Question about Homelite Consumer Products Tiller Attachment
Homelite Garden Tiller Model No HTC-12 UT22093A
I need to replace the Switch assembly with mounting plate
Part No 01075 15
4 Suggested Answers
  • 6 Answers
SOURCE: looking for a primer pump for Homelite htc12 tiller
Hi, I live in cedar rapids, Iowa. I just bought a primer bulb for my htc-12 homelite tiller. You should be able to order as many as you need, but I don't have the part #. Find out what the part # is and call this # 1-319-393-0443. They have 2 sizes, the bigger one is for the chain saws, the small one is for the tiller.( they have both) Carefully pry the plastic band off the primer bulb, press the new bulb through the band, then go get a tube of permetex weather strip adhesive ( orange box, black adhesive). Don't buy any other brand!. Lay a thin bead around the base of the bottom of the ring, press into place and let dry for a couple of hours. This adhesive works on almost any thing, and is not affected by gas, oil, or anything.
Posted on Mar 31, 2010
SOURCE: manual for Homelite model#ut60526
Not sure exactly what you need out of the manual, but if you are looking for schematics/parts list here is a .pdf document online that has the tiller broken down. Hope it helps.
http://www.ereplacementparts.com/images/homelite/UT-60526.pdf
Posted on May 15, 2010
hunter19_46m
  • 7482 Answers
SOURCE: homelite htc 12 tiller.. motor
Hi bh1149...
You have bad gears on the inside of the tiller gear box...
I had this same problem with mine.
You will have to take the gearbox apart in order to know what parts are bad.
Be sure to check the lube more often when you install the new gears/parts.
Go to the following website and order your parts.
Please take time to rate me
http://www.ereplacementparts.com/homelite-parts-c-18807.html
Posted on Sep 09, 2011
Testimonial: "very helpful "
Homelite tiller cultivator gear box disasembly
Contact Homelite directly and request an assembly drawing. Follow it in reverse for disassembly.
Jun 04, 2017 | Homelite Garden
Homelite htc 12 tiller.. motor runs ok but tines wont turn under load free wheeling they turn but under load no clutch?
Hi bh1149...
Sep 08, 2011 | Homelite Consumer Products Tiller...
Homelite tiller htc-12 carb adjustment How to adjust carb
I would like to refer you to an excellent tutorial by one of the major 2-stroke diaphragm carburetor manufacturers. This will tell you how to adjust and " tune " that carburetor.
http://www.zamacarb.com/tipspage.html
May 05, 2011 | Garden
Manual for Homelite model#ut60526
Apr 23, 2010 | Homelite Consumer Products Tiller...
Looking for a primer pump for Homelite htc12 tiller
Apr 24, 2009 | Homelite Consumer Products Tiller...
Tines won't turn.
Sounds like you hit something (like a rock or a big root) to make it Stop suddenly and smash one of the gears in the housing, The shaft that runs through the housing has a brass gear that is easily damaged when it comes to a sudden stop from hitting something. Snow blowers are famous for this problem.
Apr 17, 2009 | Homelite Consumer Products Tiller...
Both belts shredded. Atlas garden tiller model 12 -5100
I bought a repair manual from Clymer and found the belt sizes for my Atlas 12.5022 tiller. The manual lists a 1/2 inch by by 36 inch forward belt and 1/2 inch by 32 inch reverse belt for the model 12-5100. Good luck. Don't bother to buy the Clyme manual. It isn't very complete.
Bob Mortimer
mortimer5918@bellsouth.net
Mar 24, 2009 | Garden
Homelite htc-12 tiller starts but tines won't turn
No I don't need any help with this problem. I oiled it well and it broke free and works fine now
thank you
Feb 17, 2009 | Craftsman 8.50 Torque Rating Dual...
Homelite Consumer Products Tiller Attachment Logo
2,119 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
