Question about Citizen Eco-Drive BL006056H Wrist Watch
I need to remove some links from my citizen metal band watch.
  • 2,334 Answers
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
Where can i get links to add to band or replace band?
Parts Archives - Citizen Watch - English (US)
www.citizenwatch.com/en-us/faq-category/parts/
Citizen HoldingsQ: Why can't my jeweler or I order parts for my watch that is marked 'factory ... We domake some components such as bands and band parts available directly. ....Determine how many links of this size are needed to make the watch band the ... Q:Can you use substitute parts if the replacement part I need is discontinued? A:.Missing: timberland
How To Easily Remove a Watch Link - YouTube
? 3:10
https://www.youtube.com/watch?v=8uxpDXKOPqA
Dec 29, 2011 - Uploaded by TheBiggerKid
I got a watch for Christmas but the watch band needed a little adjusting. I thought ... Real Men Real Style 310,589 views ... How To Resize A Citizen Watch Band - Add & Remove Links At Home ... Get video URL at current time.Missing: timberland
Your Guide to Adding and Removing Links in a Bulova Watch
www.ebay.com > ... > Jewelry & Watches > Watches > Wristwatches
If the current watch does not fit properly, find another watch, a bracelet, ... When a metal watch band is too small, add links to make thewatch band ... How to Choose the Right Strap Replacement for... ... Bulova Men's 98E112 Diamond Set Stainless...... Bulova Men's 96A28 Black Leather Band Quartz Watch NIB Image ...
Jan 31, 2016 | Timberland Mens Quartz Watch Qt7117302
Where can I get extra links for the band?
Moto 360 - Extra links for metal watch band - Motorola Support
https://motorola-global-portal.custhelp.com/app/.../prod.../2815,9141
Your metal watch band can be expanded by adding links. The small gray envelope inside the watch box (see image below) contains four extra metal links.
Order Links & Bands - Fossil
https://www.fossil.com/us/en/.../order-links-and-bands.html
Fossil GroupOrdering Links & Bands (U.S.). Order Links. Extra links can be ordered with a U.S. issued credit or debit card by calling the Metro Service Center at ...
Dec 25, 2015 | Watches
How do you adjust the expansion band on the Citizen EW0700-98A watch?
these are hard to do. it needs to bend the tabs and pull out staples,then remove links and bend back, these are a pain in the ****. can be done by experanced guy. i can do them 10-15 dollars
Jun 17, 2011 | Citizen Expansion Band Eco Drive EW0702...
How do you adjust the steel watch band of a Citizen Sky Hawk A-T? JY0000-53E
    Making the Band Shorter
  1. Step 1 Stand the bracelet up on its side. Look for arrows on the inside of the bracelet.
  2. Step 2 Insert a small pointed tool from your hobby or watch set into the tiny holes on the edge of the bracelet. Insert the tool in the hole at the base of the arrow. You will see two holes on the edge of the band. Both pins need to be removed.
  3. Step 3 Push the pin out with force in the direction the arrow is pointing. Repeat this process on the second pin. When the pins are removed the link will be loose.
  4. Step 4 Remove the link from its neighbor and replace one pin to secure the bracelet.
  5. Making the Band Longer
  6. Step 1 Remove the link closest to the clasp by putting a small, pointed tool into the tiny hole on the edge of the watch band.
  7. Step 2 Push the pin out so the link is detached from the clasp.
  8. Step 3 Put a new link next to the detached link and line them up so a new pin can go through their holes and attach them together. You may need to snap them together depending on the type of Citizen bracelet you have.
  9. Step 4 Place the pin into the hole on the edge of the band and push the pin through the band with your sharp tool to attach the two links.
  10. Step 5 Repeat this process if you need to attach more than one link.
Aug 14, 2010 | Citizen Watches
Taking off a link from a citizen eco drive watch band
mcdevito75 here, Best Bet, look for a small watch repair shop in your area, You"d need a tool to remove that link, by the time you get the tool, the time to remove the link, is about the same cost of haveing a shop do the job.
Jul 04, 2010 | Citizen Eco-Drive Aqualand BJ2004-08E...
How do you adjust the watch band(remove the links)
This may seem simple to do but it is literally a ***** of a task. Best to where amplifying glasses and use a ball point pen, not a pin or pencil. Push one side of the pin in while keeping a slight outward pressure on the band. When it releases be care full not to let it fly off into the void(which they can) and then move to where you need the band to be and reinstall using a single edge razor blade. Just carefully align the opposite side (assuming youve alredy put one end in)place the razor blade on center and slide the remaining pin into the hole area pull the blade out slowly and listen for it to click into place.
Jul 24, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Adjust ladies citizen watch metal link band
If it is a metal link band, you can remove a few segments. Segments are connected by split pens. You should see a thinner end and a bigger end; or an arrow on the inside shows where the thinner end should be. Push the thinner end firmly with a pin or something until the big end pops out the opposite side.Use pliers to remove the pin.
Apr 12, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Take link ot of watchband
take it to a jeweler because if you do it your self your warranty is no longer valid
Jan 06, 2009 | Citizen Aqualand Duplex JP104009E Wrist...
Instruction manual
Go to this link and follow instructions for finding your particular watch movement and then lookup instructions.
http://www.citizenwatch.com/COA/English/settings.asp
Dec 05, 2007 | Citizen Aqualand Duplex JP104009E Wrist...
Citizen Eco-Drive BL006056H Wrist Watch Logo
1,035 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Are you a Citizen Watch Expert? Answer questions, earn points and help others
