I have the Toshiba DVD/VHS recorder-player and was wondering do I HAVE to use RCA plugs to get it to work? or will any manufacturer's yellow/white/red video plugs work?
  • 3 Answers
RCA plugs & yellow/white/red plugs are the same. They refer to cables used to transmit 'Composite' video (yellow) and stereo audio (red & white). RCA is the buzz word for the type of connectors they use. Probably invented by the company, RCA.
Posted on Feb 28, 2009
I am trying to copy VHS to DVD [using quality DVD-RW] but keep getting screen message of NO SIGNAL - Please check connections.
Hi try this set up to check if you're scart set up isn't the problem connect 3 rca lead to the output of the vcr into the input of video recorder then plug 3 more leads from output of video recorder into the TV set you're TV to AV INPUT AND set YOURE VIDEO RECORDER TO THE CORRECT INPUT MODE ...good luck
Aug 03, 2015 | Televison & Video
Want to copy vhs to dvd.
I convert VHS to DVD using a Toshiba DVD Recorder that I purchased from Costco a few years back. I plug the VCR into the DVD recorder using RCA jacks, press PLAY on the VCR and REC on the DVD recorder and let it sit and record. I can record up to 8 hours of video onto one DVD at low quality. After this, I finalize the DVD so it can be read on other DVD players.
Jan 03, 2012 | Hitachi DV-PF33U DVD Player/VCR
Dubbing from vhs to dvd but when trying to playback dvd it comes up blank
Install all three 3 RCA plugs to output of vcr,, other end of wires 3 RCA wires plug into right front of recorder then push record. Be sure red to red, white to white, yellow to yellow or you might have a bad RCA cord. Remote set source to E2.
Apr 12, 2011 | Philips DVDR3505/37 DVD Recorder
I have a Toshiba DVD Video Recorder. How do I record from a VHS to a DVD?
For a toshiba DVD player there should be a s-video input. For a vhs you must have a vhs player that has a component/s-video output. Hook up the vhs player to the dvd recorder using an s-video cable and press play on the vhs player. Then press record on the dvd recorder.
Feb 28, 2011 | Toshiba Televison & Video
How to connect the toshiba to a rca tv with direct tv
do you have dvd in jacks on your rca...direct tv out to dvd in.....(this setup u need to scan for channels on the dvd)..note some premium channels will not record on dvd (will and still record on vhs)
May 29, 2010 | Toshiba DR410 DVD Recorder
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
DVD VHS Recorder setup.
hi there, a little late.....but here we go........do you have cable? if yes connect the cable from the cable box out to dvd in and connect the dvd out to tv in.......pls note the dvd and tv must be set/tune to ch #3.(and you cannot record HBO)......you dont have cable just tv and dvd you need rca wire (red,white & yellow) also the F connector wire....in back of dvd connect the 3 wires audio in video in (is your tv/monitor a flat panal these connections might be on the side) if not its in the back plug in to out on tv....(this is so you can record)....plug the F conncetor wire from dvd to tv......on this connection you can set the dvd to ch #3 or any ch you want to record...........
Jul 19, 2008 | Toshiba D-VR4 DVD Recorder/VCR
VCR, DVD, TV Connection
first let me say that a dvd player and a dvd recorder are different. the dvd player can only play dvd while a dvd recorder can both play and record dvd that is said. what i understand from what you write is currently is - out of your tv box into your dvd player then out of your player into your tv........ ok some dvd has two connections. line one and line two if your tv box is in line one then you should plug the rca cable in line two in. then you select line two on the dvd player then plug the other end to your vcr in line out so that is out of your vcr into line two of your dvd player.(some times one of the connection is at the front of your player hidden) if your dvd player only have one connection then you would have to plug out your tv box and replace it with the vcr cable and when you finish coping your vhs tape you plug in back your tv box to your dvd player. hope i could help.......... Tracy
Apr 02, 2008 | Televison & Video
Dvd not recording
One touch function won't work from pre recorded VHS tape. Go to
www.RCA.com under this dvd model and read the first line.
Secondly you will have a better luck to use sony dvd+r .
Good luck
Nov 22, 2007 | RCA DRC8335
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
