Question about RCA 20" TV
Where is reset button on 35 inch rca tv,I can only view 49
Channels. model #F36649
  • 75 Answers
There is no reset button. Ypu need to give more detail about what i sgoing on with your set. Also what is the model and ctc numbers thfey can be found on the back of set. Unplug set for around 30 minnets then plug back in see if it wil work then.
Posted on Feb 28, 2009
Rca model f36649 s-video hookup to laptop computer When I hookup s--video cable to tv & HP Pavillion dv9000. I get nothing on tv? I have tried putting tv on channel 3.
Depending on how many hook ups you have on your tv it may have a factory designated channel. Example: Video 1, Game, etc. I know my TV has several different video channels. It's more a matter of trial and error until you find the vidoe channel for your oulet. Input channels are usually found before channel 1. Or look on your remote and see if it has a button to switch the channel to your input channel. Good Luck.
May 27, 2010 | RCA F36649 36" TV
Sudden channel changing,flipping off and on and channel searching
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Apr 21, 2017 | RCA F36649 36" TV
Can't find aux channel to view vcr/dvd
use vid 1 or vid 2 input on remote should do that if not then use a differ code in your universl for your tv that makes it work or type 00 should get u there another way go to channel 1 and then down arrow it will go into it if not go into your add channel menu and add them then down arrow
Dec 03, 2008 | RCA Televison & Video
Doesn't rcognize DVD players
You aren't trying to use channel 3 or 4 are you? That's for RF connections only.
There are probably AV input channels on the set that aren't accessible from the channel up/down buttons. On my set there is another button to switch between inputs and channel select.
Mar 23, 2008 | RCA 35V432T 35" TV
RCA F36649 36" TV
I had this happen. (ontop of the button board infront shorting out). I took the back off, and if your looking at the screen it'll be on your right. There is a metal box with two ribbons coming out of them, I unplugged both and plugged both in, and now she turns on without any issues. Not sure why, but it works. Now if I could get some help finding the circut board with the front buttons on it. I.e channel up down and volume.
Nov 07, 2007 | RCA F36649 36" TV
Suddenly, can't get all the tv channels!
Try resoldering where the tuner mounts. Rca has had some problems with solder connections
Oct 16, 2007 | RCA F36649 36" TV
Buzzing noise with no picture or sound.
The power supply is telling you that it has a short. I think you have a bad high voltage transformer in the horizontal deflection circuit. I've repaired several RCA's with this very same problem. The newer RCA's are vert prone to high voltage transformer failure ! Stargazer
Aug 20, 2007 | RCA F36649 36" TV
TV is on and just suddenly starts changing channels
the switches in the front of the tv are usually the cause of this kind of problem. the fix is to replace all of the switches, because if 1 is bad the others are not far behind. each switch from rca is $5 to $10 each. good luck.
Nov 18, 2006 | RCA F36649 36" TV
RCA 20" TV Logo
88 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
