Question about Rheem 80 GAL ELEC TALL Water Heater 6YR SC 82V802
My water pipes froze thursday night so friday night when i went to bed i left the tubs hot water turned on and they thawed out about 2am i got up and turned the tub faucets off the water was hot at that time. when i got back up 4 hours later is only cold water coming out of the hot water tap. PLEASE HELP
  • josh1111 May 11, 2010
    are the pipes to your bathtub on an outside wall? if they are they may not be insulated good.
  • Thomas F. Schneider May 11, 2010
    Checked the circuit breaker for the water heater?
  • 68 Answers
You probibly ran the hot water tank out of hot water shut off the hot water comming out of your fausets for a few hours and check it again u could also try to reset your tank by pulling off the front cover and hitting the reset button and my last thought is sadly you burnt out your heating elements and they need to be replaced good luck man
Posted on Mar 07, 2009
No water on the hot side of line. Have rinnai gas tankless water heater. 22 degrees last night but had pipes wrapped. Have cold water pressure but not pressure on hot side. Tried to thaw pipes
You will need to have heat in the room to thaw pipes . Cold will come in from flue pipe and freeze pipes . its a slow thaw so pipes don't split .
Jan 18, 2018 | Rinnai Water Heaters
I have a Rheem warrior glass water heater model number 71-30 s in my mobile home. Recently had frozen water pipes and had to take the entire water pipe from the water heater to the main water box off to...
Before I spent the money on a new heater I would check reset to make sure it did not trip. I would also check element and make sure you are getting flow thru outlet and that it did not plug up with rust and mineral .
Depending on the water quality where you live I would expect to get at least ten years use out of a electric heater. Thank you.
Feb 10, 2011 | Rheem Water Heaters
Water doesn't flow from the hot side. Was really cold last night. Is there a way to get it to flow?
Yes... the water pipe is probably frozen... take a hair dryer and focus the heat on the piping...moving it back and forth along the piping to thaw it out...
Feb 03, 2011 | Water Heaters
I assume this is outside? A slow warm heat, would defrost it. If so, is there some way you can make a canopy of some sort to capture heat form say a portable heater of sorts? - Just encompass the tankless unit so it may defrost from the portable heat and you can see what is any damage has occurred and go from there..
Best regards
Jan 17, 2011 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Hot water is spraying out the plastic coupler that comes out of the water heater up to the pipe. Want to know if there is any way to fix this problem in expensively.
First thing to do is wrap rag or towel around spraying joint to localize water.
Next, turn off power to water heater.
If gas, rotate knob to pilot so pilot light stays lit but burner does not come on
If electric, turn off circuit breaker.
Close cold-water shut off valve above tank.
Open tub valve to release pressure on water heater.
Wait for water to cool before working on water heater to avoid high pressure scalding water.
When finished, make sure tank is full of water and water comes out of tub valve before turning on power.
Water heater should not have plastic couplings.
I can't see your problem exactly, but water heaters have 3/4" nipples coming out of top.
Easiest solution is use flexible connectors from Lowes or Home depot.
Flexible connectors are 24" or 30" long and have 3/4" nut on each end, so disassemble existing pipes using pipe wrench.
Lowes and Home depot can help you select appropriate pipe >> take several phone-photos of your pipes to home center so they can see your problem precisely.
Attach 3/4" male adapter on end of pipe.
Attach flexible connectors between pipe and water heater nipple.
Cold water line has shut off ... make sure this attached to nipple marked cold.
Make sure hot pipe is attached to nipple marked hot.
Use teflon tape on threads.
Add a comment if you need more help.
Dec 09, 2010 | Rheem Water Heaters
Too much water draining from Vulcan Electric H/W relief valve.
Dear Julie. Do you have an expansion tank installed? If so it is probably waterlogged. If you come home shower etc. use lots hot water then go to bed or leave the cold water in your tank heats and expands as it heats. In the old days a toilet ballcock valve would relieve this pressure but modern toilets with diaphragm valves wont so the pt valve relieves pressure. Installing an expansion tank on the cold water line near the heater will absorb the extra water & stop the pt valve from activating.
Dec 29, 2009 | Water Heaters
Combi Boiler - Hot water pressure low
the coil inside got clogged
Dec 22, 2008 | Water Heaters
Rheem 80 GAL ELEC TALL Water Heater 6YR SC 82V802 Logo
96 people viewed this question
Top Rheem Water Heaters Experts
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
