Question about OfficeMax 0M96431 Shredder
OM99728 paper jammed in cutter blades
I have a officemax OM99728 shredder and the paper is jamed in the cutters and it now doesn't work at all.
splintellz1
  • 37 Answers
SOURCE: Need Ativa X1800 Shredder Parts
Hey check out this link they service all types of shredders hopefully they should be able to service yours.
http://www.factory-express.com/blog/2005/10/paper-shredder-parts.html
Posted on Jul 03, 2009
  • 60 Answers
SOURCE: My Ativa DQ60M shredder has
Hi, I have checked into this with my shredders. There are plastic "cleaners" that break very easily and when they do, the cutters jam up. No way to get just the cleaners (that I have found). Very poor design. Only thing to do is to clean the rollers from time to time.
All of these types are shredders are mainly junk. I have one that is blowing the fuse. I am an electrical engineer and am trying to see what the fix is.
Posted on Jan 10, 2009
JayBlair
  • 328 Answers
SOURCE: the paper will not go through my shredder
Can you actually see the cutter blades rotating? I have seen gears broken and you can hear the motor running but no blade movement. Remove the screws lift the top off carefully because their is a short ribbon cable connected to the main board and can easily be damaged. Of course unplug from power outlet first.
Gears and motor can be puurchased.
Posted on May 15, 2009
JayBlair
  • 328 Answers
SOURCE: Fellowes PS60 CC shredder jamming
You have guides or cutter assembly out of alignment. Take it apart and double check before reassembling.
Posted on Jun 11, 2009
FixinFax
  • 3085 Answers
SOURCE: Royal 10x Crosscut Paper Shredder (PCUA: 29054E) paper jams.
Try soaking the cutters with soapy water, yes it works. Oil after you are done.
Posted on Aug 02, 2009
Ativa shredder X1800 - shredder does not respond. green light present. Reverse works fine. I killed it with too much shredded paper.
Unplug it. Lift the shredder unit off the catch-bucket. Remove any paper caught in the blades. You may need needle-nose pliers to pull jammed paper out from between the cutters.
Aug 22, 2016 | Office Depot Ativa X1800 Shredder
Does this shredder activate when it senses paper being fed?
in the space where the paper goes to be shredded is a very small plastic level that is pushed sideways when the paper is put in
this lever is between two cutter blades and is easily jammed in the on position from paper bits
remover any paper around the center of the shredder that is blocking up the cutters
Jan 20, 2016 | Techko Office Equipment & Supplies
How do i clear jammed cutter blades
Does the shredder have a reverse button ?
If it has, just switch between reverse and forward a couple of times.
If that does not work it may have to be dismantled and the cutters turned by hand as you pull the paper out. Disconnect the power first though.
Dec 17, 2014 | Office Equipment & Supplies
Its not working and shredder wont turn on
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and poke at any compressed paper wrapped around the blades - can take a while. Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
If all else fails, contact the maker
Feb 27, 2014 | Aurora Electronics AS1010TX Cross-cut...
My fellowes p 48c is jammed
Feb 26, 2014 | Fellowes P48C Cross Cut Shredder with...
Jammed paper shredder royal 80x
Feb 17, 2014 | Royal Office Equipment & Supplies
Shredder blades not turning
A staple or paper clip has jammed the cutter blades.
If there is a reverse switch then reverse to free the cutter blades and remove these objects.
Mar 23, 2013 | Fellowes Microshred MS-450Cs
OM99732 shreader Motor operates but won't take in any paper. Motor is quieter than normal
When motor is running, look to see if the cutters are turning. The cutters can be seen by looking into the throat of the shredder. If the cutters aren't moving, the gears may have been stripped and shredder needs to be repaired or replaced.
Good luck.
Apr 14, 2011 | OfficeMax 0M96431 Shredder
Paper Jam
hi you shuld have to remove covers and saprad the cutter rollers this is the way to clear the jamed paper
thanks
May 12, 2010 | Destroyit 4004 Shredder
Jammed with gummed stickers
Always put stickers in the shredder between two layers of 3-4 plain paper sheets. That's for future.
Now I would suggest getting some "Label Off", "Label Killer" or similar spray product, that will dissolve the glue, spraying the cutters and stuck labels with it several times, trying to remove them with tweezers or thin long-nose pliers. Be gentle, try not to blunt the cutters' edges.
When you get rid of the labels, spray more of the stuff on the cutters and clean them with a brush, to remove glue residue between them. Do it several times, rotating the cutters to remove the glue all around.
Then lubricate the cutters as per manufacturer's recommendations.
Nov 14, 2009 | OfficeMax 0M96431 Shredder
OfficeMax 0M96431 Shredder Logo
480 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Randy Schumann
Randy Schumann
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
