Question about IBM ThinkPad T30 2366 Notebook
I just tried to install 1 gig of ram on my IBM T30 Laptop, easy right, well now I get nothing on my screen, so what went wrong if it was so easy. Please help. Thx BJ I tried to increase ram to 1024mb on my IBM T-30 computer (23669U). According to specs it should take it. I have inserted 2 512 chips but the computer still only reads 512mb. Please advise.
  • Thomas F. Schneider May 11, 2010
    Are you sure that the ram was of the correct speed?
  • 679 Answers
It may require either or both of these, since I can't see the laptop, I'll give you both, first and easiest, is go into the bios, and look in the system settings, see if the memory/ram is set to auto it may be set to a specific amount or speed, f 10 your way out and save the settings, hopefully that will fix the problem, if not then unplug and remove the battary, open the base and remove the little cmos battery looks like a coin, wait 5 min and replace, that is where your settings are saved when the machine is unplugged. Restart after putting everything together, then you may have to go and enable your custom settings, but the memory should show the new stick you installed, If not it's possible you have a bad stick, it won't be the first time, good luck
Posted on Feb 28, 2009
IBM T30 Thinkpad 2366 wireless network I inheirited a IBM T30 laptop from my wife. She haad it loaded up with so much **** and it was extremely slow. My fix was to format the drive and reinstall Windows...
You need to download the drivers for your Netgear.
The IBM drivers also need to be found,Depending on your model, it may have WiFi. From IBM spec sheet:
  • 10/100 Ethernet installed on the system board
  • Selected models will have Intel Wireless and modem Mini PCI combo cards
  • Selected models will have CISCO Mini PCI card
  • Selected models will have Bluetooth communication daughter card
Nov 01, 2011 | IBM ThinkPad T30 2366 Notebook
Can the IBM T30 2366-21U run windows 7?
IF UR NOTE BOOK IS OF CONFIGURATION MINIMUM OF 2 GB OF RAM AND AND IF THE SPEED OF THE PRCESSOR IS 2.8GHZ ABOVE THEN U CAN RUN WINDOWS 7
Sep 13, 2010 | IBM ThinkPad T30 2366 Notebook
My ibm t30 will work with it 256mb ram all the time, but the 1gb ram only works some of the time.
It seems 1 gb ram you have tried to install is not compatiable with this ibm t30. I will advice you to check the type and frequeny of 1gb ram you bought it will be written like DDR 400MHZ OR pc2 533/667 MHZ please check these two things and it should be matching with the original 256 ram which was working.
Apr 12, 2009 | Computers & Internet
Put the original memory back in and see if the laptop starts up. If it does, you may have chosen modules that were not designed for the laptop.
Feb 25, 2009 | IBM ThinkPad T30 2366 Notebook
HDTV as monitor via VGA
Could be that it's to old to support
you can try to put new driver on sounds like it's an older version
Jan 07, 2009 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30
Try starting without the battery, and cheking the memory chips.
Jul 04, 2008 | IBM ThinkPad T30 2366 Notebook
IBM T30 - no screen - sortof booting
i own a t-30 myself with all the same problems i am reading about not reading ram beeping on startup no screen display but you could here hard drive running before these symptoms started the first symptom i ever noticed was if i picked the unit up with my left hand on the left front corner to move it it would boot down and then would not re boot properly (no screen, beeping) until i would smack the case then it would boot fine note: ram slots are located in the left front corner. I always assumed i had a cold or broken solder joint on the main board the last week the thing started running flakey i noticed i was only reading one of my 256mb ram chips so i powered down switched the two chips to the other ram slots and rebooted i noticed one chip was really warm the other cold the comp. booted up perfect and ran perfect for 2 hrs. same prob. so i bought two new 512mb chips installed the and have had none of the above listed problems ever since
Dec 17, 2007 | IBM ThinkPad T30 2366 Notebook
Lenovo memory problem
crucial wasn't the problem.
the problem was solved by me doing a bios update.
they shipped the unit with the pci configured for 1 gig.
not 1.5,2,3 or 4.
I had to go for broke and pray that the 63af08 update had something in it,they said nothing about a memory upgrade period!
Here are 2 links for the solution. WHEW!
c.gif Lenovo Support & downloads - BIOS Update Utility - 3000 C200, N100
Specify AdRomLdr.exe with the full path name where you extracted this package and click OK. Example: C:\DRIVERS\WIN\FLASH\63af08US\AdRomLdr.exe Follow the instructions on the screen. After the update has been completed, the computer will restart
URL: http://www-307.ibm.com/pc/support/site.wss/document.... c.gif c.gif 2. c.gif BIOS Update Utility - 3000 C200, N100
URL: http://www-307.ibm.com/pc/support/site.wss/document.... c.gif c.gif c.gif c.gif
Dec 12, 2007 | Lenovo 3000 C200 Notebook
IBM ThinkPad T30 2366 Notebook Logo
79 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
