GE Profile TCC18: Same problem as everyone else: water /ice accumulates in area around fan and then runs out and freezes in freezer through drain hole and onto floor. ande eventually stops fan. Happens regularly. Repairman said it was a thermostat and he put a new one in in the coils. Said it would fix it. Worked for a few months now freezing up again. Anyone figured out a quick fix?
I had the same problem. I changed the defrost thermostat and that has solved the problem. Just to make sure the problem is not recurring I drilled a small hole in the back of the plastic drain(behind the fridge) so that I can put a long screw driver inside to determine if there is any ice build up. None so far after 3 weeks.
