Question about Sharp Computers & Internet
Monitor sharp ll172a turns on then off to stand by backlights test ok no shorts to be found think might be mem chip can yo u help dave.
  • 32 Answers
Ive had this problem a few times.and it has come down to a bad memory card.or turn off pc remove memory card clean it with an eraser then replace it..it shold work..steve card may be shot period also if it doesnt work.steve
Posted on Feb 28, 2009
F2-04 error on sharp machine AR-M205
The code you have indicates there is a problem with the communication chip within the toner cartridge. The only solution I can think of is to replace the toner cartridge with a new one. Make sure you turn off the machine first, then swap out the toner cartridge then power back on.
Hope this helps.
Dave.
Jan 30, 2017 | Sharp Office Equipment & Supplies
I have sound but no picture on my Sharp Aquos tv.
Do a flashlight test on the screen. With the TV on shine a flashlight on it and look for a dim picture. If you see it, the ballast board for the backlights is bad. If you don't see any movement, the T-Con board is bad. You can get parts from here and fix it yourself. TV Parts Universal TV Stands DLP Chips ShopJimmy
Oct 25, 2016 | Sharp Televison & Video
Model no. 32A33M LCD sharp tv, 32 inch, of serial no. 804734030. no picture shown. only sound is coming. i can decresing/increasing the volume. what can be the problem .
Do a flashlight test. With the TV on and a program is playing, shine a flashlight on the screen. Can you see movement in the picture? If yes then the backlight drivers are not working. If NOT, then the T-con board is bad You can get parts from here : TV Parts Universal TV Stands DLP Chips ShopJimmy
Jul 09, 2014 | Sharp LC-32A33M LCD TV
Gigabytega-ep35c-ds3r loud beep
The beeping sound is a sign of malfunctioning MEMORY CARD.
Just replace the mem card......
Hope that helps and tell me if there are more probs!
Nov 09, 2011 | Computers & Internet
Only Power LED on when power on
LED is on that indicates the power supply is working, so most likely you have there problem with inverter/backlight. To see easier how backlight behaves, unplug flat cable from processor board, so display itself won't be powered and light will go through it. Now if you turn on the monitor you will see the screen turns white for some short time and then turns off again. That's because CCFL driver chip turns into protection.
If you won't see any light, check the fuse on inverter and FETs in primary of inverter transformers.
If those are ok, next, you can localize the lamp, causing the problem - disconnect them one by one substituting with 27pf 3kV capacitors (equivalent load) and try turn on again until white light will stay for longer (while the controller is recognizing the signals from VGA input).
Post here the picture of inverter board (from the driver chip side).
Sep 10, 2009 | Planar PL2010M 20" Flat Panel LCD Monitor
Monitor dark but can see image in background
if u have warrenty then immediately contact u r dell service.
he check the problem and replace new one.
i also suffer same problem.
Jul 28, 2008 | Dell E173FP 17" LCD Monitor
Monitor not working...sorta
I just changed my video card and after turning up my screen refresh rate (Hz) my monitor started doing the same thing. Monitor worked great for a long time but now its done! The only thing I can think of is that it has to have 60Hz, turn it up for gaming and its too sensitive to frequency. By the way, mine will turn on after a few power cycles.
Dec 01, 2007 | Mag Innovision LT776s 17" LCD Monitor
My ben t705 moniteur.... problem
I DID REPAIR A MONITOR WITH THE SAME PROBLEM. IT TURNED OUT, THAT ONE OF THE TWO HIGH TENSION GENERATORS FOR THE 2 LIGHTTUBES WAS BURNED OUT. BY REPLACING THE POWER TRANSISTORS AND THE 3 AMP. FUSE ON THE MAINBOARD THE MONITOR IS RUNNING AGAIN VERY WELL.
Nov 22, 2007 | BenQ T705 17" LCD Monitor
Computers & Internet Logo
46 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
