Question about Olympus EVOLT E-500 Digital Camera
Flash doesn't synch with shutter on olympus e-420
On auto falsh setting, images are dark as if not synched with the camera. flash fires. Any ideas, have I messed up the settings?
Well a good photographer dosen't  use a auto to much.  Second you can solve  this problem by  buying a 36r or 50 r  flash.  Next put your camera into aperture priorty the flash will now sync up to 4000. I hope this solves your problem..  lesmobile1@yahoo.com    www.storyboardvideo.com
Posted on Jun 01, 2009
Why the flash of the camera are not sincronize with imagine and sometime is shooting down when I shooting.
Your camera probably has a flash shutter speed, typically around 1/200 second, and if you choose a higher speed then only part of the image will be exposed.
Apr 20, 2016 | Olympus E-420 Digital Camera
The viewfinder screen is completely black. no image whatsoever. it seems like the camera is functioning everything works from what i gather
Since it's a film camera, there are a couple of things to check:
1. You have left the lens cap on.
2. If this is a single lens reflex camera, take the lens off and make sure that the mirror isn't stuck in the "up" position. If it is, GENTLY pull it down until it stays down. At this point, your shutter may be open. Try cocking the shutter again, fire off a test shot, and see if the mirror sticks in the up position. If it does, you probably need to replace the mirror bumper foam - age can make foam deteriorate into a gooey, tar-like substance that can make the mirror stick in the up position.
3. Does the camera have a T (for Time) setting on the shutter speed dial? If so, turn it off the Time setting and set it to a manual shutter speed such as 1/60 - or whatever your 'X' synch speed is.
4. Your batteries died in mid-exposure. Replace the batteries. You may have enough juice in them to show the viewfinder display, but not enough to finish the exposure and close the shutter.
Nov 16, 2017 | Pentax MZ-60 QD 35mm SLR Camera
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Apr 30, 2010 | Olympus FL-20 TTL Flash
The built in speedlight on my D 70S is not synching. Seems like the flash goes off before the shutter opens.My pictues all comes out dark no matter what I try. Can you help me?
I fixed this same problem with my D70s today, after twelve months of getting dark pictures despite the flash firing. It started syncing properly after I performed the following, though I'm not sure why as I was just mucking around.
- Set Program to P. - Push button to activate built-in flash. - Push, and keep depressed same button, which will put you in Flash Exposure Compensation mode. - My Flash Exposure Compensation was on +0.3 so I set it to 0.0 by turning the front wheel. Seemed to fix it.
Sep 23, 2009 | Nikon D70s Digital Camera
Missing shot.
Any auto camera like this is going to have trouble in dark light...
Photography is all about light, and in dark situations, compromise as well.
You best chance is to set the ISO up to the highest setting available, use flash, and a faster shutter speed, however, faster shutter speeds means less light can enter the lens, and hence give a darker image. Higher ISO makes the camera more sensitive to light, but produces grainier images as a result. Flash creates artificial light...
The only real way to get good images at a concert in the dark is with a high end camera, a lens costing many thousands of dollars, a tripod or monopod to steady yourself, and a longer open shutter time.
In the meantime however, experiment with higher ISO setting, flash and try to keep your hand steady at all times because the shutter speed needs to be slightly slower for the lens to capture more light.
Apr 06, 2009 | Fuji FinePix S8000fd Digital Camera
Syncing Nikon D300 with 600VR strobe system
A wireless system such as the line of Pocket Wizards is a good choice- the are builr to professional standards and are very reliable.
If you wish to hard wire your flash unit to your digital camera, you can purchase a protector wivh reduces the trigger voltage to a safe level refatdless of the age or design of the flasg system you are goinf to use, Under no circumstances should you use this combunation of equipment without a radio triggering device or the protector, The protector attache to the hot shoe of the camera and provides a standard PC synch cord terminal for connecting your flash system to the camera.
You can test the voltage by putting a volt meter set a 250 or 500 VDC across the synch socket in the flasg unit, If the meter deflects negatively just revers the polaity for a correct reading. If there is under 5 volts there is ptobably no issue, however, I still would take no chasces abd use a radio or a protector. If the falsh won't fire with the radio or protector in place, tha probably means tha the synch voltage is very low.
Nov 22, 2008 | Novatron 1000ws Standard Head with 25'...
What kind of battery for an XC-3 vivitar camera?
Your Vivitar XC-3 takes two MS76 or S76 batteries. BTW, some further specs for your camera:
It is basically the same of the Cosina brand, CSR model.
  • Match-LED Camera with an optional aperture-prefered automatic exposure accessory unit (servo-motor).
  • Shutter: cloth electronic, 4s-1/1000, B.
  • Flash: X-synch hot shoe, standard X and F synch at 1/60
  • Metering: stoped-down TTL or spot metering
  • Finder: split-image rangefinder and ground glass collar.
  • Auto diaphragm
  • Instant return mirror
  • Self-timer
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Nov 16, 2008 | Photography
Nikon D40 Image Darkness
You probably have "bracketing" turned on. In your menu settings, search for bracketing and make sure it is off.
Feb 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Flash and Shutter not in synch
Good Day, flash assy is defective, the light sensor that will detect the correct flash exposure is defective, no longer user serviceable, contact nearest svc ctr for replacement of flash assy. thanks
Nov 19, 2006 | Sony Cyber-Shot DSC-P73 Digital Camera
Information about a picture's settings
I use Thumber to do it. It tells me everything I want to know - shutter > speed, F stop, ISO, zoom position, date and time down to the second, > plus some other things I don't remember. Thumber was freeware when > I downloaded it.
Sep 06, 2005 | Olympus Camedia C-2000 Zoom Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
173 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
