Question about IBM ThinkPad 600E 2645 Notebook
IBM ThinkPad 600 Hdd error
I had problems with my IBM cmos battery, I replaced it and right now, when I checked My hdd in bios utility, there's an errors DEV 017 ERR 22 FRU 6010 what can I do? I hope that someone could help me... Raitis.
    Problem Solver:
  • 18 Answers
Make sure the Hdd is well connected , and hope its not an HDD failure. Might also want to check see if you didn't disconnect any other wires by changing the battery.
Posted on Feb 28, 2009
What is the problem when uyou switch on the IBM
You probably need to replace the BIOS battery. This battery is small and on the inside of the laptop connected to the motherboard. It stores the BIOS settings, date and time. If this battery becomes worn out then it will cause your issue. First try and press F1. Navigate to the last tab and select to restore defaults, then save and exit. If the computer boots up fine but the next time you use it the same message appears then you need a new BIOS battery. Alternatively your HDD may be damaged if it cannot find a boot device. Check your HDD is recognised on the boot menu by pressing F12, select it and press enter and your OS should boot. Hope this helps,
www.PuterCare.com
Jul 23, 2010 | IBM ThinkPad T20 2647 Notebook
Ibm thinkpad r60 hard drive not recognized by
make sure your operating system having a sata drivers,if u r using sata HDD,try to install vista or 7 it show HDD but if you run XP it not detect HDD because XP dont have sata drivers,or burn XP using Nlight software add sata drivers in that
Nov 14, 2009 | IBM ThinkPad R60 Notebook
ThinkPad 600 System Board error
Have you tried using the reset jumper on the motherboard? I had a PC a few months ago that I had to replace the battery in. I eventually had to use the clear CMOS jumper and the reset BIOS jumper to get the computer to load to BIOS normally. Remember, if you don't have to correct the date and time, then the BIOS has not been reset. Sometimes it is a good idea to leave the PC off and unplugged for about 10-15 minutes to let the capacitors drain down. By doing this after reseting the PC, it gives you a clean cold boot (meaning there is nothing stored and nothing has had power before a reboot).
Nov 10, 2009 | IBM (30L2872) for ThinkPad 600E 2645-55x...
IBM Thinkpad will not hold date & time.
Replace the backup battery and run BIOS Setup Utility to reset the time and date. This will resolve the issue.
Sep 15, 2009 | IBM ThinkPad T22 2647 Notebook
BIOS self-set Password after upgrade/HD Install
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
try this if you can do  but i am not sure.  i am good on electronic things but its hard to do that. its only way.
May 28, 2009 | IBM ThinkPad T43 Notebook
Starting ibm 600e
Hi there.
Errors 161, 192, 163.
All three of these errors are connected to the back up battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips screwdriver required)
2. find the small connector with 1 black & 1 red wire coming from it.
3. disconnect above connector and gently pull the Red&black wires. The backup battery should just pull out from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot welded so need to be cut/broken off). Buy a new CR2025 battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
Solder the leads onto the new battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows 161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off switch at side.
Good luck and thanks for using FixYa!!
Mar 05, 2009 | IBM ThinkPad T21 Notebook
Bios lock, ERROR CODE 0271
Error code 0271 - Date and time error. Neither the date nor the time is set in the computer.
Run BIOS Setup Utility to reset the time and date
It sounds as though your computer has the wrong time in the CMOS. The CMOS (Complementary Metal-Oxide Semiconductors) is the chip that holds the basic startup information for the BIOS, system and its peripherals while the system is turned on and off.
If you can get into the BIOS check the date and time settings and make sure they are correct.
It may also be a case of the CMOS battery going out. When this happens your computer will tend to not keep the correct time. They are cheap and relatively easy to replace. Before buying a new batter your can try to take it out and let it sit for about 10 minutes or so to reset the CMOS and then go put the battery back in and go into the BIOS and reset the clock.
Hopefully taking the batter out or replacing it will get past your lock icon asking for the password. Just search for CMOS or BIOS default password for your brand of laptop.
Feb 03, 2009 | IBM ThinkPad R52 Notebook
IRe: IBM 600E
Hi, sorry I was out last night.
Errors 00161/00163/00173 mean you need to replace the CMOS/BIOS battery and update the time, date etc, like you did.. and Error 00301 means a keyboard error. Just press CtrlAltDel past this.. or try using an external PS-2 keyboard..
So, when you startup and then get to the errors, just press CtrlAltDel to restart, then tap F1 to enter the Advanced Settings and try to load Windows in Safe Mode, and let it do a Scan Disk.
It's possible that the machine won't be able to load any hardware drivers for the machine because the CMOS information might have been corrupted due to the flat battery, but try and boot into Safe Mode anyway and see how you get on.
This is a really old machine but still has driver and troubleshooting support at the Lenovo website, and it might be fun and interesting to resurrect..
Hardware Maintance Manual - June 1999: ThinkPad 600, 600E
On pages 109 and 115of the attached pdf file (actual pages 103 and 109), the Li-Ion batterypack part number should read 12P4064 replaces 02K7018.
c.gif Battery test utility diskette - ThinkPad 600/E/X
BIOS Update (Diskette) - ThinkPad 600
PCMCIA SelectaDock I/II driver for Windows 95/98 - ThinkPad 600, 770
c.gif Windows 98 installation supplement files - ThinkPad 600, 760, 765, 770
This is the Setup Guide for the thinkpad 600.
Of course, it may very well load Windows fine after a new battery and a scandisk and you'll find it has Windows 2000 on it, so maybe I'm jumping the gun with the Win98 stuff there, but let me kow how you get on..
Chris (ziraffa)
Oh by the way, if we are going to be using a different Solution thread this time, can you go back to the other page and rate it as Fixya! so that they can take it off the system? It saves the unrated pages filling up the servers..
Jan 17, 2009 | IBM ThinkPad 600E 2645 Notebook
Boot problem thinkpad r50e
Your PC may be doing a complete memory check, this does take time although your 1 minute boot time might make some of us jealous.
Check your BIOS settings to see if you have a 'Fast Boot' option. If it does, make sure you are using it. It then will make only a cursory check of memory and it is probably OK otherwise you would have other symptoms that would let you know.
Dec 31, 2008 | IBM ThinkPad T40 2379 Notebook
I forgot my bios password
Laptops often do not have a dedicated CMOS battery, but use a hardwired device which you have to unsolder and solder back.
You don't want to do that without some decent experience.
There are two basic kinds of passwords that will be prompted for by the IBM BIOS, computer and HDD. (You can tell the difference by the icon prompt).
If this is a HDD password, there are no options for recovery in the US. Federal laws prohibit possession of the software to access the secure portion of the disk. The computer passwords are also not able to be cleared locally.
The unit can be sent to an IBM's maintenance and support center and they will either clear the PW or in some cases replace the planar. If you just purchased the laptop, contact the previous owner for the passwords. If not, then sending it in for maintenance is your best bet.
Sep 26, 2008 | IBM ThinkPad R40 2681
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
192 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
