Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Says replace ink cartridge
I have replaced my ink cartridges numerous times and they are still full. It keeps telling me the ink cartridge needs replacing. It won't print and the red light keeps blinking. I have only had this printer for about 6 months. It won't scan or print. Its a Kodak Easyshare 5300.
  • KHALL31783 Mar 03, 2009
    last used said i had half full now says it needs replacing
I have replaced my ink cartridges numerous times and they are still full. It keeps telling me the ink cartridge needs replacing. It won't print and the red light keeps blinking. I have disconnected the usb and the power. I have only had this printer for about a year. It won't scan or print. Its a Kodak Easyshare 5300. The HomeCenter AiO is disconnected so how do I contact anyone from Kodak?
Posted on Mar 02, 2009
I have a Lexmark Pinnacle Pro 901 printer and its set up to print using black ink only, but it keeps telling to replace color cartridges and it won't let me print at all, how do I print using blac
The printer would need all cartridges to have sufficient ink levels to continue printing - that's to prevent damaging the printhead. Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
To save on your ink investment, try printing in draft mode and by making sure that your printing preferences is set to print using black ink only.
Oct 25, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
I have replaced all the ink cartridges but I keep getting the error light telling me to reinstll ink - I have done this numerous time but still get the message, all ink cartridges are full but the levels...
If you have used generic, or refilled cartridges, this probably the issue. You don't say what make or model, so it is hard for me to help you passed here. Newer copiers and printers are paricularly sensitive to non OEM cartridges.
Jan 30, 2011 | Brother Office Equipment & Supplies
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I replaced the black ink and it keeps saying replace ink cartridge. I actually went ahead and changed the color as well even though it did not ask and it keeps saying replace cartridge. HELP! I am a...
Did you replace the ink cartridge with a new one, or did you refill an old one.
Some printers have a memory and can tell which ink cartridge is in them. This prevents them from easily being fooled into printing with refilled cartridges.
Another option is that you changed the ink cartridge without following the specific guidelines for replacement e.g. To replace the ink cartridge, select replace ink cartridge from the main menu, then open the printer panel when the light flashes X number of times.
You might also try unplugging the printer for a couple of minutes the reset it.
Oct 15, 2009 | Office Equipment & Supplies
False error empty cartridge
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jun 01, 2009 | HP Photosmart C6280 Printer
Ink cartridge
Using some switch cleaner solvent, gently clean the contacts on the cartridge carriage, and also if you have any, use some inkjet cleaner to clean the nozzle where the cartridge sits, this should clean the mechanism sufficiently to allow the printer to detect the cartridge.
Mar 05, 2009 | Epson RX595 Photo All-In-One Printer
Printer continues to tell me low on ink.
i replaced cartridges , error , said to replace cartridges. I then removed the new catridges, and now, can't drop the cartridge back in the scanner.HELP
Mar 01, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Ink Cartridges are full but keeps telling me they are not to then
as a printer mechanic .i had got many customers coming at my work shop with this problem .and it gets soved by replacing the cartridge with new cartridge.as you said cartridges are full still it says change cartridges.but if the circuit of the cartridge is got faulty it will not print let it be full.so clean the brown colour metal circuit on the cartridge with a dry tissue.if its due to dust got stuck up on the circuit it will print otherwise the cartridge has to be changed in this case.
Feb 26, 2009 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-3360C cyan ink cartridge replace ment
On the front of the cartridge there is a sight tube for the ink, the fax shines a light through this tube to detect the ink.
I wraped a piece of paper around the tube to block the light beam on all the cartridges.
I dont need a processer to tell me if the machine is out of ink, I can work thay out when it stops printing!!
Now tell me you are out of ink you peice of electronic ****.
Jun 27, 2008 | Brother Multi-Function Center MFC-3360c...
Canon iP4300 I normally refill my ink cartridges without any problems using ink from a Jettec kit. Suddenly the printer has said that I should replace one or more cartridges although they are all full....
You can only fill ink cartridges up to a maximum of 3 times, thereafter the chip on he cartridge need to be replaced. That's why u are getting that message my advice order a new cartridge.
Jun 10, 2008 | Office Equipment & Supplies
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
745 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
