Question about Toshiba Satellite A85-S107 Notebook
Clean up!!?? Hello! How do I know wich program shoul'd run when I turn on my computer?
  • 43 Answers
To be safe you can scan with Spybot and malwatebytes, also you can disable unwanted apps. manually from loading on startup by going to "Start" then "Run" type in "msconfig" go to "Startup" tab and unthick unwanted apps. like msn, icq, etc.
Posted on Feb 28, 2009
Printer offline message
This should be a button on the printer to put it on-line. If not check the computer settings for your printer. Try tech support or youtube.
Mar 18, 2015 | HP PhotoSmart C4480 All-in-One Printer ...
Cant get google maps to work
Hello, Altrough I am not experienced with this particular model you may try the following method. First back up all your data on the internal memory of your device.This will allow you to restore contacts, programs or other data after you perform a master reset. Save the backup file to a memory card or another external storage device. Then hard reset the pda, to restore it to the factory settings. After this is done, install the program (google maps) after the pda's initial setup (wich occurs after the hard reset). Now check to see if the program works. If not, the logical assumtion would be that the program wasn't clearly designed for this pda model. Please notice that altrough all these devices run Palm OS, the actual operating system is different in order to fit each model's hardware specification. So it isn't like windows xp for example, wich can run on any computer, regardless of it's manufacturer or hardware components. If the program fails to work after all of this, you can either wait to see if google comes up with a patch to the program or a newer version that includes your pda in the suported devices list. Meanwhile you should use the backup you just made to restore the device to it's previus state. Please come back with a reply if this fails to work. Good luck.
May 27, 2007 | Palm Treo 680 Smartphone
Virus attacked my computer and the application says trial expired, I had no trial I paid for my roxio
Uninstall the application, turn off the computer, wait for 30 secs, turn on again, reinstall the MyDVD and reintroduce the license key you have.
If this not fix, maybe you should have to repeat the process but, before, make the next:
- run the "regedit" tool and clean all the information that had stored in the registry file about Roxio MyDVD;
- delete all folders wich happens to exist in the "programs files" and "my documents" folders related to Roxio MyDVD;
- browse to "c:\documents and settings\(YOUR NAME)\locals configurations (I don't know if this is the correct name in your lang, cause i'm brazilian, and here is this way) \temp" directory and delete all files that have in it.
Now, you are ready to reinstall your app.
If this not fix, contact the Roxio Support and say you've lost the license key. They'll send you a new LK. I think...
Good luck, man.
Apr 03, 2011 | Roxio MyDVD 9 Studio Corporate License...
1996 maxima flasher
if your asking about fuse flasher under your hood passenger side under black fuse box the cover shouls tell you wich fuse is wich. or button for putting them on is on your dashboard or close to shifter button with red triangle on it
Mar 28, 2010 | 1996 Nissan Maxima
The disk drive recognizes dvds and cds just fine, but when I play a dvd on my computer it lags and stutters constantly. I don't know if it is a hardware or a firmware problem. I don't have the original...
I use vlc myself it doesn't have compatibility problems and i have not run across many formats it will not play
first you shoul;d turn down the resolution on the screen(right click anywhere then go to the bottom and click properties then at the end is a settings tab lower your resolution to about 800x600 and see if this helps if not try putting in more memory that should help
Nov 30, 2009 | Dell Inspiron 600m 1.6GHz Pentium M...
I was advised that this program TotalCAD 2D/3D would run on XP
As I see Totalcad 2D-3D is a little old program. Try to use compatibility mode for setup.exe
Also i give you a link to be more clear with that program. There you'll se on which OS is shoul work.
Aug 05, 2009 | Computers & Internet
My computer is running very slow and i dont know why, I have used the defrag and clean up and ran many of antivirus programs but nothing seems to work, Please HELP
Hello
try running "msconfig" and disable all services except microsoft services .. there may be many programs running behind... and also disable all the startup entries in the startup menu in the same msconfig window..
Cheers!!!
Aug 03, 2009 | HP D530 PC Desktop
Clean a virus from regedit
it's impossible to clean the virus by regedit !
Sep 05, 2008 | Computers & Internet
Epson c84 ink cartrages
Hello Carla, can you manually clean the heads where the ink delivers the printer. Try using the printers own program first then do a manual clean with proper cleaning solution if this will not work.
Mar 10, 2008 | Epson Stylus C84 InkJet Printer
HELP! I cannot remove Programs from my Computer!!
You could try running Add/Remove program under safe mode. To enter safe mode, press and hold "F8" during system bootup, when given a menu, use arrow key to choose "Safe Mode".
Good Luck!
Tony
Jan 09, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Toshiba Satellite A85-S107 Notebook Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
