Question about Philips GOGEAR SA6045 MP3 Player
Can not transfer wma,wmv
I get the following error message:
Unable to transfer the selected title because [Insert] returned 0xC00D2779 (I used zero's, might be capital letter o). I transfered a video one time and since then can not transfer.
  • maidk_64 Mar 02, 2009
    I understand the lic. part, but what about mwv's that are supposed to be for handheld or mp3 players. A download from the public library which says for mobil device (mobile version). I was able to transfer one time (from the Public Library), but not since then. They use OverDrive Media.
  • 8,596 Answers
The exact description of that error message is: "The file could not be transferred because the device clock is not set."; NS_E_DRM_LIC_NEEDS_DEVICE_CLOCK_SET
It is related to a DRM license that is on the videos that you are trying to transfer - either the video you are trying to transfer has a DRM license that does not have transfer rights, or does not allow reencoding.
Basically, the video you are trying to convert is copyright-protected, so you will not be able to use it on a GoGear, only because the GoGear's require re-encoding first. Sorry.
The only solution is illegal - you would have to use a DRM-Stripper such as Tunebite to remove the license from the video. I would not recommend it.
-Tha Mp3 Doctor
Posted on Mar 01, 2009
  • Corey Knoettgen
    Corey Knoettgen Mar 03, 2009
    This player does not recognize wmv format directly - you have to run the video through the Philips Media Converter - and you may still get an error message if it is DRM-encrypted. Some Go Gear's recognize DRM-encrypted wma's, but none of them accept DRM-encrypted videos, even though those videos will work on other mp3 players.
Hello all - here is the code solution - happy printing!
Machine unable to int - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An "initial purge", for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
1) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
2) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
3) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
4) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
5) Press the 9 key twice to return to the standby state
Jan 06, 2011 | Brother DCP 115C All-In-One InkJet Printer
Can't transfer data files
Can u tell me the model of ur mp3 player ???
Mar 07, 2008 | Audio Players & Recorders
Cannot Play .wmv file with WMA 9.2 and WMV 9 professional codecs
Have had same happen. Try clicking right and choosing open with....and choose windows Media player for list. Don't know why this is the part that works for me. double clicking the file has never worked for me. I get the wmp with the same error but when I select the wmp and let IT open the works....I think it is magic and a stubborn way to do this but it works
May 07, 2009 | Computers & Internet
I was afraid of that. The file that you are trying to load has a DRM license on it that has a fixed-term license. It will play on your player for about a wekk or so, and then it is unusable except on the computer itself.
Most mp3 players that claim to support audiobooks don't really support most audiobooks - or don't play them correctly. Audiobooks that are in mp3 format (as in, NOT Overdrive) will give you the fewest problems.
Mar 02, 2009 | SanDisk Sansa Clip MP3 Player
About adding songs to ZEN Mosaic
The first one is a DRM error and should be solved by the FairUse4WM which you can download for free from the following link.:
This will rip the DRM off the tracks and you should be able to listen to the without problem.
The other problem could be caused by codec differences. With GSpot you can check what codec was used to create the mp3s /both the working ones and the others/. If different codecs appear than you just have to reconvert the non working ones using the codec which workes.
You can download GSpot from here, for free.:
Feb 14, 2009 | Creative Labs Creative Technology Zen MP3...
Sans Clip 1 Meg Player
I would try seeing if you can update the firmware, you can find Sandisk's Sansa Clip Firmware updater off to the right on this web page:
Let me know how that works for ya.
Oct 10, 2008 | SanDisk Sansa Clip MP3 Player
I called Sansa and I was instructed to format my player. The steps were as follows:
1)Connect player to computer
2)Go to my computer and right click on your player
3) Click format on the menu
This will start the formatting of the player. After this I was fine. This is the 2nd time I have had to do this in a year and all I put on this player are books.
******Please Note**** This process will erase any files you have on your mp3 player.
May 08, 2008 | RCA JET S2002 MP3 Player
Hi shellibelli,
I am not expert, but I had the same problem using OverDrive Media to transfer audio books and music to my SanClip 2mb. So, here is what I did, I hope it will help you.
On my mp3 player I went to "Settings" -> "USB Mode" - > and then I selected "MTP", whereas "AutoDetect" was what was previously selected by default. This seemed to solve my problem. I hope it helps you!
Feb 22, 2008 | SanDisk Sansa e250 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
596 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
