Question about M-Audio US85100 Keyboard
I have M-Audio session with fast track... every time I try to open the program I get No M-Audio Hardware found. Session will now exit. I uninstalled and the reinstalled. This program was working find and then started to mess up
3 Suggested Answers
SOURCE: i keep getting no m-audio hardware found
change that cord then boot the computer with the USB  hooked up good luck
Posted on Dec 06, 2007
SOURCE: Working with Vista
M-Audio Session is looking for the USB device, e.g. "Micro" or "Fastrack"
Posted on Jun 27, 2008
Toc error 14
On questions like this it would help if we knew the manual was or was not consulted.
And if it was NOT, why.
C14 / TOC Error The unit did not read the TOC information. Insert other discs.
http://www.cdrfaq.org/faq02.html#S2-19
[Extract]
"If you write data to a disc and leave the session open, the TOC -- which tells the CD player or CD-ROM drive where the tracks are -- is written into a separate area called the Program Memory Area, or PMA. CD recorders are the only devices that know to look at the PMA, which is why you can't see data in an open session on a standard playback device. CD players won't find any audio tracks, and CD-ROM drives won't see a data track. When the session is finalized, the TOC is written in the lead-in area, enabling other devices to recognize the disc.
(Something to try: write an audio track to a blank CD, and leave the session open. Put the disc in a CD player. Some players will deny the existence of the disc, some will spin the disc up to an incredible speed and won't even brake the spindle when you eject the disc, others will perform equally random acts. The TOC is important!)"
Mar 02, 2011 | Sony RCD-W500C 5-Disc CD Recorder
Digidesign 002 rack
first of all uninstall the programme switch off your pc and remove the sound driver putit again and check that all wires you put are complete now turn your pc on and install the driver again. so try this one if problem persist cointact me .
Dec 04, 2007 | Computers & Internet
Hi, I have intel SSR212MA and data on it. I reinstall DOM, How can i assign IP to SAN and restore data? Regards, Anees UR Rehman
Hi ,
Bro Attach a serial cable to the storage system and connect to a laptop. Open a terminal emulation program to run a text interface, such as HyperTerminal* or ProCommPlus*. Use the following settings to configure your session:
  • Bits per second = 19200
  • Data bits = 8
  • Parity = None
  • Stop bits = 1
  • Flow control = None
  • Backspace key sends = Del
  • Emulation = ANSI
If using HyperTerminal, set the properties for the backspace key and emulation after the session is established. If you exit the session and return to the session in order to use the Configuration Interface, the screen will not open correctly.
Feb 23, 2011 | Intel SSR212MA Hard Drive Array
Gaps and noises in my Session recording
Is it bus powered? If it is only plugged into the USB port and not also into the AC outlet, it may be because your USB port does not supply enough voltage or enough current. USB is spec'd at 5V, 500mA, but many fall short. I have the same problem with a Tascam US-122. I haven't tested yet, because it doesnt have an external power port. I would need to splice 5V power into the USB cable.
May 25, 2010 | M-Audio Audiophile USB Audio and MIDI...
How do i stop tha tracks from skipping, because while im recording tha audio tracks seem to skip
Depending on whether you are using recording software and what kind you are using you are experiencing what is known as latency. It happens when your computer is not fast enough to keep up with what you are recording. More RAM sometimes helps. Sometimes it is just a simple adjustment. It is too long a subject to go into here. Try looking at Audacity which is freeware. There is a good explanation on their site. Also, I would recommend Asio4all. Hope this helps.
Oct 21, 2009 | M-Audio Producer USB Microphone with...
It cannot find hardware.
Not expert on this but......First make sure drivers are installed properly, Next connect to computer via USB. Next look to see if a popup on the taskbar says something like "Failed to connect etc." If so then open CONTROL PANEL.....Click on SYSTEM....Click on HRDWARE...Click on DEVICE MANAGER.......And then look for any YELLOW QUESTION MARK or MARKS......And / Or...Click on the USB Symbols to see if the BAD USB Shows its-self . Opening Any of these bad connection symbols will inform you if the DRIVER is installed properly, and will give you the options to UPGRADE or INSTALL etc.If this does not work the try the following:- Click on CONTROL PANEL. Click on Add-Remove Hardware and follow the on-screen instructions (While the device is plugged into the USB) All of the above simply is verifying that the drivers are or are not installed, but at least it will be a starting point.
Aug 06, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
Getting rid of Aloha Bob's PC relocator
to get rid of a program , go control panel, programs and features , high light the undesired program and uninstall
there may be other lines from the same company so high light them one at time and uninstall them as well
Nov 07, 2017 | Eisenworld Alohabob PC Relocator Ultra...
Mbox cannot start new session or load in old sessions.
Digidesign website had the answer....go to windows,show workspace and change the settings for your relevant disc from transfer T to R...record in the A..audio column.
Thanks  Bobcat8
Oct 07, 2008 | Digidesign Mbox External Sound System
Working with Vista
Jun 21, 2008 | M-Audio Session KeyStudio USB Keyboard
Error
sounds like your missing a file mite try unistalling it and reinstalling it .lala linda
Jun 01, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Open Questions:
See all M-Audio US85100 Keyboard Questions
M-Audio US85100 Keyboard Logo
46 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
