Question about Insignia LCDTV26 26 in. Television
Insignia TV Speakers stop working
Hello everyone ,I have a problem with my 26inch Insignia flat panel TV,the speakers located at the bottom of TV screen stop working ,I mean when the volume is at maximum you barely hear sound from the speakers ,this started about 2 weeks ago before it sounded great ,I do not have a clue why or what to do to fix it ,what are my options on fixing the speakers if possible ,can you please help me to get the speaker working again or how I can connect external speakers .Please ,thank you for any help i can get ,take care and god bless.
David
2 Suggested Answers
  • 814 Answers
SOURCE: Insignia 26 inch Flat Panel Internal Speakers Stop working
You need to test the unit on a external sound source, to see if the audio amplifier is working correctly. By checking it on another source you can determine if the sound amplifier system is failing or you have had some problem with you speakers. Once you determine the problem. If it is the speakers, you can replace them with new ones. However if it is the audio amplifier section failing you will have to take it to a service center where they have all the service information to do the repairs.If the unit is still under warranty, have it serviced by Insignia. You can reach their customer support with this telephone number !-877-467-4289. Give them the model number of your television and the problems you are having with it. The should be able to tell you how to have it serviced. You can also check out their website for customer support at www.insignia-products.com. If the unit is out of warranty, you must have someone help, you troubleshoot the problem and try buying parts for the repair. You can call this number for insignia parts. 1-888-237-8289. You can also search the Best Buy website for parts on these units. The website is www.bestbuy.com. Go to the parts search section and put in the brand name of you television and put in the model number. The search engine will bring up a parts list with prices. I hope this information has helped you with your problem. You should also be aware that Best Buy has had a recall of some these model units. Check my tips and hints postings for more information.
Posted on May 22, 2009
The speakers have stopped working - not a mute issue. Are there replacement speakers or a way to add an external speaker to this tv?
hi yes on the back u have 12 rca sockets the 4 red and white down the bottom a red and a white socket will b marked audio output left & right u can use these to connect speakers but u will need an amplifier ..to boost the sound ...good luck
Aug 29, 2015 | RCA L26HD35D TV
I have a insignia tv and I was playing with the remote and my sound stopped I tried everything the mute the tv volume settings and headphones.
Check its speakers. If found OK, check and replace damaged component/s at its audio output section circuit.
Jun 28, 2013 | Televison & Video
Insignia NS-LB032X-10A we bought from a friend that claimed virtually no use and we have not manual and can't get any sound out of it. Please help if you can. It is a 32 TV &built in DVD year 2009
Do you mean the NS-LBD32X-10A? The manual is available here: http://insigniaproducts.com/products/televisions/NS-LBD32X-10A.html?supportTab=open . The direct link to the manual is http://insigniaproducts.com/cms/documents/NS-LBD32X-10A%20UM%20EN.pdf .
Check if the speakers are muted or if the volume is low. Then go to the Menu and in the Audio submenu go down to Speakers. Make sure that the internal speakers are on.
If the speakers still don't work, they may have failed or the wiring may be damaged. Unfortunately, I do not see any speakers for the TV from my usual vendors.
I hope this helps.
Jun 21, 2011 | Insignia Televison & Video
Our Insignia TV has a vertical line right in the center, and the picture to the right of the line has a "lava lamp" look...sorta cartoon coloring. Looks this way with a DVD or satelite. Suggestions?
Are there any speakers directly beside/above or below the t.v? If so remove them away from the tv. The magnets in the speakers will distort your picture.
Dec 09, 2009 | Insignia IS-LCDTV32 32 in. Television
I have a 42 inch Insignia plasma tv. I only hook
If you have the audio cables hook up correctly to where the video cable from DVD is connected to, it should be RED and WHITE wires for audio. Then go to on screen audio setup menu to see if the speakers is turn off in the menu. Also try hooking up the powered PC speakers to the AUDIO LINE out RCA jacks to see if you get the sound OK there.
Nov 03, 2009 | Insignia 15 in. Flat Panel LCD HDTV
Can't get my laptop speakers to work through headphone jack
the reason for this is that the audio thru this jack is attenuated to a level where you don't loose quality and to prevent ear damage. You better try the audio out or audio monitor output jacks located in the back of the tv(if this model comes with them). you'll probably need an audio amp to get the speakers to work properly though.
Sep 09, 2009 | Insignia LCDTV26 26 in. Television
My insignia 37 inch tv
Press menu and use the up or down arrows to find the audio section adjustments. Press the right arrow and again use the up and down arrows to find tv speakers, Press the right arrow to either turn on tv speaker or turn them off ( This is used only if you are using the output signal from you tv in to you stereo input to have surround sound.) Turn them on to listen to sound from the television speakers only. If this does not solve your problem, Press the mute button on you remote control to release the mute function. If all this does not work the telephone number for Insignia is 1-877-467-4289. Talk to them about you problem and see if your television needs some type of service to restore the sound. Hope This helps you with your problem.
Mar 19, 2009 | Insignia 37" LCD Flat-Panel HDTV
Feb 28, 2009 | Insignia LCDTV26 26 in. Television
Insignia LCD 26 inch
sum tvs cant take it this is a cheaper model try adjust bass and settinsg in the tv suround mode ect 3d mode adjust treble down
Dec 27, 2007 | Insignia IS-LCDTV32 32 in. Television
Insignia LCDTV26 26 in. Television Logo
459 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
