No sound on tv switch positon. works on dvd
I can unplug and plug back in and sound will sometime come back onfor a while................
  • 9 more comments
  • tantiques Feb 28, 2009
    I can unplug like you said and it doesn't come on all the time and when it does it cuts off. I also can turn on cd and the back to to tv sometime and it might work. CD sound works good. I am tech. and it seems to be in mute ckt. May be a common trouble with this unit. I don't have diagram for unit.
    fuse is good
    Yes I agree with the mute theory. Have you had any other reports of this problem with this model? Boards are expensive. Is ther switching tr or ic that can be changed?
    I have checked everything on ckt. board.everything seems ok. Where do I get ckt board for coby. Do you have address of co.?
    Sound works on everything but tv. Don't think its ic
    radio shack does not carry parts i need. Give me mfg. web. site
    resistors don't short out. they burn up or open up. some time this tv will work for hours. It looks like theres a lot of guessing going on here. i need factory parts location
    tv is almost new. nothing worn out
    tv picture is perfect. all chans work good and snow free
    i need to talk to tech. that knows something about coby tv sound. everything i have received so far is general info. which i tried before i contacted you
    Resistors that are burned can be seen and the ones you say are shorted turn to charcol. I was in business before you were born. You need to admit you don't know anything about this tv and quit wasting my time.
  • 217 Answers
What is the make and model #??
Posted on Mar 01, 2009
  • 350 Answers
I've searched the following and have to tell you support for Coby Repair seems impossible to find.
I wouldn't waste any more time.
It appears as though Coby is built not to be repaired but replaced. It's a shame. If I'm wrong and anyone can find support for repair or even service I would love to hear from them.
For now Coby goes into my Poor Support File (No phone #, no offer of substaintal repairs).
Failed to Find Necessary Support at the following sites....
Coby Support @ http://www.cobyusa.com/?p=doc
Coby Parts & Accessories @ Fox International @ 800-321-6993
Electronic Parts @ http://www.partstore.com
jackiaria
Posted on Feb 28, 2009
  • 58 Answers
Ur cables mights be worn out form to much movement and usage or u could have a bad connection replace the cables first and then chek ur conecctions
  • 158 Answers
Hello, it sounds as if you are having a problem with sound coming out of your tv after awhile. It sounds like there is a resistor heating up and shorting out after it gets hot.There may also be something wrong with the printed circuit board it too can get hot and short out. thank you
  • suterman
    suterman Feb 28, 2009
    Correction risistors do burn up but the can produce enough heat to short out on a printed circuit board. I guess you have never run into that so you need to quit talking about someone guessing.
    Sergeant:
  • 326 Answers
Yes there is sound ic located on the main board if its gone weak this problem happens sometime. you can get the parts from www.radioshack.com
  • 565 Answers
Its the problem of tv cable connection it has bad signal try to rescan channels.
  • Teet Bergmann Feb 28, 2009
    try to fine tune the channels or manual rescan
    Scholar:
  • 85 Answers
Check out the audio circuit and ic on the main board that will be loose internally or got weak.
  • 19,396 Answers
It is not in mute, the mute on audio circuit will be the same if you use DVD or Tuner.
It is also not a problem with audio circuit, as that would affect all signals.
If it is mute with an external receiver, then it is either a cable/connectors problem, a bad receiver, or a bad input board on TV.
If instead has no sound with only an antenna attached, then the fault is on tuner board or on tuner circuits.
If the TV has an internal tuner board, then you can replace the board.
If you want to repair the TV working at component level, you will better buy the service manual for your model.
You can buy service manual and replacement entering your make and model details here.
    Sniper:
  • 113 Answers
check out the internal fuse of TV. and let us know the result.
Good Luck!!!
neo
  • nenotech_neo Feb 28, 2009
    ok....plug a jack in to the audio port and remove it after plugin.
    some time audio jack pins push down, cause no audio.
    yes..... if further you have the same problem, means its a time to call a repair person so time to change the sound IC.
    Genius:
  • 1,550 Answers
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
  • SAM ANDERSON Mar 01, 2009
    You need to provide model details of your tv .
    You can get parts for your tv by checking the part number from the link below
    Parts for coby tv
Dvd will not play, or eject from dvd slot
Try unplugging it from the power source, wait a minute, then plug back in, some times the "query" line is locked up. If this doesn't work it could be jammed on the track of the dvd, causing the mode cam switch not to function correctly. Have you physically looked inside the door to make sure something isn't in the way of the disk? This sometimes happens as well.
