Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Bravia headphone jack problem
My Sony Bravia tv does noy play sound as it is turned off because it detects that headphones are plugged in but there is nothing plugged into this socket.
I tried plugging and unplugging headphones in but to no avail.
The sound does work through the headphones.
Is there some way of fixing this through the setup options menu. I have tried but the cure must be obscure or non-existent.
5 Suggested Answers
SOURCE: problem using headphones 3.5mm output with Sony Bravia tv
Just mute the TV and you will get sound out of your headphones. You may have to turn the TV sound up though.
Posted on Nov 18, 2009
  • 5 Answers
SOURCE: Sony Bravia 40
go to your remote contol ( menu )
then you go to the option set up.
then you go to headphones and you can set the volume louder.
You will see that it works fine.
Greetings from Holland Gesinus
Posted on Aug 15, 2010
  • 1274 Answers
SOURCE: When i plug headphone jack
Hi mowl, my name is John. Welcome to FixYa. Make sure that your are putting the right headphone jack into the jack plug. Some plugs are different than others. Look at the manual and it will tell you what kind you need. Don,t have a manual, you can download it here, its free. www.manualsonline.com . You will need your make and model. Thanks for choosing FixYa......John
Posted on Dec 07, 2010
  • 8457 Answers
SOURCE: Sony Bravia KDL-40V3000 - sound
Go into the tv menu go into the AUDIO setting,go down to do a resetting for a back to the factory setting.Now go to OPTION setting go down Output Select and enter and pick Fixed for speakers for the tv option,now tv will play on the tv speakers
Posted on May 12, 2011
I can't get sound through my headphones on my Bravia kdl-52xbr5 tv. First time I have tried to hook up the headphones which are sharper image wireless
I take it the headphones are charged up and known to be in good working order? Are you using the 3.5mm headphone jack on the side of the TV or the white and red RCA jacks labeled AUDIO OUT (VAR/FIX)? If using the headphone jack the TV should shut off the internal speakers and output to the headphones. If using the mentioned RCA jacks you need to go into the audio options settings and set to Audio System. Also under audio settings, Audio Out, you can pick Fixed or Variable. If you opt for Fixed you will use the headphones to adjust the volume. If you opt for Variable you can control the headphone volume and muting using your TV remote control. Just make sure you have the headphone volume turned up adequately.
Dec 16, 2016 | Sony KDL-52XBR5 52 in. LCD HDTV
Sony Bravia tv, can't get sound out of wireless headphones with base station plugged in
Check the Volume on the TV, the audio jack is tied to the TV volume control.
Jan 09, 2016 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sennheiser RS 120 headphones won't work, only hear static
Adjust the tuning wheel on the side of the headphones so it picks it up.
Mar 20, 2014 | Sennheiser RS 120 Consumer Headphones
Sony Bravia KDL-46Z4100 46 in. LCD HDTV TV does
Probably its not a problem. On the menu You should have a Headphone audio level control (when needed you can mute the set speakers and still have headphone audio).
Oct 10, 2013 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
How do i connect my soni bravia television to internet
Hook up a computer to it. The tv could have an hdmi connector or monitor connector (check the back of the television to see which type of connectors you have available) so just plug a cable in from your pc to the tv.
For sound, a simple computer cable plugs into the headphone jack of the computer to the back of the television. If you have a PC, you may have a series of connectors for stereo surround sound systems (like a sound card). I use a simple jack that plugs into the headphone jack (stereo speaker jack) and also plugs into the pc audio in port on the tv. Now I just select the input (pc) from the sony menu and select the option for sound input and voila. As long as the pc is connected to the internet, your tv is your new monitor.
Feb 23, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL-40V3000 - sound is directed to the headphone jack and not the speakers. Cannot get it to play to the speakers.
May 12, 2011 | Sony BRAVIA KDL-40V3000 Television
Can't find where to plug my headphones to the Bravia tv
If you look closely in the area where your audio outputs are (red and white holes) you will see a headphone jack a 3.5mm minijack hole.
Jan 28, 2011 | Sony Bravia KDL-32V4000 32 in. LCD TV
Sony Bravia 40" LCD, not getting any audio out of the headphone jack. Have tried different types of headphones. When I plug my headphones in to the side headphone jack I'm not getting any sound. The tv...
Jan 14, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Problem using headphones 3.5mm output with Sony Bravia tv
Sep 09, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
Where do I find the place to connect headphones on the bravia xbr
Try this: face the television; Left hand side on the edge; Look for the green input port (top hole); plug in headphone jack; should work
Dec 22, 2008 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
877 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
