Question about LG Washing Machines
I hold down the tub clean for 3 seconds & the prewash turns on
I hold the tub clean button down for the 3 seconds the book tells me to, when I do the prewash light comes on and the washer starts a 1hr 25min cycle. What am I doing wrong? Do I need to contact LG?
You need to turn "off" the "spinsense" feature before you can successfully activate the 'tub clean' cycle.LG won't tell you this.Just make sure you turn it back "on" after you are done,as you probably turned it on for a good reason.
Posted on Mar 12, 2009
Quit working with CL code flashing nothing will work, Ive unplugged and waited to no avail
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 19, 2015 | Washing Machines
Model EWF10843. How do I select diagnostic mode?
Electrolux Diagnostic Mode
* Press the Cancel button to enter standby mode and enable diagnostic entry.
* Within 10 seconds after pressing Cancel , press any button to wake up the control.
* Within 5 seconds of wake up, turn the selector knob to the far left cycle and press and hold Cancel and far left
button under the display simultaneously for 3 seconds to enter the diagnostic mode.
To save time at wake up, the Welcome screen can be bypassed by turning the selector knob.
1. Upon entering diagnostic mode, all lights should flash for 1¼"x2" display models and all lights on for the 1¼" x
4 3/4" display models.
2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water
should enter through the detergent compartment.
3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water
should enter through the bleach compartment.
4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and
cold water should enter through the softener compartment.
5. Turn the program knob (4) clicks from the start position. The prewash solenoid will activate and cold water should
enter through the prewash compartment.
6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door
can be opened. When the door is opened, the drum light should turn on.
7. Turn the program knob (6) clicks from the start position. The door lock will activate and the washer will fill then
tumble. Once tumbling has started, the boost heater will turn on.
8. Turn the program knob (7) clicks from the start position. The drain pump will activate draining out any water in the
tub and the washer will operate in high spin.
9. Turn the program knob (8) clicks from the start position. This is a free position.
10. Turn the program knob (9) clicks from the start position. The control will signal the last 5 error codes with E00
being no error.
11. Turn the program knob (10) clicks from the start position. Latest software version will be shown.
12. If applicable, turn the program knob (11) clicks from the start position. This is a free position
Exiting Diagnostic ModeA) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord or
Turn the program knob clockwise back to the start position. Press the Cancel and far left button under the display
until the LED's stop flashing
Jun 08, 2015 | Electrolux Washing Machines
When I press clean the Extra rinse button on the options side the light does not come on. When I hold it for 3 seconds to start the Clean tub option it gives me an error that looks like an upside-down f...
Just happened to me today! Exact same code. When I hold the button for 3 seconds it automatically switches to pre-wash. I have the LG wm2487hrma.
Feb 24, 2011 | LG WM0642H
My washing machine says control locked
Hello there
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
? Close the door.
? Push CONTROL/ON (if present on this model).
? Select the DRAIN/SPIN cycle.
? Select NO SPIN by pressing the SPIN SPEED touch-pad.
? Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
Read more: Whirlpool Duet Washer 'Control Locked' - The Laundry Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum2/1540.html#ixzz1AbBWB73c
Get appliance parts at http://parts.fixitnow.com
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does LF mean?
It is a long fill error. It flashes when the machine control board detected no change in the water level or the water level is not reached in a certain period of time during the fill cycle. Water is probably not entering the tub due to the water inlet valve not functioning or water enters the tub but not properly due to clogged fill hose screens.
Press the Pause/Cancel button to clear the error on the display. Remove the fill hoses from the water inlet valve assembly at the back of the machine and check the screens. Clean the screens and replace it if necessary. Make sure that the water supply valve is open and water is present.
Put the machine in standby mode (only the Clothes Clean indicator is on) and activate the Manual Diagnostic Test Mode to check the operation of the water inlet valve.
  1. Select any one button except Power, Stop, and Stop.
  2. Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds
  3. Press the same button when all indicators on the console are illuminated and "88" is displayed on the Estimated Time Remaining display. A single beep sounds and display shows the two digit console ID number for 3 seconds. The displayed ID number will change to "00" and the Add a Garment indicator will flash.
  4. Select Whitest Whites cycle.
  5. Press Start>Wash/Rinse Temp. The water inlet valve should turn on and fill the tub according to the Wash/Rinse Temp selection.