Mar 13, 2016 | Westinghouse RMC-02
Projection TV. DVD works. Cable often seems, "untuned". Static & un-fine-tuned sound of channel with black screen. Then, later, it will come on just fine. Sometimes, will go back to untuned status.
I would suspect your cable box first. I would unplug the power cable from your cable box and wait 60 seconds. Plug it back in and try to watch cable tv. I would also make sure the coaxial cable going from the wall to your cable box is connected properly. I would also make sure the cable going from the cable box to the tv is connected properly. Test your tv and see if it works correctly when you watch cable. If this fixes the issue you are good to go.
  • If this makes no difference use a set of new cables if you have them.
  • If this does not work then call your cable company. They may have to replace your cable box.
May 25, 2015 | Televison & Video
Why does my t.V keep switching to dvd screen.
TVs turn on in the last screen they were turned off. Try switching screens using the remote control. If the dvd screen keeps coming back, try pressing or tapping on the manual key located on the side or bottom or back of the TV panel. Sometimes this key gets stuck up. If this does not work, try unplugging your home theater and turn on the TV. Most TVs automatically switch to DVD when they sense signal from HDMI cables.
Nov 26, 2014 | Televison & Video
Screen went black. Shut t.v. off and tried to turn it back on. Power comes on, front light is green, and in about 3 seconds the t.v. shuts off, green light goes off. Was playing dvd at the time. Shut off...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix. SD TECH
Jul 15, 2011 | Mitsubishi WS-55819 55" Rear Projection...
I have a Panasonic DMR-EZ48V and have had many problems with it from day one. It sometimes records a tv program sometimes not. Sometimes plays dvd movies sometimes not. It often freezes up and has to be...
Not having Cable TV would not stop it playing back a DVD. A good TV aerial, with new cable will cure any bad TV signals, but the fact that it is not playing back a DVD everytime tells me that there is something wrong with the unit's mechanism.
The Panasonic engineer in this case doesn't know what he is talking about.
Jun 16, 2017 | Panasonic DMR-EZ48VK DVD Recorder
Can't switch to TV. I removed a DVD that was stucked in it. I continues to ask for DVD or sd card Model is dtv-263-d
Did you remove the DVD without opening the tray? If so unplug the unit and let it unplugged overnight. When you plug it back in it should work unless you damaged something removing the DVD. Let me know how it works out.
hardrocko
Jan 31, 2010 | Mintek DTV-233 23 in. TV/DVD Combo
Can not change "Device" input, no sound control,no remote control
I unplugged the manual switch electrical connection. Everything works just fine with the remote.
Not sure what is wrong with the switches just yet, but suspect a resistor problem. I have checked all voltages and have 5.04 v feeding the switch assembly on what I feel are the correct circuits
(5v, ksco, ksc1, man/reset). I have no voltage on the ground circuit with the board plugged in, so the ground circuit should be ok. I have tested all switches with ohmmeter, all switches work. I suspect a resistor problem as I have one with no voltage drop and one resistor with no voltage pass-thru. Would need a wiring schematic with values to pinpoint better.
May 16, 2009 | Mitsubishi WS-65711 65" Rear Projection...
The sound on my t.v. is not working, I checked all the settings on the remote and still I have no sound, wha do you think it might be?
Unplug yer cable box from TV...after a minute, RE plug it back in
I had that problem beofre. Sometimes it wouldn't switch back from Video to TV!
Jan 10, 2009 | RCA HD52W58 52" TV
Power supply for dmtech wt20xt lcd tv
I have DMtech 20" with intergrated DVD and had the same problem- blue light lit on power switch but no response on power up.
I noticed that when the power cord was unplugged from the back of the TV the green LED on the power supply would brighten and consequently dim when plugged back in. Sometimes the blue light on the power switch would strobe very quickly but you had to look carfully for this.
I repeatedly unplugged the DIN type power plug from the back of the TV untill the green light on the power supply stayed a constant bright and there was no strobing on the blue light on the front of the TV, when I powered the TV on at this point the button worked again and the tv powered up with the silly tune then life in the screen. I did have to do this a good few times (I'm tenacious) but it did work!!!!!
Hope this helps someone else, cheers.
Apr 11, 2008 | Televison & Video
TV not coming on...
The same thing happened with my T.V. (although it is an RCA). The first time a repair man charged me $75.00 to fix. The next time we were told to just try unplugging it for a few minutes then plug back in...that worked. T.V. still sometimes does this, unplugging it fixes the problem
Sep 03, 2006 | Toshiba CZ27V51 27" TV
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
