Question about Maytag MDG21PD Electric Commercial Dryer
MCG8000AWW Neptune Drying Center initially has heat, then not
MCG8000AWW Neptune Drying Center initially has heat, then no heat after a few minutes (maybe five or less). I have already disconnected the vent and verified that the problem is before there. Any most-likely suspects in the component area? Pointers to any Neptune Drying Center tear-down instructions? I googled with mixed results - this site being one - ha ha. Any input greatly appreciated. Have a great day!
  • krosenfield Mar 03, 2009
    I have lost all heat in my mcg8000aww. The first thing I did was to clean out the vent. Then, I found a huge amount of lint build up down the front chute of the lint screen holder. You cannot get to that until you remove the front of the machine. I have the one with the upper dryer cabinet, so for me, the front removal required removal of the control panel (4 screws) then removal of four front screws (previously hidden, then disconnect the door wires and then the front lays open, remove the plastic lint box and there was a huge pile of lint. But, once done, that did not solve the heat. I am moving on to the "coil" but have not yet figured it out. Any help?
Hey u burned the ingniter with all that lint, so just buy it around $100 , replace it and back in business.
Posted on Sep 28, 2009
No power to maytag neptune drying center mcg8000aww
Sounds like the thermal fuse is open, which generally means the vent is clogged
Aug 31, 2014 | Maytag Neptune MCG8000AW Gas Dryer
Maytag neptune drying center has no power mcg8000aww
Could be a bad thermal fuse, a bad drum belt, a door switch a loose wire , one of the computer boards or the user interphase. Time to call a qualified technician. This machine is a complex machine to disassemble and diagnose and if reassembled wrong could prove to be dangerous to operate.
My matag dryer #mcg8000aww heats and then after a few minutes stops heating
you high / low temp thermostat is going bad need to replace it. or your vent is clogged and it is over heating. and shutting down to prevent a fire.
Aug 21, 2014 | Dryers
Im trying to gain access to the drying center by maytag, mdl mcg8000aww. i am having trouble getting in to check the components
This not a solution, just a statement that the only way in seems to be via the front with removing everything! There is a link in here to a Service manual that shows (poorly) different stages of a tear down. I think my washer not spinning out the clothes properyly has cause what every it is to break. Lots of good info on how to test the ignitor, but how to get it out is another matter. Did you have to call a tech?
Apr 01, 2011 | Maytag Neptune MCG8000AW Gas Dryer
My Neptune MCG8000AWW Dryer isnt heating up. How do I get to the ignitor??? Does the front come off or is it through the back of the unit.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Aug 24, 2010 | Maytag Neptune MCG8000AW Gas Dryer
I have the Maytag MCG8000AWW gas "drying center", it tumbles but does not have any heat. The burner lights when the cycle is started, and for a few minutes it does heat. Then the humidity indicator changes...
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric Dryer won t Heat
May 06, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Maytag MCG8000AWW gas dryer no heat
The ignitor may be bad you can chek to see if there is 110volts when the dryer is allin by unplugging the wire to the ignitor and putting using a multimeter to chek for voltage at the wires. If there is power to the ignitor and the ignitor is not glowing up then the ignitor is probably bad replace the ignitor.
Jan 12, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Maytag Neptune Drying Center MCE8000AYW
Email me a response to and I will be more than happy to provide you with parts breakdown illustrations and possible part numbers and locations to replace. The service amount verses the do-it yourself amount will be well worth the savings. Typical labor cost on appliances are 75.00 per hour and a mark up on the parts. If you feel you can do it yourself after getting the photos e-mailed to you, it will save you approx 200.00 if not a lil less or a lil more.
Please rate this solution "fix-ya" if it seems to satisfy your question.
Apr 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MDG21PD Electric Commercial Dryer Logo
623 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
