Question about Yamaha HTR-5730 Receiver
Does the phlips fr 965 have a fuse
No power with unit pluged in
    Problem Solver:
  • 11 Answers
If the unit was purchased in the UK, then yes it will have a fuse witht the following specs:
BS1362 5 amp, A.S.T.A or BSI approved type
Otherwise, I would suggest that you bring it to an authorized repair shop.
Posted on Mar 23, 2009
How do I connect a Philips FR 965 digital
http://www.p4c.philips.com/files/f/fr965_00/fr965_00_dfu_nor.pdf Here ya go.
Oct 01, 2014 | Audio Players & Recorders
Fr 965 won't work with fiber optic
Check for dust blocking the sockets on the fibre optic ports.
Try a different optical cable.
If it's not working then maybe the old receiver is past it.
Sep 13, 2014 | Audio Players & Recorders
Why my subwoofer has no power?
It could be a fuse blown in side the unit. it could be a bad power supply. it might be a power issue. make sure you have power connected properly and all connections are made correctly.
May 07, 2014 | Creative new labs speaker inspire...
Philips fr 965 wont stay on
It is shot, Kiss it good buy, Repair will be verry costly, Just go end get a different one, End not anouther (Phillips)
Nov 28, 2012 | Philips Fr965 Stereo Receivers
I have Phillips home theater system model FR 965. When I turn the power on it powers up for a few seconds and then shuts off. I have done some searching online and found advice saying that it may just be...
It's not a fuse. Fuses don't self-heal allowing another try.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a possible root cause for intermittent shutdown.
Jun 11, 2011 | Philips FR965DHT Receiver
Console says replace belt unit even though I have minimal copies on the printer. Dell 3115 color laser
Hi
Try and reset the power to the printer and re-install check the toner cartridge. If this doesn't help then please try and reset the printer to default factory settings. Y?? ??n reset ???r Dell printer by using 'Reset Dell Printer' icon. Y?? ??n g?t t? th?? icon in folder 'UAN'--> 'Logic Utilities' -->Reset Dell Printer. Hope this helps... Please post back if you need more information.
Daniel
May 28, 2011 | Office Equipment & Supplies
I need to purchase the meade polaris model # 60az-d eye pieces that you use to look through the telescope.
You need to purchase .965 diameter eyepieces. 700mm ( focal length of scope)/ eyepiece focal length=magnification. Maximum power of a 60mm scope is about 225x (under perfect conditions)
I would get a 25mm 700/25=28x for low power see link below
http://cgi.ebay.com/Meade-MA25-25mm-965-telescope-eyepiece-NEW-/230542978572?pt=LH_DefaultDomain_0&hash=item35ad6eae0c
and then for higher power 700/8=87.5x
http://cgi.ebay.com/Astro-Optics-8mm-Deluxe-965-Telescope-Eyepiece-/230543763551?pt=LH_DefaultDomain_0&hash=item35ad7aa85f
There are not many options with .965 eyepieces I would get a .965 to 1.25 adapter or .965 to 1.25 hybrid diagonal. That way you have more options on better eyepieces and the 1.25 eyepieces can be used for better telescopes in the future.
Oct 31, 2010 | Meade Polaris 60AZ-D (120 x 60mm)...
Front red light comes on when pluged in, but no power the the tv
be sure all units are auto volt. if you plug units 110V to 220V it might be damage or fuse will blown up.
Jun 28, 2009 | Toshiba 23HLV85 Television
My phlips gogear will not turn even when i plug it in
try holding the up volume button and the power button until it powers up and see if that makes any difference for you.
if not the device may have a corrupt board as many other GoGear products similar to this one have the same problems
Mar 12, 2009 | Philips GoGear HDD6330 MP3 Player
Where is the fuse on a Philips FR 965 AV receiver
Hi Hibbs8829
Generally fuses are located on the PCB attached to the power transformer terminations. In some instances the only primary fuse may be a thermal fuse located inside the power transformer that may have failed. This one you cannot see from the outside. They are replaceable, but you will need to get into the transformer somewhat to sort it out. Other than that, there are often fusible resistors and circuit protector devices on the PCB. These can be a little difficult to find if you don't know what you are looking for. Good luck
regards
robotek
Jul 15, 2008 | Philips Audio Players & Recorders
Yamaha HTR-5730 Receiver Logo
65 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
