Question about Sony MDS-JE320 Mini Disc Player
Sony minidisc MDS-JE320 Clicking problem
When there's no disc, the player starts making a very annoying clicking sound. I've opened the case and it seems like a gear is making this noise (it's standing still and another gear is moving against it).
How can i solve this. When a disc is inserted, everything is ok. Only when the disc is ejected, the clicking noise appears.
I had the very same problem with my MDS-JE510 and I found out that it has something to do with a sliding plate that comes forward and stops too far. It is a metal pin that could be bend (very, very little) to the frontside of the recorder. I put a paper between the pin and the stopplate and the problem was really gone. Now I bend the pin so it stops earlier and voila, everything works super fine. I can send a picture of the pin, I made. It's n the leftside of the disc-unit. The only thing you have to do is open the upper cover (5 screws). Tell me if you would like to send me the picture OK? Ronnie Janssen.
Posted on Nov 21, 2009
  • momentueel Jan 13, 2011
    I suppose it is quite late, but jansser could you please post that picture you mentioned!
  • DaFu
    DaFu Mar 26, 2015
    I'd love to have it also....
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
you seem yo have a problem with the disk positioning/insertion switch, the switch may have become misaligned or it has become intermittent. The switch is located on one of the circuit boards that is attached to the drive mechanics. It may not be easy to get to it without dissembling the entire player. You may want to download the service manual and have a look to see the placement of the switch. Here is a similar player service manual for your reference.
Hope this helps you.
Cheers
Posted on Mar 01, 2009
    New Friend:
Fixed it.... Bending this part towards the switch a bit helped.
Sony minidisc MDS-JE320 Clicking problem - sony-minidisc-mds-je320-clicking-problem#-wxd0nmgxg0eifbnojvrfur5b-3-1.jpg
Posted on Mar 28, 2015
  • DaFu
    DaFu Mar 28, 2015
    pictures here (hopefully)
Stuck in eject
Wow. A cheap MD deck from 1998. Brings back memories.
The last time mine did that the sticky label came off and jammed up the mechanism.
Take the cover off and see what you can do by hand. Be REAL careful not to touch anything that looks electrical!
Jun 13, 2012 | Sony MDS-JE320 Minidisc Player/Recorder
Is there any other remote that will work with Sony Mini Disc Player & recorder model mds je-320
Most Sony MD remotes will operate most functions on this unit, almost all of the Sony MD remotes are available on ebay even the rare ones.
Jul 01, 2011 | Sony MDS-JE320 Mini Disc Player
I have humming noise from earphones connection Minidisc MZ -N1
Are you using an AC adapter, or running it on batteries? If 'wall-wort' AC adapter, that's the issue. If you're running it on batteries, sounds like a bad ground, try different earphone/headphones and see if the hum goes away. With the 2nd pair of headphones/earphones, does the hum go away, or if you wiggle the headphone jack back and forth a little bit?
May 02, 2010 | Sony MDS-JE320 Mini Disc Player
MD player windows keep saying "no disc" when a disc is inserted. This started after the door starting getting sticky opening and closing. Any help would be great. Thanks
The little switch that detects the disc is inserted goes bad quite often on all of these sony home MD recorders. Do an online search as I have seen a step by step approach on it's repair. Make sure to UNPLUG the unit before removing any covers and poking-around inside. Good luck,
Jan 17, 2010 | Sony MDS-JE320 Mini Disc Player
MDS-JE320
The loading mechanism needs to be repaired or replaced. This is a common fault. Unfortunately, this is not a really cheap fix. Usually the loading carriage needs to be replaced at a cost of about $40 or so/
Dan
Nov 10, 2008 | Sony MDS-JE520 Mini Disc Player
3 connection leads inside
These are ground wires and can be attached to the chassis anywhere where they will fit.
Dan
Aug 18, 2008 | Sony MDS-JE320 Mini Disc Player
Clicking noise
Yup, you are right, the plastic gears are broken. You can buy new once and install them yourself or find a local repair shop that can do this for you.
May 08, 2008 | Sony MDS-JE320 Mini Disc Player
Problem with the mds-je320
Hi there, it seems that one of the sensors is bad. Please contact me at LIVE session. Arpi
Sep 30, 2006 | Sony MDS-JE320 Mini Disc Player
Sony MDS-JE320 Mini Disc Player Logo
1,569 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
