Question about GE Ovens
Gas leaking from valve on the oven pressure regulator
We were smelling gas in the kitchen when we weren't using anything. We called the gas company and the gas guy tracked the leak to the little red shut off valve on the pressure regulator. It is a GE model JGBS22BEA2WH and this is this part: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=214551. He flipped the valve a couple of times and it stopped leaking, so he left. But a couple of days later we smelled it again. So I opened the oven door and the oven was full of gas (strong smell). I was just going to replace this valve, but I was unsure if there are special things I need to do, like sealing the connections properly. Also is this valve leaking because it is broken, or is there some other part causing this to leak.
5 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: new gas valve, new gas smell
CG, unfortunately you replaced the wrong part. The problem with your oven is the igniter. The igniter is wired in series with a safety valve. The safety valve monitors the amount of electrical current flowing through the igniter when you ask it to "bake".  When the igniter gets "weak" it won't allow current to flow through it properly, this will keep the oven from heating. It will also cause your symptoms as well...
Here's the scenario; Say your safety valve is "looking" for 2.5 amps of electricity flowing through it before it'll open up and allow gas to the manifold. Your igniter is designed to allow 2.8-3.2 amps to flow in good operating condition, but your igniter has become "weak"... it's now allowing 2.48-2.51 amps. The safety valve is sensing this and opening and closing rapidly, allowing gas to flow through it (fluttering). BUT! the igniter is not hot enough to ignite the gas and/or there is not enough gas to ignite do to the fluttering effect of the valve. Sometimes it'll light sometimes it won't.
Your igniter is the cause and needs to be replaced.
Before you begin the repair, you should have the new part on hand. The part number is WB2X9154 and can be purchased at your local appliance parts retailer for about $50.00. Here's one online for $65.00.
First, UNPLUG YOUR OVEN!
To replace it... Remove the racks and lower panel (oven floor). This will expose the burner manifold where the igniter is mounted.  (It's the round thing on the manifold near the back... it has 2 wires going into it.) You'll need a 1/4" socket or nut driver to remove it.
(*TIP---> before removing the screws from the igniter, put a few drops of liquid dish soap on the threads to lubricate them. If you do this, you will not strip the threads of the screws and it will ease their removal.)
The new igniter kit will have two ceramic wire nuts in it. Cut the two wires off of the old igniter and strip them back about 3/8". Then connect the wires of your new one to the wires in the oven using the ceramic wire nuts provided. Then mount the new igniter and rebuild the oven.
(*TIP---> The new igniter is very fragile! [that's why it came wrapped tightly in bubble wrap] Handle it gently!)
There ya go! Total job time? ~45 minutes.
Posted on Oct 11, 2007
fridgetech
  • 473 Answers
SOURCE: gas leak from oven
Sounds like the ignitor is weak and needs to be replaced. How old is the oven and what is the model # from the sticker on oven?
Posted on Nov 07, 2007
meBNme
  • 334 Answers
SOURCE: wHIRLPOOL SUPER CAPACITY 465 MODEL: SF368LEPQ GAS SMELL
I will rarely say "call a professional" here because this is a do it yourself site right?
However, in this case, you obviously have a gas leak and/or malfunctioning gas valve.
Unless you have experience and training in detecting gas leaks I highly recommend shutting the gas off to the unit, ventilating the area, and calling a pro.
Gas can be very dangerous if handled improperly and a mere spark can "make house go kaboom".
If you are smelling it strong enough that you have to open windows, it is a potentially dangerous situation.
Posted on Dec 06, 2008
SOURCE: Maytag gas oven slow to ignite,makes poof sound
sounds like the safety valve gas regulator (its where the main gas line attaches in the bottom back)
Posted on Mar 28, 2009
dmftrucker
  • 1922 Answers
SOURCE: The flame in my gas oven is flickering orange
either the orfices are dirty or you lack enough air to completely burn the gas,you might want to have a tech from the gas supplier look into adjusting air flow or cleaning orfices
Posted on Sep 13, 2009
I have an ES340 gas self cleaning oven. I smell gas when I open the oven door. I checked all the connections in the back and the ones behind the back panel, and none are leaking. Are there connections...
Hello tds. It is not uncommon to smell gas when you open an oven door. That said, if the amount of gas you smell is stronger than it used to be call your gas company. They will send out a technician, free of charge, to check your stove. Joe
Thanks for choosing Fixya!
Jan 13, 2011 | Frigidaire Ovens
Oven has gas smell
all you need is a regulator or a thermostat
Feb 10, 2010 | Whirlpool GBS307PR Electric Single Oven
When I first turn on the oven I can smell gas. This just started so I don't that it is a leak at a gas line connection poin. It must have something to do with an internal valve.
Have the Glow bar ignition, thermocouple and gas regulator valve checked. It is not un-common for some gas smell as the Glowbar heats the thermocouple bulb.
This in turn when reaching the correct temperature activates the gas regulator. If the Glow bar is not providing ignition quick enough. More gas can be released before combustion is initiated. This extra can be the smell you are experiencing now.
Best to have the unit serviced by a qualified technician to be safe.
Good luck Luck be safe!
Nov 26, 2009 | Maytag CWG3100A Gas Single Oven
When I heat up the oven i get a strong smell of gas and it fills
Ok, your mixture is to rich at this time. you will need to access the gas pressure regulator and adjust the air to fuel mixture. add a bit more air and back off of the fuel a bit. this will correct this issue.
depending on the model, this may or may not be an option so, if you cant access the regulator and the burner assembly is not accessible as well, i recommend calling the local gas utility service tech to preform this adjustment. This rich mixture is very dangerous for you and your family and i suggest that this be corrected asap for you safety.
Please rate and god bless:)
May 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Mar 25, 2009 | Maytag CWG3100A Gas Single Oven
WHIRLPOOL SUPER CAPACITY 465 MODEL: SF368LEPQ GAS SMELL
Dec 06, 2008 | Ovens
Oven gas
For safety purposes call gas technician to check your gas pipe. If stove turn off supposed not to smell gas.
Jul 23, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
307 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
