Question about Alpine CDE-9850Ri CD Player
Newly installed alpine resetting
Recently installed alpine deck in cavalier, still has stock speakers. Any time i turn it up past 19 the deck shuts down and resets. comes back to same song on cd where it cut out at.
  • 21 Answers
Chevy stock speakers are 8 ohm. You should change out the stock speakers. Or at least dissconnect the back speakers and see if cd player still overloads and shuts off.
Posted on May 22, 2009
    Scholar:
  • 69 Answers
Have you checked the Ignition fuse for the radio? Sometimes if a fuse partially blows it will still allow power to flow through it but limit the amount of current going through. I am going to have to say its something to do with either the ignition not getting proper power or speakers wired incorrectly or a bad ground to the radio. I say this because you say it goes back to the same song that it cut off from, so this means its got memory which means it has constant or battery power. Battery powere is yellow wire, ignition is red wire, and ground is black, front left is white and white/black, front right is grey and grey/black, rear left is green and green/black, and rear right is purple and purple/black.
Posted on Mar 23, 2009
Amp shuts down under load - If I turn the volume from the head unit up past about 16 it shuts off. I've had it for a while and haven't had this issue until recently. Thanks!
If you added or changed speakers and the impedance (ohms) is not the same, it could overload the amp depending on which way the speakers are wired (parallel or in series).
Apr 10, 2014 | Alpine - Mrx-v70 X Power - 5 Channel 360w...
Car deck turned too loud and shut off
The deck might be damaged. In order to accommodate that kind of layout, there should be a cross over, and a separate 2 channel amplifier for the subs. Without that it's easy to fry the deck!
Dec 06, 2013 | Alpine CDA-9857 CD Player
There is no bass coming out of the speakers why?
check the crossover setting on the amp and try bringing it down to 80hz and make sure the filter is set to HPF
Jun 15, 2010 | Alpine MRP-F300 Car Audio Amplifier
I'm having trouble connecting my alpine cde-9852 to my 96 jeep cherokee. is there a wiring diagram online for this? thanks
Constant 12V+ Pink Switched 12V+ Purple/White Ground Black Illumination Light Blue/Red Dimmer Orange Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Dark Blue/Red Rear Speakers 5 1/4" Rear Deck Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Dark Blue/White Right Rear (-) Dark Blue/Orange
Jul 11, 2009 | Alpine CDE-9852 CD Player
Alpine X 300 gets to a certain volume and turns off how cna i fix this problem?
How do you have your speakers hooked up to the deck. If you have bridged any speakers to the deck, its overloading it and thats why it shuts off. Its getting too hot.
Jul 10, 2009 | Alpine IDA-X300 Car CD/ MP3 Player
Can't get my amplifier to work.
My homie had the same problem with his escalade they adapted an rca line adapter from the factory wiring to geta signal to his amplifier and it just wasnt hitting like it should so we installed a new deck and plugged the rca cords right into it and boomboom pow it was hittin like a champ-we figured that the stock premium system that was incoprporated into the truck had some sort of an onboard amp that was filtering the bass from the door speakers and which was limiting the bass output to the rca adapter and thus on down the line to the amplifier- so maybe ya might want to look into getting an aftermarket deck and see if that helps your cause-good luck
May 21, 2009 | Alpine MRP-M450 Car Audio Amplifier
Alpine stereo car deck installed in place of factory Bose with
What you have been told is correct, these proprietary systems are great for the manufacturer, but when they start to have issues (and they will) they leave you 2 options: pay through the nose to stay original or replace the amps with new ones....the upside of this is aftermarket amps are soooo mugh better than stock that it is lauhgable.
Mar 11, 2009 | Car Audio & Video
Alpine sub pre outs
i know people dont like doing it this way but when in doubt, splice wires.
go to walmart and buy a crossover, splice your front or rear door speaker wire and wire in the crossover and also the door speaker. plug your RCA cables in and run them back to the amp.
most people with stock decks do this if they dont have sub out or amp out.
if u need more help let me know
Feb 18, 2009 | Alpine IVA-D310 Car DVD Player
Volume won"t pass 20 cut's off dack
the speakers either cannot handle the poew and shut off to protect the radio- or the wiring for the speakers are not insulated well or your groung is not good
Mar 26, 2008 | Alpine CDA-9833 CD Player
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
Alpine CDE-9850Ri CD Player Logo
221 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
