Question about ViewSonic KU709 (E77030) Keyboard
I have been using a viewsonic keyboard ku709 with a 3m joystick mouse plugged in the left usb port. 3-4 times a day, I get a stall accompanied with a chime (ding-dong) and then both keyboard and mouse become unusable for a 5-10 seconds, then another chime is heard and the become available again. Not a show stopper but a definite annoyance, especially that I love both of them.
  • ypixel Feb 28, 2009
    My system is a Dell latitude E6500, with XP pro SP3
  • 479 Answers
Please refix your IR receiver and then use your k/b and mouse this connectivity issue is common with the IR ports keep the batteries changed as the joystick is embeded on the kb
Posted on Feb 28, 2009
    Sergeant:
  • 326 Answers
Its just the connection issue faced by many of the customers .in this case unplugging the connection and checking it in another ports solves the problem as the port in which the devices are connected are got loose internally.
  • ViewSonic Master
  • 19,396 Answers
That can be because of a bad ir sensor, check the main receiver connected to the USB is not behind objets, and that surface is not dirty.
If problem persists, it may be time to get a new keyboard.
  • ViewSonic Master
  • 13,433 Answers
Seems like the usb devices are disconnected and then reconnected try another set of usb ports for them or if your using a hub connect them directly to the back of your computer, check that the cables are ok and they are not cut, you can test this by waveing the cables around and see if you start hearing ding dong that means the cable is cut at somepoint.
    Sniper:
  • 113 Answers
HI there,
 i thinks there is some problem with the USB port
neo
HOW TO ACTIVATE CORDED MOUSE
I understand that you don't need to "activate" USB mouse. Turn off your computer., plug in a USB port and turn your computer on. I just don't know it it is compatible with USB3.0 Just some days ago I conected a Microsoft USB mouse to my USB 3.0 port and it didn't wor so reconnected it to USB2.0. Port USB3.0 is 100% ok!
Microsoft SideWinder Mouse Mouse laser 5 button wired USB OEM pack of 3...
Apr 18, 2015 | Microsoft SideWinder Mouse - Mouse - laser...
My computer is unresponsive to the joystick; I plugged it into the usb port a message confirmed it was installed and ready for use but nothing happens when I move the joystick in a flight simulator or...
Hello, Here's the solution to your problem, you have to configure the games you're playing for the joystick to work, I believe all games have this option, ussualy in the "configure keyboard and mouse" options menu, click on any funcion you want your joystick to use for each button, and then press the button you want for that function, do that with all buttons of the joystick you want to use, some games need the joystick axis to be configured, just click on left/right and move your joystick in the desired direction, same procedure to up/down, if your joystick has a throttle wheel, do the same for it (if needed).
Procedure is simple and most games has small variants of this procedures I gave you, but they are simple to figure out.
Hope my solution helps, have a nice day :)
Apr 14, 2011 | Trust Predator TH 400 (12629) Joystick
Brought a CS62US and Mircosoft KB with mouse. When USB combo plugged on the left USB, only KB is worked together with switching function. When USB combo plugged on the rigth USB, both KB & Mouse worked...
Unfortunately, this switch has a dedicated port for keyboard that listens for the keyboard keystroke. You MUST plug the keyboard into the dedicated keyboard port on the KVM switch for the hotkeys to work. I recommend putting the mouse that comes with your keyboard to the side, and using another mouse, plugged into the dedicated mouse USB port on the switch. Not the prettiest solution, but some of those mouse/keyboard combos have some funky hardware!
Feb 17, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
How can I install if I havent got a Cd or any other files? I just got the joystick only, and my computer cant see the USB port including the joystick... wot now?
There should be no driver needed for this under WinXP/Vista
First, make sure that the USB port you're using works -- plug in a different USB thing into that port, even just a mouse, and confirm that the computer sees the device and it works.
You can also try plugging the joystick into a different USB port on the same computer, or take it to a different computer to see if it works there.
If this helps, please be sure to hit the "thumbs-up" for me.
If not, use "add comment" to tell me what you find from your troubleshooting, and I'll try to get it worked out for you.
Jan 09, 2010 | Trust Predator TH 400 (12629) Joystick
My wireless mouse will not work, I forget how to 're'-pair it. It was functioning normally before i left home for a couple of days. Both the mouse and the other part (that goes into the usb port) are...
1. Try unplugging usb device and replugging in (I'm sure you already did that) LOL
2. Uninstall device driver
3. After uninstall plug in USB device
see if that works
Nov 14, 2009 | BenQ M310 Wireless Mini Optical Mouse
PS2 keyboard mouse not functioning
First look usb or pst driver is stall or not. if install your port may be damage or shourt. then check usinge y- cable. where one side usb port and another side we get ps2and usb. then we use mouse and key board once atime.. . ithink u solvev your problem. if not .there is another way . you can add usb card in *********** bord . Which help you to operate usb key board and mouse once time. thanks
Jun 17, 2009 | Acer Aspire™ T180 PC Desktop
Optical mouse
Yes you may use your regular keyboard if it plugs into the keyboard port the the wireless mouse plug into a usb port.
Depending on how the wireless mouse/keyboard reciever plugs into your computer. it's either it splits into one keyboard plug and one mouse plug OR just on usb plug.
Mar 01, 2009 | Compaq Wireless Keyboard/Mouse p5304
Keyboard want light up but mouse works
The buttons on the top (silver) are linked to your "Favorites" folder in Internet Explorer.
The buttons to the right of that are used for your media player (To skip tracks and adjust volumes, play pause etc)
The buttons on the left (from top to bottom) are:
1) My documents folder will open
2) MSN or Windows Live! Messenger will open
3) Your E-Mail will open (whatever your default email program is)
4) Calculator Opens
5) Windows Update will open
Now... In order for these you HAVE to have the drivers installed. If you didn't get a CD with your keyboard, you can download the drivers directly from Microsoft here:
http://www.microsoft.com/hardware/download/download.aspx?category=MK
Just fill in the drop-downs and press "Go", it should show you a link the the exact driver you need to install. Once it's been installed you can set up your favorites with the software that it installs.
Oct 24, 2008 | Microsoft Wireless Optical Desktop Comfort...
MS optical desktop 700
try one of the method below:
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
To determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
uparrow.gifBack to the top
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Method 4: Install the latest software loadTOCNode(2, 'moreinformation'); If you are troubleshooting a wireless mouse, download and install the latest Microsoft IntelliPoint software. For more information about IntelliPoint software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) If you are troubleshooting a wireless keyboard, download and install the latest Microsoft IntelliType software. For more information about IntelliType software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) uparrow.gifBack to the top
Method 5: Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Sep 18, 2008 | Microsoft Wireless Optical Desktop Comfort...
Wireless keyboard
wireless keyboards and in wireless mouse devices, use the following methods in the order that they appear in.
Mar 02, 2008 | Sakar 62150 Keyboard
ViewSonic KU709 (E77030) Keyboard Logo
19 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
