Question about IBM ThinkPad T40 2373 Notebook
WHERE IS THE WIRELESS SWITCH ON THE THINKPAD R50?
  • 2 more comments
  • muchomonty Mar 08, 2009
    i tried and nothing, i'm about to throw my router out the window as well. thanks for the info.
  • wnkrbean76
    wnkrbean76 Aug 06, 2013
    go to lenovo and search for the driver to this Cisco Aironet Wireless Card
  • wnkrbean76
    download the driver and then go to the yellow ? and right click update driver, select to install from known folder and then browse for that download it should be in your driver folder under like wll or wall something just click on down the list until the ok gets highlighted and then hit ok
  • wnkrbean76
    after 3 days I finally got mine working
    President:
  • 2,653 Answers
Try pressing Fn + F5
That's the hotkey command for the R50
Let me know if this works.
Posted on Feb 28, 2009
    President:
  • 1,073 Answers
And here is the manual...if u ever need to know anything else about you R50
ftp://ftp.software.ibm.com/pc/pccbbs/mobiles_pdf/39t2462_01.pdf
Good luck
Nic
Geekman
  • 32281 Answers
SOURCE: thinkpad r50
The Power On Password problem is near impossible to crack. It is designed to prevent unauthorized access to the Thinkpad and removing the BIOS battery will not remove the password because the password is stored on an EEPROM chip.
There are no backdoor passwords available, the only option is to ask the person who set the password.
OR
There is a way to hack into the Thinkpad to see and remove the password but it requires electronic skills, a program and a working computer.
For details on how to do this go to :-
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Posted on Feb 04, 2009
Geekman
  • 32281 Answers
SOURCE: IBM R50
You could have a defective LCD screen, If the laptop appears to be running and the hard disk is spinning but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jun 22, 2009
parrotheadpc
  • 2600 Answers
SOURCE: ibm thinkpad r50 notebook won't boot
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here:
http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Oct 15, 2009
  • 20 Answers
SOURCE: how to turn on wireless device
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
abarasa42
Posted on Jan 03, 2010
SSidd
  • 166 Answers
SOURCE: ThinkPad R50e PC Notebook: i cannot able install wireless adaptor for ibm r50...
please try this link for download
http://www-307.ibm.com/pc/support/site.wss/MIGR-55042.html#wireless
Posted on May 06, 2010
How to disable wireless on IBM R50 to use on a plane
Software Solution: FN + F5 key enables and disbales wireless 802.11.
Hardware Solution: There should be a hardware switch to disable it at the bottom of the laptop or at the side.
But u cud temporarily on or off it using the software solution.
Feb 28, 2011 | IBM ThinkPad T40 2373 Notebook
Requird Lan Driver of IBM Think PAD LAPTOP
Drivers for Vista are not available.
You can find all drivers for R50 clicking below:
IBM Thinkpad Driver Download models R50
Feb 25, 2009 | IBM ThinkPad T23 Notebook
Thinkpad r50
OR
Feb 04, 2009 | IBM ThinkPad R51 Notebook
Thinkpad R50 Reboot problem
Try a different battery. Then come back.
Jun 23, 2008 | IBM ThinkPad R50e Notebook
IBM THINKPAD R50
You need to setup the wireless, consult the manual on how to configure the wireless.
Apr 14, 2008 | IBM THINKPAD R50 - P M1.5GHZ 256MB 40GB...
HAVE A CD ROM TEAC CD-224E PART #1977047B-12 DO YOU KNOW WHAT IT WILL WORK IN
This slim CD Rom is compatible with the Cubid and Travla mini ITX cases.