  6. Press Start to turn off the valve.
  7. Press Stop or Power button to exit diagnostic test mode.
Feb 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Message CL has appeared whch is child lcok. How
hold down the rinse and prewash buttons at the same time for 3 seconds , do the same to start it also.
Nov 12, 2009 | LG WD-1045FH Front Load Washer
HOW TO RESET SERVICE INDICATOR ON 2001 C CLASS CDI
  1. Make sure the doors are closed
  2. Turn key to position 2,
  3. press trip reset button 3 times, untill service indicator screen shows
  4. Hold down the reset button and turn key to position 0.
  5. while the key is at position 0, release the button and repress,
  6. turn key back to position 2 while holding down the button
  7. wait untill service resets.
this all has to be done within 10 seconds. it may take a few attempts.
Jul 17, 2009 | 2003 Mercedes-Benz C-Class
I have the spinsense option activated. I want to turn it off and I want to activate the tub clean option. The won't work when I press and hold the button for 3 seconds. What can I do?
Push and hold Stain Cycle button for 3 seconds to cancel spinsense. Then, turn off machine. When you power it back on, press "Extra Rinse" for 3 seconds and push the START button.
When cleaning tub, do NOT use detergent--only use liquid chlorine bleach.
Jul 05, 2009 | LG WM2487H Front Load Washer
TROMM Washer "CL" Error Message
THE CL ERROR CODE IS CHILD LOCK, PRESS AND HOLD THE PREWASH BUTTON FOR 3 SECONDS AND IT SHOULD TURN OFF........ BUT IF THERE ARE OTHER BUTTONS TO PRESS TRY IT OUT, THE OLDER LG'S HAD TWO BUTTONS TO PRESS, SO IF YOURS ARE THE OLDER ONES TRY IT OUT..... IF THIS HELPED OUT, PLS LEAVE A FEED BACK. I DO NOT ACCEPT PAYMENTS FROM ANYONE ONLY FEED BACKS, IT MOTIVATES ME TO HELP OUT OTHERS WHO NEEDS HELP....................
Jun 24, 2009 | LG WM2688HWM TROMM SteamWasher
Can't make tub clean setting work
Thanks to a couple of previous responders, 6 months of frustration has now ended - I can now run the Tub Clean on my LG Steam Washer! I first want to say that it is important not to get excited and start pushing buttons randomly, as I think I had been doing for all these months when I couldn't get Tub Clean to work by pushing the button in for 3 seconds. Just do the following, which combines and expands on a couple of previous responses:
1. I had to deactivate the Spin Sense, and if your Spin Sense is ON, you will have to do this too. (It is ON if the spin speed light flashes while any of the wash cycles is in progress. If spin speed button does not flash while a wash cycle is in progress, the Spin Sense is already off.) So how to deactivate Spin Sense? Select Speed Wash, and start the cycle. Let it run for about 20 seconds and THEN push and HOLD IN in the Spin Sense option button for 3 seconds. The blinking spin speed button will stop blinking and you will then know that the Spin Sense is OFF.
2. Once Spin Sense is off: Start with your machine turned off. Then push the power button on and select the RINSE AND SPIN option button. Then START the Rinse and Spin cycle. Let it run for about 5 seconds and then PUSH IN AND HOLD THE TUB CLEAN OPTION BUTTON FOR 3 SECONDS. You will then see the little LED light panel show something that looks like tcl. And you are there! Just leave it alone .... the LED will change to one hour and 25 minutes. And it will clean your machine just great.
3. Don't forget to put your bleach in the detergent cup before you start all of this.
I want to thank the two responders above who gave me the essential features for this fix. I forgot to make a note of their names before I started this response, but you can see who they are. I am so excited. Now EVERYTHING works on my LG Steam Washing Machine. I love this machine. It is a miracle of cleaning, especially since I own 4 large breed dogs and am washing and sanitizing large hairy and smelly bedding each and every day. And I no longer have to iron anything - I just use the steam cycle to unwrinkle our clothes. Best washer I have ever owned (and I have owned another major brand of large capacity front loading washer before - no comparison).
May 15, 2008 | LG WM2688H Front Load Washer
Washing Machines Logo
451 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
