Question about Avid Juicy Ultimate Hydraulic Disc Brake , 160mm, Front
Front Brake pad Replacement 2007 1500 Suburban 4x4
Hello out there, I need a little help ( Info ) on replacing front pads on 07 suburban. I HAVE DONE A FEW BRAKE JOBS IN MY LIFE, BUT NOT ON A LATE MODEL SUBURBAN. I would like to find a step by step illustrationon how to to this. I just need to know any of the unforeseen issues!!! I would guess that this is a pretty strait forword job. I'm trying to keep some of my cask on my Dinner table not the dealership's. Do ya know what I mean. ( Unless you happen to work for one of the dealerships... not trying to take food off your table eather) THANKS
  • 58 Answers
If you have done any brake work before you can do this to. Its just a standard disc brake system, remove the caliper, compress the piston back, toss on some new pads and a new rotor and put it all back together. Usually on the newer vehicles they have squeakers, at least thats what a lot of guys call them, its the little anti chatter shims for the pads, if the pad kit comes with them then you have them, if not then don't worry about it. Other then that usually a little lube on the bolts that the calipers float on. Its a easy wrench job. I was hesitant getting into the brakes on my newer vehicles also, but after doing it once i don't have any worries about doing it again. Grab a wrench and a beer and dig in!
Posted on May 04, 2017
2 Suggested Answers
  • 30 Answers
SOURCE: 2007 Suburban front pad replacement
Posted on Jul 26, 2009
2003 Chevy suburban replaced front rotors and
you need to take the calipers off and make sure the caliper bolt are free of rust, dirt, and debris inside the boot and caliper bolt hole the caliper slides on these bolts so that both brake pads can wear equally. I suggest antiseize on a clean bolt. A small amount of grease will work, be careful this does not get on the pads or rotor.
Sep 15, 2014 | 2003 Chevrolet Suburban
1995 suburban the whole truck shakes when i apply the brakes and the pedal seems to pulse as it slows to a stop. I have changed the front pads calipers and rotors. no change ?
Now, did the mechanic even suggested anything about MACHiNiNG ur ROTOR brake disc before putting those brake pads? U got UNEVEN brake disc and needs MACHiNiNG to equally level the pads grip to the rotor! Do it i'm very sure of it! Taaah!
Nov 09, 2010 | 1995 Chevrolet Suburban
1997 suburban C1500. I replaced the Front pads
You will have to check each brake caliper for pressure when the brake pedal is applied. You may have a sticking piston in one of the brake calipers.
This will cause a spongy pedal.
Hope this helps,let me know how you get on.
Jul 01, 2010 | 1997 GMC Suburban
Front wheel heating up, just replaced pads rotor, caliper,outer wheel bearing, and still gets hot.
You may need to replace the flexible brake line going to the caliper. One little spec of rust or dirt will restrict the brake fluid from returning to the master cylinder which will keep the caliper depressed
Jul 10, 2009 | 1995 GMC Suburban
2006 dodge ram 2500 4x4 diesel replace brake pads front and back
Straight forward job. Remove wheels, remove 2 caliper bolts per wheel, check bolts,and bushings for wear/corrosion and lubricate, remove calipers, remove brake pads, push caliper pistons into calipers, replace anti-rattle clips, put new pads in, put caliper and bolts in, put wheels on. Start truck and press brake pedal several times to take up slack and you're done.
Apr 25, 2009 | 2004 Dodge Ram 2500
Unlike the front pads where you only have to push the caliper piston in to replace the pads,the rear caliper pistons have to be turned clockwise to screw them back in.Hint: only go as far as nessesary to get the pads to clear the rotor as this is also the adjustment for the emergency brake.Good luck,
Mar 25, 2009 | 1997 Chevrolet Suburban
Front brakes waering out excessively
1. Check your front rotors for being silk smooth
2. Take your truck to a lightly dusty area where you can force a slide without leaving marks and see if your rear brakes are working at all
3. Check fluid level in your mater cylinder for improper levels
4. Anything me
Jan 07, 2009 | 1997 Chevrolet Suburban
2001 Chevrolet 1500 Suburban Brakes/Front makes funny noise
if this started happening after the brake replacement then the isses seem to be with the installation. get it checked.
Dec 24, 2008 | 1999 Chevrolet Suburban
My first brake job
I am assuming you have front disc and rear shoes? The front pads are just about as simple as it gets. Two 3/8 allen bolts to take off, one simple piston to push back in and replace pads. (this is assuming you are not metal to metal and the rotors do not need to be turned. The rear should be shoes and just follow the same procedure in reverse after taking them off. BTW remember the larger brake shoe goes towards the back of the vehicle.
Nov 01, 2008 | 1988 Chevrolet Suburban
Avid Juicy Ultimate Hydraulic Disc Brake , 160mm, Front Logo
1,071 people viewed this question
Top Avid Cycling Experts
Michial Gueffroy
John Egan
John Egan
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
Are you an Avid Cycling Expert? Answer questions, earn points and help others
