Question about Bose QuietComfort 2 Consumer Headphones
No Sound/No Power
I have a Bose headset Model OC2. I removed a dead AAA battery which was somewhat corroded on the positive terminal. I had not used the headset for 2 or 3 years. Replacing the battery does not get me power or sound. There is no visible damage to the battery compartment. The contacts seem to be ok, but how do I clean them just in case corrosion is the problem. If cleaning doesn't work, what then?
  • 158 Answers
Hello, I see you have a set of headphones that are inoperative. You can take a peice of aluminum foil the heavy duty type and scrub the contacts to clean the terminals.If you have a figernail emery board that will work also. If that doesnt work you will either have a wire corroded into also and you will have to take apart, or either take to a local small radio repair shop and let them repair the wire.Thank you
Posted on Feb 28, 2009
  • 10,594 Answers
Sand paper of file are best to clean battery terminals metal.
Make sure that leakage of battery has not reached to circuit board of headset.
    Scholar:
  • 85 Answers
Try cleaning with the isoprophyll alcohol available at local medical stores.and use tissue for cleaning.
  • 13,433 Answers
Hey, you need to clean the contacts, you can use almost anything todo this.
  • Ekse Feb 28, 2009
    use the end of a pencil, the eraser end, or vinegar remember to dry it.
Why does the myzone headset we purchased not work, as the red light will not turn on?
Not sure how old this unit is but you need to check your battery connections for crud.
If the battery's have been leaking or the terminals are corroded it will not power up. I beleave that unit takes rechargeable batterys.
May 15, 2014 | Lands Phones
2008 Tahoe has no power at all lights, engine, bells all dead
First step check the battery and the connections , chevrolet has a common problem with the negative battery terminal getting corroded. Remove the negative terminal and inspect the metal lead in the cable , clean and repair as necessary, with the negative cable removed perform the same inspection on the positive cable. If issue still persists further troubleshooting will be required.
Oct 14, 2013 | 2008 Chevrolet Tahoe
Car won't start, Ford Expedition, clicking noise
if the car will jump off doesn't matter what AAA said battery is bad, either terminals are excessively corroded, or battery has a dead cell internally, remove battery and take to a reputable auto parts store or repair shop and have tested, also have load tested it is bad.
Apr 18, 2013 | Ford Cars & Trucks
I need replacement batteies for my sony headphones and can not find them
My headphones (after several years) got to where they would go dead in about 1/2 hour. I used Panasonic AAA H8 Ni-MH 630 mAh. They last longer and get much louder than the stock batteries. I was able to remove the old batteries without breaking the holder. They work better than new.
Jul 15, 2011 | Sony MDR-RF960RK Consumer Headset
Tractor engine clicks but will not start need a solution
hopefull your battery is just dead a new battery should fix that problem you can try charge the battery may be okay depending on how long it has sat without bein used.... otehrwise it mat be your starter solinoid it ts the block with 2 poles on it that your positive battery cable goes to, it will most likely be a dead battery tho...
Regards
Brad:)
Sep 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Starter button doesn't work. can't be pushed down so grill won't start. do I need a battery for this part?
When the igniters stop working the backs are corroded. Clean well and reinstall or replace altogether. In the meantime you can use long fireplace matches to light the burner until you are ready to effect repairs.
Apr 26, 2009 | Weber Genesis E-320 Propane Grill
RCA headphones - nicad or alkaline batteries WHP141
BATTERY INSTALLATION AND INFORMATION
Your wireless headphone unit requires two rechargeable AAA batteries.
Rechargeable batteries are uncharged when you purchase them. Before
you can use the wireless headphones, the batteries must be charged for
16 hours. Follow these steps to install and charge the batteries.
Installing the Rechargeable Batteries
Take care to follow these steps to correctly install the batteries.
1. On the right headphone, locate the battery compartment (1).
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
2. Insert two AAA rechargeable batteries, carefully following the
markings inside to ensure the batteries are inserted properly, with
the + and - ends in the correct positions.
3. Replace the battery compartment cover.
Charging the Rechargeable Batteries
To recharge the headset unit, follow the directions below. Note: The
cradle/transmitter on the WHP141 is not a recharging cradle, although
you may place the headset in the cradle during recharging.
Follow these steps to recharge the NiMH rechargeable batteries.
1. Make sure the ON/OFF switch (2), located on the right headphone,
is in the OFF position.
2. Connect the AC/DC main power adapter to the DC IN power
supply socket (11), located on the back of the cradle/transmitter.
3. Plug the adapter into an electrical outlet.
4. Connect the charging cable (10), located on the back of the
cradle/transmitter to the recharging input (3), located on the right
headphone. The headphones can either be placed in the
cradle/transmitter or placed next to the unit. If the headphones are
connected correctly, the charging LED indicator light on the
cradle/transmitter (8) illuminate.
Mar 27, 2009 | RCA WHP141 Consumer Headphones
No Sound/No Power
I used your site to research the problem further. I found an answer which recommended rubbing the suspect terminal lightly with a pencil eraser. It worked! I now have battery power and my headset works fine.
Nov 30, 2008 | Bose QuietComfort 2 Consumer Headphones
Bose QuietComfort 2 Consumer Headphones Logo
195 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
