Question about Kenmore Dryers
My electric Kenmore Dryer (65291) does not get hot anymore
My dryer used to get hot but now it doesn't have any heat.
  • 686 Answers
Does it still start? if so you may need a ne heat element?
Posted on Mar 01, 2009
Kenmore dryer MOD# 110.61402310, Dryer heats up and is SUPER hot. Clothes are to hot to take out after. Seems like timer is messed up because it will run until you open the door. Only has one heat set
OVER HEATING HAPPENS ONLY IN ELECTRIC DRYERS NOT GAS DRYERS.... HERE IS A VIDEO FOR HELP ON THIS..
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Oct 28, 2014 | Dryers
My dryer is getting so hot that it is shutting itself off mid cycle. I can restart but it only runs a short time....gets really hot and shuts off again!!
Check your entire vent tubing from the outside vent to the line coming out of the back of the dryer.
Overheating indicates low air discharge flow. The air in the dryer must move out quickly so the heat doesn't build up too much.
Try that & post back.
Gary
Sep 15, 2011 | Kenmore 600 6965 Electric Dryer
Dryer spins but doesn't get hot. Model #11077522600
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 09, 2011 | Kenmore 73952 Gas Dryer
KENMORE ELECTRIC DRYER WILL NOT GET HOT ANYMORE
heatman101
Aug 30, 2011 | Kenmore Dryers
Kenmore Dryer does not dry anymore
heatman101;
Jul 22, 2011 | Kenmore Dryers
Dryer turn on, heats up but doesn't get hot
I just had the same problem with my electric dryer. Check your exhaust vent (dirty/clogged). I have seen brushes designed for cleaning the vents at many hardware stores. I replaced mine because it was pretty bad (it's was over 10yrs old). Hope this helps.
Jun 14, 2009 | Kenmore Dryers
Kenmore dryer 400series electric not gettin hot enough to dry
you might have a open heating element. ohm out your heating elements.
Feb 20, 2009 | Kenmore 62602 Electric Dryer
Dryer doesn t get hot
it is going to be either the igniter for the gas or the heating element
you probably have an electric igniter. it is not igniting the gas to make the dryer heat i would definantly start with that
Jan 07, 2009 | Kenmore Dryers
Dryer doesnt dry clothes
If your kenmore electric dryer is not heating anymore, the problem can be with the element, with the thermal fuse, or rarely with the control timer , see below from repairclinic: What is wrong with your Dryer?
Oct 15, 2008 | Zanussi TC180W Electric Portable Dryer
Dryers Logo
97 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