This is also compatible with:
Portege 3440CT, Portege 3480CT, Portege 3490CT, Portege 4000, Portege 4000CT, Portege 4005, Portege 4010, Portege M100, Portege M200, Portege M205, Portege M205-S809, Portege M205-S810, ProLiant Content Delivery , ProLiant DL140, ProLiant DL320, ProLiant DL360, ProLiant DL380 G2, ProLiant DL380 G3, ProLiant DL560, ProLiant DL560 R01, ProLiant DL580, ProLiant DL585, ProLiant DL590, ProLiant DL590 R01, SAN Management, Satellite 1550CDS, Satellite 1555CDS, Satellite 1715XCDS, Satellite 1730-S101, Satellite 1730CDT, Satellite 1735-S101, Satellite 1800, Satellite 1800-S203, Satellite 1805, Satellite 1805-S203, Satellite 2060CDS, Satellite 2065CDS, Satellite 2100CDS, Satellite 2100CDT, Satellite 2105CDS, Satellite 2140CDS, Satellite 2140XCDS, Satellite 2180CDT, Satellite 2210CDT, Satellite 2210XCDS, Satellite 2215XCDS, Satellite 2230CDS, Satellite 2250CDT, Satellite 2250XCDS, Satellite 2255XCDS, Satellite 2510CDS, Satellite 2515CDS, Satellite 2520CDS, Satellite 2530CDS, Satellite 2535CDS, Satellite 2540CDS, Satellite 2540CDT, Satellite 2540XCDT, Satellite 2545CDS, Satellite 2545CDT, Satellite 2545XCDT, Satellite 2590CDS, Satellite 2590CDT, Satellite 2595CDS, Satellite 2595CDT, Satellite 4000CDS, Satellite 4000CDT, Satellite 4005CDS, Satellite 4005CDT, Satellite 4010CDS, Satellite 4010CDT, Satellite 4015CDS, Satellite 4015CDT, Satellite 4020CDT, Satellite 4025CDT, Satellite 4030CDS, Satellite 4030CDT, Satellite 4060CDT, Satellite 4060XCDT, Satellite 4070CDS, Satellite 4080XCDT, Satellite 4085XCDT, Satellite Pro 4600 (14.1), Satellite Pro 4600 (15), Satellite Pro 6000 (14.1), Satellite Pro 6000 (15), Satellite Pro 6100 (14.1), Satellite Pro 6100 (15) , Satellite Pro 6100 (15 SXGA), Satellite Pro 6100 (15 UXGA), Satellite Pro M10, Satellite Pro M10-S405, Satellite Pro M10-S406, Satellite Pro M10-S407, Satellite Pro M10-SP405 (14.1), Satellite Pro M10-SP405 (15), Satellite Pro M15-S405, Satellite Pro M15-S406, SUN FIRE V100, SUN FIRE V120, Tecra (14.1) , Tecra (14.1 SXGA) , Tecra 8000, Tecra 8000 (12.1), Tecra 8000 (12.1 STN), Tecra 8000 (13.3), Tecra 8000 (14.1), Tecra 8000 (14.1 PIII) , Tecra 8000STN, Tecra 8100, Tecra 8100 (13.3), Tecra 8100 (14.1), Tecra 8200, Tecra 9000, Tecra 9100, Tecra PE2100, Tecra S1 (14.1), Tecra S1 (15) , Tecra S1 (15 UXGA), Tecra TE2000, Tecra TE2100, ThinkPad 1300 1171 (12.1) , ThinkPad R50 1829 (14.1) , ThinkPad R50 1829 (15.0) , ThinkPad R50 1830 (14.1) , ThinkPad R50 1830 (15.0) , ThinkPad R50 1831 (14.1) , ThinkPad R50 1831 (15.0) , ThinkPad R50 1836 (14.1) , ThinkPad R50 1836 (15.0) , ThinkPad R50 1840 (14.1) , ThinkPad R50 1840 (15.0) , ThinkPad R50 1841 (14.1) , ThinkPad R50 1841 (15.0) , ThinkPad R50e 1834 (14.1) , ThinkPad R50e 1834 (15.0) , ThinkPad R50e 1842 (14.1) , ThinkPad R50e 1842 (15.0) , ThinkPad R50p 1832, ThinkPad R50p 1833, ThinkPad R51 1829 (14.1) , ThinkPad R51 1829 (15.0) , ThinkPad R51 1830 (14.1) , ThinkPad R51 1830 (15.0) , ThinkPad R51 1831 (14.1) , ThinkPad R51 1831 (15.0) , ThinkPad R51 1836 (14.1) , ThinkPad R51 1836 (15.0) , ThinkPad R51 1841 (14.1) , ThinkPad R51 1841 (15.0) , ThinkPad R51 2883 (14.1) , ThinkPad R51 2883 (15.0) , ThinkPad R51 2887 (14.1) , ThinkPad R51 2887 (15.0) , ThinkPad R51 2888 (14.1) , ThinkPad R51 2888 (15.0) , ThinkPad R51 2889 (14.1) , ThinkPad R51 2889 (15.0) , ThinkPad R51 2894 (14.1) , ThinkPad R51 2894 (15.0) , ThinkPad R51 2895 (14.1) , ThinkPad R51 2895 (15.0) , TRANSPORT NX
Mar 05, 2008 | Computers & Internet
Wireless signal inconsitent; sometimes cuts out
If you are able to, take the the linksys card out of that IBM r50 and install it on another one of your laptops.If you get a great signal you know the card is good but if you move that card to another laptop and have the same problem you will have to replace the wireless card.If other laptops will not accept that card you can purchase a new Lynksys wireless usb adapter and see if that solves your problem.Those usb wireless adapters only cost about $35.Another way to seperate the problem would be to see if the IBM R50 will access any other wireless network with more signal strength.take your laptop to a public wireless connection(mcdonalds star bucks) any if you get a good signal than your problem is with your router.RATE ME IF THIS HELPS....Good LUCK!
Nov 17, 2007 | IBM Refurbished THINKPAD R50 - P M1.5GHZ...
IBM ThinkPad T40 2373 Notebook Logo
3,105 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
