Question about Crane Plumbing 3755 Toilet-To-Go Metro Complete Replacement Toilet
Raising water level in the toilet bowl. Crane toilet. Don't see where any adjustments can be made. Water level in reservoir tank is up to the inlet tube. How do i get the water level in the bowl to be higher than it is? Quite low at this point.
  • 4 more comments
  • Anonymous Mar 16, 2014
    Low water level in bowl
  • Anonymous Mar 20, 2014
    water level low in bowl
    Water level in bowl is way too low! How do I get the water in toilet bowl "higher"???? What do I adjust inside toilet tank to raise water level inside toilet bowl? ***** is sticking to bowl
  • Anonymous Mar 24, 2014
    How to adjust water level in bowl
  • Anonymous Mar 26, 2014
    Water level in tank is low
    Toilet keeps running. Water level in tank is very low
Your problem may be a leaking wax ring. Even if you do not see water on the floor, a broken seal may effect the water level in the bowl. I have experienced this in my own home before. If it isn't the problem it's a cheap attempt to fix it.
Posted on Oct 04, 2013
  • 653 Answers
The water level in the bowl is limited by the height of the internal trap down stream from the bowl. There is no adjustment possible. If the problem is odors, you can either flush more often, turn on the exhaust fan, or buy a different brand or model of toilet.
Posted on Apr 04, 2009
Raising water level in toilet bowl Niagara Stealth
the water level in the pan is set by the exit pipe level and if it is raised it will only flow out again to that pipe level
if you are ferefing to the cistern water level
remove the top and adjust the float level or level control unit
Sep 10, 2016 | Niagara Stealth Ultra High-Efficiency -...
Adjust the water level in the bowl of a duravit toilet
You can't. Water level is set by the design of the trap built into the ceramic base. Can only adjust height of water in the tank.
Jan 07, 2015 | Duravit 0910100005 Happy D Toilet Cistern ...
Dropping water level in toiet
Is all the water in the tank allowing the water into the bowl. This could be the problem, unless there is a blockage in the toilet itself as the water flushes out.
Feb 10, 2013 | Crane Plumbing Home
My toile tank does not completly flush, I have to hold the lever up untill all the water in the tank emptys and complete flushing occures. What is the solution?.
Sounds like the adjust on the flapper has to much slack on the chain. It's not raising it up enough to flush correctly.
Adjust that and make sure water level in tank is correct at least up to mark in tank or about 5/8" to top of overflow .
Also check fill line and make sure it is connected to overflow also this allows bowl to fill up.
Jun 15, 2010 | Toto CST414M-11 Aquia Dual Flush Elongated...
Crane toilets don't flush properly, ball comes down too quickly
adjust the flappers-- either adjust the length of the lift line-from flapper to handle and or the flapper itself not properly mounted on tank seat
Mar 10, 2010 | Crane Plumbing Home
Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
Oct 24, 2009 | Kohler K-11470-0 White Wellworth Complete...
Water level in bowl too hogh
Try bendig the float rod down so th resivor dont fill so much
Oct 19, 2009 | Elements Of Design EVWC320 EcoFlush Close...
Water level in bowl too low
Hello, W/D, toilet expert, here.
The tank has a water level line cast into the inside back of the tank. That's where your water level should ideally be. Now, there are a variety of water level controllers, so we'll hit on the major ones. But first, a little nomenclature, so you'll know what it isn't. If you remove the tank lid, you'll notice a tube in the middle that's open, and usually has a smaller tube inserted or attached to it. This is the overflow tube, and feeds water to the rim of the bowl. At the base of the overflow tube is the flapper, and it controls the majority of the flushing power. The flapper is operated by a chain connected to the flush lever. When the flapper is raised (flushed), the water level drops. On the left side of the tank is the water fill valve, The water coming from the house via the tubing under the tank goes into this valve assembly. Part of this assembly is the all important float.
Older ones have the float at the end of an arm, As the water level falls, the float falls and operates the water inlet valve at the other end of the float, on the water fill valve. As the level rises in the tank, the float rises with the level and shuts off the water when it gets to it's pre-set level. This type is adjusted by positioning the float either by the screw adjustments on each end of the float arm, or sometimes by bending the float arm.
The newer types have the float either built in, or the float surrounds the fill valve. The one that surrounds the fill valve looks like a very fat donut and is very similar to the older float arm type, just more compact. The water level is set by adjusting the linkage between the float and the water valve at the top of the water control valve.
The newer newer type has all of the floating mechanism built in. But cleverly, there is an external adjustment for raising and lowering the water level. On the side of the tube, there are slots and raised dots on the lower tube. The upper tube has slots on the inside of it. There is a white locking tab between the two tubes. Here's how this one works: (Turn your water off first for adjusting this type). The tube is in two parts, an upper and lower tube. They are held in place by the locking tab, and by the slots cast into the two tubes (they intermesh) To adjust this type, you have to raise the lower portion of the locking tab to raise it off of the locking dots, and than revove it. Then, you push down slightly and twist the upper section to unlock it. Set the level higher or lower, twist the two parts back together, and reinsert the locking tab. The aim is to set the water level at the level mark on the tank. This type can be tricky; you'd do best to turn the water off to adjust this type, and turn it back on once you have locked it back in place.
Best regards, W/D
Aug 17, 2009 | American Standard Cadet 3 Right Height...
My Toto keeps running
Yes, there is either a screw that can be turned lowering or raising the water level, usually found on top of the fill valve.
Or there is a lever system that raises or lowers the float, thereby raising and lowering the water level.
The first it typically found on fill valves with a float ball attatched by a metal rod to the top of the fill valve.
The second are on the "fluidmaster" type fill valves.
If you still cannot find the water level adjustment describe in detail or provide pictures of the type of fill valve you have and I will walk you through it.
Aug 16, 2009 | Toto Carlyle 1-piece Elongated Bowl Toilet
Low water level in toilet bowl
Sorry, but there is no way to raise the water level in the bowl of a low-flow toilet. The water level is determined by the height of the internal trap, usually visible from the side of the toilet (that squiggly little bend). If the toilet is not flushing satisfactorily, you can make adjustments to the water level in the tank and adjust the closing of the flapper. If the problem is odors, flush half way through your business or turn on the bathroom exhaust fan. If you found this answer helpful, please don't forget to rate it.
Apr 09, 2009 | Bemis Home
Crane Plumbing 3755 Toilet-To-Go Metro Complete Replacement Toilet Logo
1,313 people viewed this question
Top Crane Plumbing Home Experts
john h
Tom Chichester
Are you a Crane Plumbing Home Expert? Answer questions, earn points and help others
