FixYa.com
Tags:
NEC SuperScript 1450N Laser Printer
Can't print pdfs in OSX
By Melissa - usenet poster
I've switched over to OSX and can't seem to print my pdfs. The print center says the jobs are stopped. If I start jobs it starts processing then stops again.
I'm printing to a HP Deskjet 1200C that is connected to a print hub.
If I switch to my apple laserwriter the jobs print.
Any clues?
Marvin
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 02, 2007
Helpful (85)
Brad
Brad - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Might be a silly question, but are you printing from Acrobat (and what version?) or from Preview?
Assuming you are trying to print from Acrobat 5.05 or 6, what happens if you try to print the PDF from Preview (apple's application)?
If you print to the printer directly and not through a print hub does it work?
Do other documents from other programs print to the 1200c without problems?
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Perkins
Perkins - usenet poster
Rating: 0%, 0 votes
Check and see but I think that the HP1200 is at most a PS2 device. It might not be even Adobe PS but an HP emulator.
Larry
Solution #3
Not Rated (0)
Brad
Rating: 0%, 0 votes
It looks like a lot of these printers or the driver could not handle latest options of postscript. A message to this effect would be more usefull than "Document can't be printed".
Solution #4
Not Rated (0)
maartenw
maartenw - usenet poster
Rating: 0%, 0 votes
You should try contacting HP customer support. I had similar problems with my HP printer (not necessarily Acrobat files). They sent me a new printer driver that worked. The printer driver was not available anywhere on the HP website. Good luck
Michael
Solution #5
Not Rated (0)
Hart
Hart - usenet poster
Rating: 0%, 0 votes
I had the same problem on my Laserjet 4100 DTN. In the print dialog box, scroll down to Acrobat. Check "Print as Image." It's a slow workaround, but it seems to get the job done until you can fix the problem permanently.
I eventually had to call HP and they sent me out a new DIM chip to install. I don't understand what it did, exctly, but it fixed the problem. I think it had something to do with memory. Have you tried contacting HP about the problem?
Solution #6
Not Rated (0)
LiZzIe
LiZzIe - usenet poster
Rating: 0%, 0 votes
I am new to this discussion group so I hope I don't
screw it up.
I may have the same or a similar question.
I can't print from my Mac G4 with OS X 10.2.6
to my HP Laserjet 1220 series. I am using Adobe
5.0 and I get the message:
"The document can't be printed" ????
Can you Help with these Printers problems?
Printers
TALLY 2030g matrix printer -...
Our printer has been working... Answer This...
Printers
red flashing light
red flashing light Answer This...
Printers
Printer screen has the words
Printer screen has the words... Answer This...
Printers
HP Photosmart C5180 All-in-One...
HP Photosmart C5180 All-in-One... Answer This...
Printers
I have a Cannon PIXMAMP210
I have a Cannon PIXMAMP210... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
