Question about Mitsubishi VS-50605 50" Rear Projection Television
Horizontal lines jump on screen Mitsubishi Medallion HDTV 1080i
It might be just a coincedence, but...After using the DVD player we have horizontal lines jumping across the screen of our TV. We turned off the DVD and even disconnected it while watching TV but it did not solve the problem. The lines go fast sometimes and slow at other times but dont go away. It reminds me of the older TV's that you could make an adjustment by just turning a knob and slowing down the horizontal roll until the picture stabilized.
3 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: Rolling horizontal lines on 62" Mitsubishi
That problem is caused by failed Capacitors on the signal and FMT power boards. which is a very common problem for mitsubishi TVs. There are repair kits available for the V26 dlp which contain the capacitors and instructions on how to do the repair. Heres a link check under the repair kits category.
http://servicemanuals.vstore.ca/
Posted on Mar 29, 2009
MNfisherman
  • 11896 Answers
SOURCE: Mitsubishi TV had horizontal lines across the screen and rolls up
Answer
ONE: Yes, the speaker mounted close/near to the set can be a cause of mischief; please move it further away and see if that helps clear up the problem. But, you must keep it away for several days before you will know for sure because it takes some time to degauss all the internal parts that may have become corrupted by the magnets in the speaker.
TWO: Yes, any set can be repaired the question is cost and wisdom. Old sets are sometimes not worthy of the repair simply because of the likelyhood that another failure will follow soon after. A big screen always invokes a repair charge of $200 and up. After a few of these you will wish you had put all the money into a new set!
THREE: The lines are most likely a problem in the vertical blanking circuits of the set. These are horizontal retrace lines that are supposed to be blanked out during vertical retrace of the raster. Think of it as a paintbrush that scans across the screen painting thin lines and when you get to the bottom of the screen it goes quickly back to the top, but during that time the horizontal, which is many times faster, has made several sweeps; so it must be blanked out during the retrace. The repair involves finding the guilty parts and replacing them. Usually this repair runs over the $200 somewhat.
FOUR: Prior to calling in a service tech try a hard reset to see if that will recover any of the circuit degradations. Merely unplug the power cord and leave unplugged for 4 hours or more. It may help. Or, it may not help; but worth a try since is won't cost you anything.
If the set is over 5 or 6 years of age it probably is not a condidate for any expensive repair. On the other hand, it is a Toshiba - and they make a fine set.
Hope this helps. Let me know if you have further thoughts.
Posted on May 09, 2009
  • 242 Answers
SOURCE: Rolling horizontal lines. Changing picture shape like fish eye lens view.
the magnifing unit is going
Posted on Dec 23, 2009
I need to be able to connect DVD player to output 3 on Mitsubishi Medallion hdtv 1080 we can't seem to get it to work
It needs to be input if you want to display some on the TV from the DVD player. HDMI is the easiest as it's both audio and video.
Jun 01, 2015 | Mitsubishi LT55164 Unisen Medallion 55...
LG 32LD450UA, horizontal thin black lines covering scren
Thats almost alwasy a Tconn issue replacing the Tconn board should solve the issue in most cases you can get replacement T conn from www.tvcircuitboards.com
Mar 02, 2012 | LG 32LD450 32 In. LCD HDTV
Mitsubishi rearTV has intermittent wavy lines running throughout
Do you have anything to test it in 1080i? Does it do it on all connections or just one? I had a similar problem with my TV that turned out to be a bad input board. Mine would only display 1080i through the Component connections. All others would show pink and green wavy lines. It cost me around 500 to fix it. Unplug the TV. Remove the back cover for the TV. Using a NON-metal object, or gloves, wiggle the input board (that has all the video connections on it) slowly back and forth and see if the problem comes and goes. You will have to have someone watching for you. If something is loose on that board, the problem should show itself. Narrowing down the problem will probably save you money on repair bills.
May 13, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Wavy horizontal lines running through the screen
Ur tv convergence is dead.U must know how to solders?The 2 STK convergence ICS.and some or all it resistors must change.Tries websites Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 17, 2010 | Mitsubishi WS-55613 55" Rear Projection...
Jumping horizontal lines when connected to CD player
Hello, I want you to do a test first. Take you TV and connect a DVD player to it and see if this problem occurs. I bet you it wont, because the problem is not with the TV nor the CD of the karaoke machine. The problem is with the sync pulses of the signal from the karaoky, and the inability of the Tv to sync-up with those signals. What I would use is a video stabilizer between the TV and the DVD player. If the TV still has the problem with the DVD player I would then check the TV for a vertical section problem. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jan 28, 2009 | Sharp 13VT-K100 13 in. Combo
Set-up big screen tv
just hook up by color coding. or through HDMI which will be the easiest for you. (if you things support HDMI)
Aug 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Horizontal Lines On Screen
horizontal lines = horizontal sync off . mitsbishi always seemed to have this problem .. on the older sets I would take the back off and inside deep on the board i would adjust a pot and sync it right .... and never had a recall, maybe your newer model has this too .. this little control,
but its a horizontal sync problem.
if no change the horizontal processing ic.
Jan 11, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Interlaced comes in fuzzy & with lines
you need to check if the dvd or games are doing the same thing on different inputs. if they have the same problems you might be looking at the single board or the focus block.
Dec 01, 2007 | Akai PT5598HD 55" Rear Projection...
Horizontal multicolored lines appearing
Open up the TV and unplug and re-plug the connectors to the circuit boards. This is most often caused by a poor connection of the circuit board connectors.
Mar 25, 2017 | Samsung LN-S4092D 40 in. LCD HDTV
Mitsubishi VS-50605 50" Rear Projection Television Logo
178 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
