Question about Kenmore 24032\24036 Top Load Washer
The machine works fine until it reaches the rinse cycle.
Just hooked up my machine after it sat in storage for 3 years. I found it filled up fine, agitated fine and if I manually advance to the spin cycle, it works fine too. The problem is the rinse cycle. The dial just stops there. There is a soft 'buzzing' sound and trying to advance the dial produces nothing. Going to the spin cycle and it works fine.
What happened?
  • 117 Answers
The buzzing sound is the cold water inlet valve is getting power but water is not able to enter. You need to have the valve replaced or make sure the cold water is turned on at the sink. Hope that helps, let me know.
http://tclaundryrepair.com/
Posted on Mar 02, 2009
Kenmore 70 series washer
If you can see a constant water pressure from the hot and cold, chances are the water solenoid valves are ok.
I would look towards resetting to factory and checking the main control unit.
May 11, 2014 | Washing Machines
Washer works fine until it starts filling on the rinse cycle, then the water just flows out of the drain. Last night the water was running for 3 hours, before I realized it. The tub fills fine when it is...
Make sure the drain hose is not sealed to the drain pipe, and that the hose is not shoved into the drain allowing the end of the hose to reach the trap. That will prevent the machine from syphoning out the rinse water as it fills.
Mar 29, 2011 | Washing Machines
Replaced lid switch a year ago, and the heavy duty cycle works fine. However, the permanent press/delicate and normal cycles do not work (tub just keeps filling/emptying water). My research indicates that...
I agree, it is most likely a timer problem. Possibly "rust" build-up.
See the Whirlpool / Kenmore Service manual for top load, direct drive washer for troubleshooting and diagnostics procedures.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Nov 18, 2010 | Kenmore 24032\24036 Top Load Washer
Top-load washing machine wont stop filling. It is as if the machine does not know when the proper water level is reached. However, if I advance the knob, it will proceed into the wash cycle just fine...
There is a scensor in the controll panel it have a tube connect to it.
that is the level switch .
make sure that the tube is clean by taking it out and run water with bleach make sure the tube is not damage.
hook it up again and check the machine again if it solve the problem dont forget to rate me, if you still have a problem let me know we will work on it more...
Jan 12, 2010 | Washing Machines
My washing machine is not changing cycles. It fills, drains and refills. It sat unused for 1 year. 12 months ago it was working fine.
Hi there. I can help you.
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. If this is the case, turn off the water and remove the hoses. Check both hoses to be sure the filter screens are not clogged with crud and that the hoses aren't kinked.
Jun 18, 2009 | GE WSXH208A Front Load Washer
Will only fill and drain
It sounds like the timer/controler is broken replace it. Peter
Mar 18, 2009 | Washing Machines
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
The correct way to start the wash cycle
we have just purchased a Fagor dishwasher also - the instruction manual is worthless.
in regards to the 2 thin tubes, we just inserted them in the gallon jugs that the soap/rinse agents comes in and it works fine. just make sure the clear tube without the label goes in the rinse agent and the labeled tube goes in the soap jug. we did drill a hole in the top cap of the jugs and pushed the line thru and that helped keeping the tubes in the jugs and minimized the mess if the jugs fell over.
in regards to the temperature problem, we found that running it thru a couple of cycles before you start the actual dishes helped get the water temperature up faster. it seems to like to start with normal tap hot water first, so the 1st couple of cycles get the cold water out of the line.
Dec 29, 2007 | Fagor 24 in. FI-48W Dishwasher
Kenmore 24032\24036 Top Load Washer Logo
193 people viewed this question
Sal De
fordexpert
Robert Rankin
