Question about Xerox Office Equipment & Supplies
My copier ( xerox xc1040 ) hit a power surge . It
My copier ( xerox xc1040 ) hit a power surge . It flashes H4 and will not let me do anything else. Nothing what so ever . how do I fix the problem.
  • visn0955 Mar 04, 2009
    Thank you for the advise . the solution did not work .
    None of the buttons will activate no matter what . I have tried everything from unplugging to taking out the cartriage still it will not reboot. ( whats Next ) .
    Problem Solver:
  • 12 Answers
I speak a littlebeat english.
H4
00
Low Temp
you cant erease this code
in panel control
press (clear ) (exposure select key) (clear) (exposure select key) (14) & (start key)
14: Resets H3, H4,
Posted on Mar 01, 2009
  • 3 Answers
I've seen this problem b4 in the field. I think to reset this code is:
press these buttons in sequence...clear, auto, clear, auto, 1,4, stop. If it doesnt clear then there may be problem with the fuser unit ( i.e. burnt out fuser lamp and or terminals) or the thermistor.
Posted on Mar 14, 2009
I have a xerox xc1040 copier. The paper jam light is stuck on (it is the red light in the center of the display). I have gone through the entire sequence of recommended steps in the Xerox PDF files for...
Sounds more like the drum life chip has expired. Either replace the drum unit or the chip .
I can't remember if the xc1040 has a chip, or if its the one with the gears on front that has to drop a flag in order to reset the drum count.
Either way, I believe replacing the drum unit is the solution to your problem.
Dec 13, 2010 | Office Equipment & Supplies
Tip
Xerox XC and XD series copier H3 or H4 error code reset procedure
To reset the H3 or H4 condition on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This procedure will work on all Xerox XD and XC models.
on Mar 20, 2010 | Office Equipment & Supplies
I have a very old, but working, copier Xerox XC1040. It is blinking "H." What do I need to do?
To reset the H3 or H4 condition on your Xerox XC1040 copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
If this solution works for you then please leave a positive feedback and testimonial for me.
Thanks,
WheatlandServices
Oct 15, 2010 | Xerox Office Equipment & Supplies
Xerox XC1040 that keeps jamming
sounds like the fixing unit needs to be replaced, give a call to any copier dealer that services lexmark and see what it'll cost for a replacement fuser, with that info you'll be able to tell if you want to fix or trash it.
Apr 13, 2010 | Office Equipment & Supplies
Xerox model # XC1040 flashes H4 when turned on will not make copies ? code
H4 is a fuser error code. it basically means that the fuser is heating up. from what i can see the fuser lamp alone will be about $60.00. that would be the best case scenario if the rest of the fuser parts are ok. the upper fuser roller is 135.00 and lower 144.00.
Oct 16, 2009 | Xerox Office Equipment & Supplies
I have a Xerox xc1040 that works fine most fo the
Yes these problm occurs frequently xc1040 . you ned to adjust the paper tray properly. then shake the bunch of papers so that the paper which are sticked are freed.
Jun 16, 2009 | Office Equipment & Supplies
Paper jam on Xerox XC1040
Sounds like the fuser gear (the long rollers where the paper exits that get hot) is broken. It is on the upper roller. Precision roller.com sells this gear.
Mar 12, 2009 | Xerox Office Equipment & Supplies
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox Copier problem
Turn power on and within 4 sec.press the following sequence;clear,exposure,clear,exposure.The screen will go blank.Enter '1' and '4' then hit print.turn off. This will reset H4 if the fuser has no problems such as a bad fuser lamp or thermal fuse.And yes it,s worth fixing with the right guy working on it!
Jun 30, 2008 | Xerox Office Equipment & Supplies
H4 Problem
Hi there, if you want to clear this code its very simple, do the following: -on your control panel locate the clear and auto exposure buttons, next -hit in the following sequence clear, auto, clear, auto without holding them down, after that all your panel lights should go out. If they do not you have to keep trying...They will go out. -Next program the machine as if your going to make 14 copies -Once 14 is displayed, hit the green start button and your copier should be working again. Cheers! :)
Sep 11, 2006 | Xerox WorkCentre XE88 Laser Printer
623 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
