical scale (reticle) visible through the left half of the binocular, above the compass display, allows you to calculate distance to an object if you know its height, or to calculate the height of an object if you know its distance from you.
Each mark on the vertical scale has a value of 5 MIL (1Mil is equivalent to an angel that can determined an object one meter in height at a distance of 1000 meters). Therefore, if a navigation chart gives the height of an object, by sighting on it and counting the number of MILS, you can determine how far away it is.
To Measuer distance when height is known:
Object Height(m)/Scale Reading x 1000m=Distance in Meters
To Measure height when distance is known:
Distance(m)xScale Reading/1000=Object height in meters
Posted on Mar 31, 2009
SOURCE: Fujinon-Mariner WPC-XL Lens Cap replacement
You can order a replacement set at: http://www.bakermarineusa.com/index.php?id=17&cat=38&prod=137
Posted on Jun 29, 2010
Dust removal inside fujinon techno-stabi binocular
The case has to be opened for this, and a can of compressed air used. There is the risk that the binocs can be knocked out of collimation, so you'd best ask a repair tech for a quote.
Sep 19, 2016 | Fujinon Techno-Stabi Binocular
I need a new compass for tasco 322 BCW waterproof binoculars. Any ideas where I can find one?
Open the battery door, clean all inside with Alcohol & Q-tip. Check that the AG10 or 389 batteries are positive up. Now the compass dial pivots on a shaft. It seems to get caught. Take a strong magnet and rotate it above the compass lying horizontal and spin it until it spins freely. Take it away slowly. Does the compass settle down to accurate heading? If so place back in the top of the model 322BCW observing the glued in marks on the clear window area. Re-screw in, press brass button red LED should light.. If NOT recheck for corrosion. Regards, Don
Jul 03, 2012 | Tasco Optics
Techno stabil 14x40 . yellow light comes on. Green light wont follow. Pwr button will not turn off pwr . of course if gr does not come on no IS
Hi.
The binocular is behavior is the same as when the electronic control module is defective. First try resetting the electronics by pulling out and putting back the AA batteries. The power reset in some occasion may unlock a jammed control module. If you have an external power adapter also test the binocular using the power adapter.
If that does not help the control board must be replaced. Disassembling of optical units is quite delicate and require experience. In that case I suggest contacting Fuji to get support. You can also get a quote on repair from a third party service. Here the online form: Repair Form.
Here some contacts. You will find your local Fujinon contact on the user manual provided with the binocular:
FUJINON INC.
10 HIGH POINT DRIVE, WAYNE, NJ 07470 U.S.A.
TEL:973-633-5600 FAX: 973-694-8299
FUJINON (EUROPE) GmbH
2 HALSKESTRASSE 4, 47877 WILLIcH, GERMANY
TEL: 2159-528545 FAX: 21 59-51 315
See also : Technical Service
Regards.
Ginko
Aug 28, 2011 | Fujinon Techno-Stabi Binocular
7x50 Marine binoclars, Fujinon w/compass. How do you swing the compass to get it to read more acutely? The compass rose, while viewing through the lense, is slightly off kilter (not centered in the view)....
I've been thinking about this for awhile, and it seems to me you're experiencing a factory defect. I don't have one of these devices, or I'd know what "normal" was for compass, but if you can't easily have the display centered, something is out of kilter. Was it always like this, or did it just start occurring recenty? Your best venue would be to contact Fujinon support and see if they will replace or fix the problem. Here is their site:
http://www.fujinon.com/NewsAndEvents/PressReleases/pr.aspx?id=84
Good luck, and hope this helps.
Dec 31, 2010 | Fuji Optics
Ranging reticle in Fujinon FMTRC-SX Binocular
Its easier to explain seeing a diagram. Go to Tascos website and download the instruction manual for the Offshore binoculars or Steiner Optic website and download the general binoculars instruction manual. It has all of Steiners models incuding those with a reticle. Most reticles are the same and there is no difference between meters and yards as your calculations are an approximate.
If your Fujinon is an ex military unit it has what is known as an M22 reticle. It is only slighlty different as it is graduated in mils but the calculations is the same. If it is the M22, google Binocular M22 manual. The military number for this is TM 9-1240-403-12 & P
Mar 22, 2009 | Fujinon Polaris FMTRC-SX (7x50) Binocular
Jan 26, 2009 | Fujinon Mariner WPC-XL Binocular
Rangefinder
Jan 10, 2009 | Optics
Dec 02, 2008 | Fujinon Mariner WPC-XL Binocular
Fujinon Mariner WPC-XL Binocular Logo
71 people viewed this question
Top Fuji Optics Experts
Marvin
Marvin
Geoff White
Geoff White
Are you a Fuji Optic Expert? Answer questions, earn points and help others
