Question about Dell Inspiron 1525 Notebook
My Dell Inspiron 1525's touch pad is not working properly.
It is not responding when I tap the pad, Every time I have to press the left or right key in the pad. How to restore this performance?
  • Anonymous Mar 30, 2009
    cursor is not responding to the touchpad at all.....
  • shnitle Apr 06, 2009
    cursor doesn't move when is supposed to
My dell touch pad is not working.pls check the problem urgenty pls reply thanku
Posted on Dec 20, 2009
    President:
  • 2,653 Answers
Let's try resinstalling the touchpad software first:
If you're using XP it's HERE
If you're using Vista it's THIS ONE
Let me know if that works.
Posted on Feb 28, 2009
How to work key pad
Key pad? Do you mean the keyboard or what?
Mar 21, 2016 | Dell Inspiron 1525 Notebook
Can't right or left click on inspirion 1501, touchpad is fine.
It would appear that the left/right touch pad buttons have failed. You will have 3 options at this point in time.
1) Use an external wireless mouse such as a Logitech Wireless Mouse M505 for roughly $39.99
2) Use alternative features on the laptop. Left click is typically simulated by tapping or double tapping the touch pad itself and right click can be simulated, in most cases, by single tapping the icon and pressing the pop-up menu button, typically located between the right alt and ctrl buttons.
3) Search for a replacement component online and replace the component. Touch pad replacement will require you to remove all casing screws from the laptop and then remove the case. You will then expose the screws and cabling for the touch pad. I can not give more detailed instructions as this varies per laptop model.
Sep 21, 2011 | Dell Inspiron 1501 Notebook
Typing on a DELL Inspiron 1525 keyboard, the typing often appears somewhere else to the left on the line or a couple of lines up.
This problem can be very frustrating! It is typically from you hand moving over the touch pad to type on the keys. It would be lovely if they weren't designed so. To reduce the problem change the sensitivity of the touch pad to a lower level so it is not as sensitive.
Mar 04, 2011 | Dell Keyboard for Inspiron 1420, 1520,...
How do I darken my computer on the Dell Inspiron 1525
Hold the "FUNCTION" key down and tap the LEFT ARROW key to darken, tap RIGHT ARROW key to lighten the screen.
Good Luck
Jan 06, 2011 | Dell Inspiron 1525 Laptop Computer PC...
Left click key doesn't bounce back when clicked. Seems stuck
The key is stuck you have to be very careful if you are going to attempt to repair this.Turn the computer off and remove the battery before you attempt to repair it.Try prying it up with a thin knife blade.If this pops up and is working make sure it works as good as the other side.If not you will have to replace the palmrest.
Good Luck
Mar 21, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Touch pad not working on Dell Inspiron 1525
My daughter has the same laptop and I went to Dell's web site and checked on the parts to buy. The keyboard kit that came with a new touch pad would be around $119.oo. She is going to wait until next pay day. Check it out and have a friend replace it, if you do not want to.
Dec 30, 2009 | Dell Inspiron 1525 Laptop
How can I lower the brightness of my screen in my Dell 1525 lapto
Sometimes the brightness is on the arrow keys hit the Fn or function key and press down on the arrow to dim the light or press up on the arrow key to increase brightness
Jul 28, 2009 | Dell Inspiron 1525 Laptop
How to clean inspiron 1525 touch pad
Hi there.
The touchpad itself is easy to clean but if the liquid has got into the left and right click keys you may have a problem, a warm soapy partially dry cloth will take the residue off the touchpad but the soda may have got to the circuit board causing it to be slow to react.
To clean the left and right keys and under the touchpad you have to take the laptop apart, remove the keyboard and the front cover and clean under that where you can get under the left/right click keys and the ribbon cable of the touchpad.
This type of job is not for the novice and i would advise having a technician do it whether it's in or out off warranty, preferably Dell themselves.
Other than that the best option would be to buy a wireless or wired mini mouse which are much easier to use than the touchpad itself.
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
May 19, 2009 | Dell Inspiron 1525 Laptop
Laptop touch pad mouse does'nt work while charging
my toch pad dont work when my laptop is charging i have inspiron 1525
Feb 26, 2009 | Dell F3534 Touchpad
Had a new hard drive fitted to my Inspiron 1525 today. Now the mouse pointer does not seem to work so can't drag anything. Cheers
it has been disabled because of bios refreshing try finding the key around the keyboard sorry i don't know which key should you press but i know that laptops has function keys that would enable the touchpad that's what i've learned from this site
Dec 31, 2008 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 Notebook Logo
1,849 people viewed this question
Alun Cox
