Question about Whirlpool GHW9150 Front Load Washer
Whirlpool duet has water pouring out of the part that the detergent goes
    President:
  • 1,294 Answers
If this is when the spin is on, there is something clogging your pump. After taking the plug off the mains, open up the machine's pump to clear the block. You can do this yourself. There is a panel in the lower of washer; 3 torx screws beneath the panel.
Posted on Mar 31, 2009
  • 20 Answers
Send it back thats wired just send it back dont no nufink else and get a your money back
Posted on Feb 28, 2009
My whirlpool steam duet washer won't pour water in the wash cycle
There is no output from the control panel to switch on the inlet valve, so check the inlet valve at this time of the cycle. Also check the water level pressure sensor switch.
Choose another program to confirm if not the controller seems to be suspect.
Jan 24, 2013 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
The issue with my Duet currently is that it begins to fill, then water starts to flow out of the detergent drawer. I suspect an obstruction somewhere near the intake hose leading to the drum. Unless of...
Try using a piece of springy wire, such as from a coat hanger to clear the blockage. Put a loop at the end of the wire to prevent the sharp end from sticking through the intake hose. There are products available for cleaning the drain outlet on sinks consisting of springy wire which may be of use. The only danger is that they may get stuck in the intake hose especially if it has a corrugated interior surface.
Probably the best thing to do first is to remove the detergent drawer and pour hot water, not boiling into the space where the drawer goes. You may need a funnel or a bottle with a long neck to do this. The hot water might be sufficient to dissolve any powder build up.
Mar 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport WFW8300SW02. Water pours out detergent disp
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%%%%
Oct 17, 2009 | Whirlpool WFW8300SW
Whirlpool Duet Sport Leaks from under detergent dispenser
there is a hose that runs from the soap box to the drum to let the water into the drum if it is not connected or has perrished then that would explain the waterfall
Jun 11, 2009 | Washing Machines
Water is pouring out of the detergent part of the washer
The first thing you need to do is to slide the detergent drawer out, look down inside the compartment and see if its clear of obstructions. If it is, then the next step is to look inside the boot around 10:00 - 11:00 O'clock. You will probably find something there (like a sock) This is obstructing the inlet water and causing the water to back up through the hose/drawer. you should be able to fish it out easily enough with either your hand or needlenose plier.... Hope this helps... Bill
May 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water pouring out of the detergent holder duet sport
you have an article of clothing stuck between the tubs. run your hand around between the tubs and you will probably find something at about the 11:00 o' clock position.
Jan 13, 2009 | Whirlpool WFW8300SW
Water pours from detergent basin-Whirlpool Duet Sport
first remove dispenser pull out and make sure its not clogged inside,w/ hand fill around ,, on any frontload machine i perfer liquid soap,, are you using HE detergent
Jan 03, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Water coming out of the detergent compartment
When you take out the drawer you can reach inside and at the front of that compartment there should be an opening where the water goes into. I have seen many times where something is blocking that opening. The only other thing would be something stuck in the hose that attaches to that opening and feeds water to the tub. It sounds impossible but I have pulled underwear and socks out of that hose several times. Best way to access that hose it to take the outer clamp off of the door boot and reach in there, disconnect the hose and pull it out. Getting the clamp back on can be a little tricky if you haven't done it before so it may be best to call for a technician. Hope this helps.
Dec 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water pouring out from the detergent dispenser
Remove the washer top panel by removing the three screws in the back of the washer that hold the panel in place. With the three screws removed, the panel will slide back, then lift off. This will give you a full view of your dispenser and components. I strongly suspect that you have a hose leading from the dispenser to the fill tube along the door that may be either kinked or clogged. Inspect the hose for any kinks. You may have to remove it and flush with hot water. Let me know what you find. I hope this helps.
Sep 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9150 Front Load Washer Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal De
