FixYa.com
Tags:
Mackie SWA1801 Subwoofer
Excessive: 4 x Mackie SRM450s + 2 x Mackie SWA1801?
By Bomber - usenet poster
Hi folks,
I'm helping to organize a work party for a room with the dimensions
72' x 39' x 14' (L x W x H) for 150-200 people max.
We'll be spinning house and other electronic genres, and we want a
decent club atmosphere.
I rang a rental place earlier today and they recommended:
two x Mackie SRM450
two x Mackie SWA1801
I've played on/and heard a pair SRM450s at a couple of smaller venues,
and I was thinking more along the lines of:
four x Mackie SRM450
In your expert/experienced opinion would my suggested setup using four
x 450s really be too excessive?
Thanks for your time!
Scott
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Bray
Bray - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Yep they are a major part of my business too. However at this stage we have
a guy aiming for a great PA with no lighting. IMHO he is better off to back
track a little on the PA and put some lighting in.
However BJ, I agree with your suggestion of finding another Hire Co to do
the job. IF he can get a better PA with Lighting he should go for it. Even
if it involves eons ;-)
DP
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Janice
Janice - usenet poster
Rating: 0%, 0 votes
You NEED lighting!! Thats the other half of the atmoshpere. Just a few
simple DJ effects wont cost much. But they will make a hell of a change to
the atmosphere.
DP
Solution #3
Not Rated (0)
Rachel007
Rachel007 - usenet poster
Rating: 0%, 0 votes
Three hundred people is a big difference. You may not have enough bottom end
to travel through that crowd. However, Stick with the Mackies though. The
G2s are great. But the mackies with subs are a better option as JBL dont
make a powered sub specifically designed for the G2 15s. The G2 ( 250 watt)
subs are gutless compared with the Mackie and are really designed to work
with the G2 10s.
With your original spec you wont have enough bottom end to travel to the
back of the room. But it will do the dance floor ok. I would stick with
that given the options you have. Removing a 450 will reduce your tops
somewhat and frankly, the idea of three stacks just doesnt work in my mind.
Perhaps you could screw the hire co a little and tell em they have the
booking if they throw in the extra subs.
DP
Solution #4
Not Rated (0)
herself
herself - usenet poster
Rating: 0%, 0 votes
The building is half of a hotel ballroom, in a separate building a
long away away from hotel guests.
Also re: budget, we already decided not to have any lights/smoke. The
money has to be spent on speakers (amps). Defiinitely a case of how
long is a piece of string, but I just wanted to make sure I was in the
right ballpark, don't want to spoil the party for those wanting to
dance by not having a good enough sound system.
Scott
Solution #5
Not Rated (0)
Duke
Duke - usenet poster
Rating: 0%, 0 votes
When I say work, the 'workforce' consists of 1000+ people in their 20s
to early 30s, about 100-200 people are the party going type and will
turn up with like-minded friends. So we're expecting about 200-300 at
the party.
Realistically at the absolute peak I expect no more than 150 on the
floor at once. On average, yeah it'll be way less than those numbers.
I just hit the budget limit for equipment, can't get 4 tops and 4
subs, so probably going to have to go with:
2 x 450 (playing full range)
2x SWA1801 and 2x 450s (wired through the freq cut off of the subs)
OR:
3x SWA1801 and 3x 450s (wired through the freq cut off of the subs)
not exactly stereo...
Incidentally, the rental guy said he played in a band with 2x SWA1801
and 2x 450s to a crowd of 700 people...which I thought was
surprising...I guess the music he was playing was no where near as
reliant on bass as the tunes I'll be playing...
I also have the option of swapping out the 450s for JBL EON G2s, or
passives + amps
Budget is $300 for speakers (inc amps) see what you can come up with
here if you want some fun :o)
Scott
Solution #6
Not Rated (0)
Powe33
Powe33 - usenet poster
Rating: 0%, 0 votes
I agree to a point. However he is talking about a smallish venue. Its all
about the levels he wants to run with however. Dependant on neighbouring
buildings, houses, businesses etc , two srm450s and the swa1801s will easily
do a crowd of 150. This sort of thing comes down to 'how long is a peice of
string'. A 'real' club would have an eaw,kv2 or martin system for instance.
Basically he is doing a mobile gig. To go bigger may just be over spending
on the pa at the risk of underspending on lighting etc.
DP
Can you Help with these Home Theater Speakers and Subwoofers problems?
Need to replace one of the 5.25
I bought a used Boston... Answer This...
sts96 speaker wire
speaker wire's not long enough Answer This...
turning off the speakers on my...
Iwant to turn off my speakers... Answer This...
Popping sound
Sub has an auto off when not... Answer This...
no sound
there is no sound coming out of... Answer This...
Repair Service
Find Home Theater Spe. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
