Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Only hot water is coming through the washing machine
The washer has been set to do a cold wash but only hot water is coming into the machine?
Make sure the hose is not plugged,and if you have hard water claen the skreen,i had the same problem the skreen was plugged.
Posted on Mar 01, 2009
Only hot water is coming . cold water none
Ensure the hose's at the back are in the right places, Could be you or the fitters has put them in the wrong place.
Feb 20, 2012 | Kenmore Washing Machines
Hi I have a problem with my Kenmore washing machine,in particular I can not use hot water anymore. When I use my washing machine hot water does not stop at set water filling level (law, medium,high)...
Please post the model number for your washer. It sounds like your hot water valve has failed and is not closing. Unplug your washer's power cord and turn the hot water spigot that comes out of the wall on. If you still get water filling your washing machine, it's definitely the washer's valve and you will need to install a new set (hot and cold valves are both part of the same assembly).
Mar 11, 2011 | Kenmore Washing Machines
What is the F20 error code?
F-20 error code in Whirlpool Duet Sport washing machine is indication of inadequate water supply. Check both hot and cold water supply lines to make sure machine gets enough water intake. If you do not have a hot water supply to the machine you can only run it with the cold temperature setting. This machine does not have an internal water heater and relies on the hot water supply from the house water heater.
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
hey Paul, you don't have to wash anything in hot water. Hot water only wastes money and does nothing, in my opinion, to get anything cleaner. It does ,however set the stains. To kill any thing the water has to be 212 degrees [ boiling ]I have not used hot water for over 40 years and our clothes are coming out clean. Just set the machine on cold. I put a twoway spigot on my cold tap and put the hot water and cold water together incase someone breaks in and does my laundry. Barry
Feb 14, 2009 | Haier HLT364XXQ
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My Admiral Washing machine only runs the hot water (not cold)
the water temp switch is bad call aplience parts store in the area
Nov 25, 2008 | Admiral AW22 Top Load Washer
Washer only washes on hot
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
  • Nov 06, 2008 | Roper RAS6233KQ Top Load Washer
    Maytag washer
    It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
    Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
    No hot water to wash
    Is the hot water hot that is coming to the washer? Are you using the correct settings on the unit? If yes to both then either the solinoid water valve is bad or the timer switch unit is bad. Try going to a totally hot water setting. While turning on the machine feel of the hot water line at the machine and see if you notice a buzz or feel a click as you turn on the machine. On this setting does water run in and is it hot or cold. If water runs and it is cold try going to a total cold setting and see if you get cold or hot water. Is this a new setup or has it been working and stopped? If new, you could have the hoses connected backward. If you get water in both hot and cold settings but cold both ways then your hot water heater is not working....let me know....
    Feb 10, 2008 | Frigidaire FEX831CS Top Load Stacked...
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    50 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
